Cold Weather Riding: Muffs vs Heated Grips vs Winter Gloves
ViniH
PostPosted: 00:30 - 29 Nov 2013    Post subject: Cold Weather Riding: Muffs vs Heated Grips vs Winter Gloves Reply with quote
New biker here having passed my mod 2 last week, and having only 120 solo miles under my belt thus far (accrued in a return commute from Cardiff to Bath Spa - but I did almost all of my learning in extremely bad weather (high wind, heavy rain, etc)).
I have a question with regard to the only part of me that seems to get cold, my fingers.
I've done quite a bit of reading online, including reviews and forum threads, and I can't seem to really decide on the best method of avoiding the pain of really cold fingers on longer high-speed rides.
So I thought I would ask for some advice, in the hopes that the collective experience here will aid me in making a decision.
I currently ride a Divvy, more specifically a 2001 Yamaha XJ600N. My current weekly "routine" includes a once a week commute from Cardiff to Bath Spa, and a weekend ride for several hours. I intend to do this all winter, in all weather, with the possible exception of heavy snow. I am also intending to ride from Cardiff to Preston, a journey of a little over 200 miles, in mid December.
Generally I do not feel the cold, and while riding this is no exception, quite often I am too warm, however after about 40 minutes at 60mph+ I notice that my fingers, especially my fingertips, are very cold and it can get painful.
So my questions relate to methods of avoiding cold fingers, specifically whether I should invest in a good pair of winter gloves, handlebar muffs, heated grips, or some combination of these. My budget is approximately £100, although this is not set in stone.
Winter Gloves
The research I have done seems to indicate that you can buy a good set of winter gloves for under £100.
I am basing this primarily from Visor Down reviews (and the user comments), specifically:
>£100 - https://www.visordown.com/product-features/tested-sub-100-all-weather-gloves/21734-7.html
and
>£60 - https://www.visordown.com/product-features/tested-sub-60-all-weather-gloves/22259-7.html
But my friends who ride have all advised me that gloves tend to wear out reasonably quickly, so this is likely to be the least cost-effective solution to my problem.
Heated Grips
I have very little technical expertise with either electronics or mechanics, and I would feel very uncomfortable wiring up a set of heated grips myself, therefore the only reasonable scenario would be for me to buy a set and have a garage fit them for me, presumably at the extra cost of about £50.
My research has told me that heated grips have very limited effectiveness for my riding situation, and that they often keep the hands warm but not the fingers/fingertips - although it seems that a combination of heated grips and muffs are very effective.
In addition I am concerned that the extra power drain might be a little much for my old bike, especially given that the lights will be on almost all the time during the winter.
Handlebar Muffs
Although I cannot imagine handlebar muffs will do anything to improve my image, these are the direction in which I am currently leaning. They seem to be pretty cost effective and in theory could be transferred from bike to bike, and are unlikely to suffer wear issues like gloves. I have been reading quite a lot about them and my main considerations are the fitting (I don't much fancy anything that involves a Stanley knife and super glue), the possibility of interference with levers/instruments, and getting my hands in and out of them safely while riding.
Also, the ones I was looking at, based on reviews, were the Oxford "Bone Dry" muffs - although various forum posts recommend the Tucano Urbano which are apparently easier to fit, however some posts suggest these latter are only really suitable for scooters.
So I'm really looking for some advice on the above, and would welcome your thoughts and comments on this, it is entirely likely that I will make my decision based on the discussion in this thread, so please share any experiences you have with any of these methods (or indeed some other method I haven't yet considered).
haroman666
PostPosted: 00:34 - 29 Nov 2013    Post subject: Reply with quote
Winter gloves + Bar muffs = barely chilly fingers.
I use lobster-style gloves which cost me about £30.
Bar muffs are Oxford ones which cost me around £25 on Ebay.
Job's a good'n'.
EDIT: To be slightly more helpful here's links to what I have:
Gloves
Bar Muffs
I will say though; having a faired bike has made a massive difference to how warm I am.
lozzypop1
Certified MILF!
PostPosted: 00:46 - 29 Nov 2013    Post subject: Reply with quote
I'd suggest the other combo, Heated grips + Muffs = Lozzy riding all year round without cold fingers
PostPosted: 00:58 - 29 Nov 2013    Post subject: Re: Cold Weather Riding: Muffs vs Heated Grips vs Winter Glo Reply with quote
Noooonooo, nooo.
Well, oxford ones are 'ok' if you don't go over 40 and don't mind a bit of a draft etc.
Tuccano are THE muffs (no, I don't have shares in them, but maybe I should.)
They clip on to the bar ends so don't push back against the bars.
They do bigger ones fine for 'normal' bikes.
If you don't use the cable ties to hold them on, it takes about 20 seconds to get them off or put them on. So easy to take off if someone else wants to ride your bike and doesn't like them etc.
I would go for the muffs first.
I never bothered to fit the heated grips on my GSXR, but both does add that bit more.
Heated grips alone tend to overheat the middle of your hands, but the outsides are chilled by the wind. Decent muffs remove that.
On my KTM I could be sitting at 70mph on the motorway with soaking hands in mx gloves from greenlaning but not have a problem with the oxford muffs (around enduro bash guards, which solves some of their problems) and symtech heated grips.
The symtec heating element goes under your normal grips and is very thin, so doesn't noticeably increase the size of the grips.
I wouldn't mind some heated gloves, but most of the time prefer the convenience of the above setup - which if you've got it wired in to a relay for the grips, means no extra fiddling at all.
PostPosted: 02:05 - 29 Nov 2013    Post subject: Reply with quote
Heated grips and and lobster gloves Thumbs Up
PostPosted: 02:15 - 29 Nov 2013    Post subject: Re: Cold Weather Riding: Muffs vs Heated Grips vs Winter Glo Reply with quote
...are good, but muffs and either grips or warm gloves (which will be dry gloves) are better.
ViniH wrote:
I have been reading quite a lot about [muffs] and my main considerations are the fitting (I don't much fancy anything that involves a Stanley knife and super glue), the possibility of interference with levers/instruments, and getting my hands in and out of them safely while riding.
Mostly non issues, at least with Tucano Urbanos. They go on easily, come off readily (if you want them to), don't interfere with the levers (there's a stiffening rib), and there's no problem getting hands in and out.
There's a tiny issue with not being able to see the controls, but a ride or two takes care of that. Numb fingers are much worse.
PostPosted: 02:20 - 29 Nov 2013    Post subject: Reply with quote
Another vote for Tucano Urbano muffs. I ride all year round and finish work as late as 2:30am some nights when I'm bar working and spend the day out on the bike when I am CBT instructing. During that really cold spell the other week I put a thermal set of inner gloves inside my summer gloves and my hands were cosy. Takes a few minutes for the bars to warm up with your body hand heat but when they do you dont feel the cold.
They work so well the boss instructor got himself a pair for his bike.
ViniH
PostPosted: 03:15 - 29 Nov 2013    Post subject: Reply with quote
Thanks for the advice so far, I am now leaning quite heavily in the Tucano direction.
Is there a specific model or whatever that I should be looking for or will a shopping search for "Turcano Urbano" yield the correct set for my Divvy?
P.S. Don't you think Turcano Urbano sounds like a spell from Harry Potter?
EDIT: I found this:
https://tucanourbano.co.uk/wp-content/uploads/2013/05/Hand-grip-covers-compatibility-list_04_01_13.pdf
So, Nylon or Neo-prene?
EDIT 2: I've ordered the Nylon ones. Yes I am impatient (also I want them on Saturday ideally).
Mark65
PostPosted: 09:43 - 29 Nov 2013    Post subject: Reply with quote
Tucano muffs = win
Trust me Ive just been through this, my muffs cover everything,takes a ride or two to get used to them, I can take handout and wipe visor and back in no problems. And no numb fingertips any more and thats with thin summer gloves. I have the nylon ones for mirrors and bar ends, call Palmers motorcycle shop, they had them to me in less than 30 hours from ordering.
Mark
PostPosted: 09:49 - 29 Nov 2013    Post subject: Reply with quote
Hate the look of the nylon ones, if you are going to look like a bell end, might as well do it in style with neoprene Laughing
PostPosted: 10:48 - 29 Nov 2013    Post subject: Reply with quote
Agreed.
Takes a second to realise you can no longer use the passing light that you never really used anyways. Couple of minutes to get used to using the buttons but best thing I have bought so far for the bike.
James83
PostPosted: 11:04 - 29 Nov 2013    Post subject: Reply with quote
+1 on the Tucano muffs. Its the wind chill factor - winter gloves can keep it at bay for a period of time, depending on the gloves, but the wind chill will get through any glove eventually. Because the muffs don't touch your hands, it simply removes wind chill from the equation. After that, as long as your gloves are warm enough for the ambient air temperature, your good all day long.
Oh, and as others have said, don't cheap out on the basic muffs if you ever plan to ride at more than *mumblemumble* mph. Even the Tucanos begin to press inwards at 110+*
*As tested on a private road, under controlled conditions, with expert supervision, while wearing a high vis jacket. By someone who wasn't me. Honest.
PostPosted: 11:08 - 29 Nov 2013    Post subject: Reply with quote
What ones? I've had the neoprene ones up to... over 170 I guess and they stayed solid.
Bendy
Mrs Sensible
PostPosted: 11:25 - 29 Nov 2013    Post subject: Reply with quote
I've got the muffs but still need the heated grips as well.
But then I'm currently sitting at my desk with the heating on and wearing 2 fleeces. Laughing
James83
PostPosted: 11:31 - 29 Nov 2013    Post subject: Reply with quote
I've got the Neoprene ones as well, with the plastic insert. Wonder if I've mounted them wrong somehow? Will have to have a look later.
PostPosted: 13:12 - 29 Nov 2013    Post subject: Re: Cold Weather Riding: Muffs vs Heated Grips vs Winter Glo Reply with quote
I really don't like the 'can't get my hands out quickly' feeling with muffs. It's probably in my head but I don't like using them.
PostPosted: 13:23 - 29 Nov 2013    Post subject: Re: Cold Weather Riding: Muffs vs Heated Grips vs Winter Glo Reply with quote
I have handguards and grips and gloves and my hands are fine.
Walloper
PostPosted: 13:46 - 29 Nov 2013    Post subject: Reply with quote
If you're not au fait with electrickery look at kies heated gloves. And you'll be fine.
As for winter gloves not lasting. You need to find better mates. Smile
I have winter gloves I've used since 2009 every winter and still purfik.
I wear long sleeves thin woollen jumper. (Or a fancy Tech Base-layer).
Grips are not such a difficult thing to fit and there are good tips on this forum for how-to-do.
PostPosted: 13:47 - 29 Nov 2013    Post subject: Re: Cold Weather Riding: Muffs vs Heated Grips vs Winter Glo Reply with quote
You get used to it.
Getting your hand out is never really a problem - when I'd be riding with them daily for a while I could generally also get my hands back in.
Only time I had trouble I had pulled both hands out to put my mirrors back out (after tight filtering) and a taxi pulled out - queue me missing both and holding on top of the bars for a second.
Of course, if I'd just taken hands out one at a time, I'd have been fine.
No problem using passing light with the nylon ones.
Oxford ones around chunky dirt bike bash guards don't restrict you at all - I use this off roading where you tend to move around a lot more on the bike (standing up, weight forward/back etc.)
Flatbadger
PostPosted: 13:50 - 29 Nov 2013    Post subject: Reply with quote
I keep my fingers warm by contributing to all the 'cold hands' threads on here at this time of year..
Other than that, vintage lobsters off ebay for £15, a pair of normal wool gloves under those, and I'm sorted.
You're in ISIS
Matt B
PostPosted: 18:35 - 29 Nov 2013    Post subject: Reply with quote
You can even make your own muffs...
https://i45.tinypic.com/3495lc7.jpg
All very fetching and very Blue Peter. Full instructions here: https://www.bikechatforums.com/viewtopic.php?t=255922
27cows
PostPosted: 23:02 - 29 Nov 2013    Post subject: Reply with quote
Nice bit of muff is the only way to go, ideally with winter gloves and thermal inners underneath for the particularly bitter days.
mgh0
PostPosted: 22:14 - 01 Dec 2013    Post subject: Reply with quote
Anyone know where I can get an extra stiffening rib for the muffs? Managed to break one, Tucano Urbano just sent me a link to the bits you cable tie onto the grips, not the rib itself.
"Courage is not defined by those who fought and did not fall, it is defined by those who fell and rose to fight again." Adrienne Rich.
Benno
PostPosted: 22:57 - 01 Dec 2013    Post subject: Reply with quote
Heated grips can be very nice in somewhat cold weather - weather in which you are comfortable when not riding (and uncomfortable when riding due to wind chill).
In weather that is cold even if you are not riding, heated grips will only keep the insides of your hands [slightly] warm[er]. Your fingertips will still lose all feeling and your thumb tips will feel like blocks of ice.
I have heated grips and fairly decent winter gloves, and still sometimes on the colder nights my hands get absolutely frozen. It's the wind that does it.
Muffs are probably the best item for keeping your hands warm. It's the wind that really does it. With muffs and a normal pair of winder gloves you will never want for any fancy electronics or technology again Very Happy
But if you do, make sure you get some that go off when the ignition goes off...because one day when you go for a ride way out onto the moors, and you stop somewhere remote to admire the view...you will end up spending a very long time admiring that view. Even after the rain comes.
bikersupermot...
PostPosted: 01:56 - 02 Dec 2013    Post subject: Reply with quote
What's sitting right next to & against your hands fingers & skin?
Yes the glove! So heat the glove, not the handgrips! Get heated gloves! Iv got the keis ones and even at lowest setting other night I'd to turn them off for a while I was too warm!
tinybikes
The last post was made 12 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 137.93 Kb
