| ViniH |
 ViniH Nitrous Nuisance
 Posted: 00:30 - 29 Nov 2013 Post subject: Cold Weather Riding: Muffs vs Heated Grips vs Winter Gloves |
New biker here having passed my mod 2 last week, and having only 120 solo miles under my belt thus far (accrued in a return commute from Cardiff to Bath Spa - but I did almost all of my learning in extremely bad weather (high wind, heavy rain, etc)).
I have a question with regard to the only part of me that seems to get cold, my fingers.
I've done quite a bit of reading online, including reviews and forum threads, and I can't seem to really decide on the best method of avoiding the pain of really cold fingers on longer high-speed rides.
So I thought I would ask for some advice, in the hopes that the collective experience here will aid me in making a decision.
I currently ride a Divvy, more specifically a 2001 Yamaha XJ600N. My current weekly "routine" includes a once a week commute from Cardiff to Bath Spa, and a weekend ride for several hours. I intend to do this all winter, in all weather, with the possible exception of heavy snow. I am also intending to ride from Cardiff to Preston, a journey of a little over 200 miles, in mid December.
Generally I do not feel the cold, and while riding this is no exception, quite often I am too warm, however after about 40 minutes at 60mph+ I notice that my fingers, especially my fingertips, are very cold and it can get painful.
So my questions relate to methods of avoiding cold fingers, specifically whether I should invest in a good pair of winter gloves, handlebar muffs, heated grips, or some combination of these. My budget is approximately £100, although this is not set in stone.
Winter Gloves
The research I have done seems to indicate that you can buy a good set of winter gloves for under £100.
I am basing this primarily from Visor Down reviews (and the user comments), specifically:
>£100 - https://www.visordown.com/product-features/tested-sub-100-all-weather-gloves/21734-7.html
and
>£60 - https://www.visordown.com/product-features/tested-sub-60-all-weather-gloves/22259-7.html
But my friends who ride have all advised me that gloves tend to wear out reasonably quickly, so this is likely to be the least cost-effective solution to my problem.
Heated Grips
I have very little technical expertise with either electronics or mechanics, and I would feel very uncomfortable wiring up a set of heated grips myself, therefore the only reasonable scenario would be for me to buy a set and have a garage fit them for me, presumably at the extra cost of about £50.
My research has told me that heated grips have very limited effectiveness for my riding situation, and that they often keep the hands warm but not the fingers/fingertips - although it seems that a combination of heated grips and muffs are very effective.
In addition I am concerned that the extra power drain might be a little much for my old bike, especially given that the lights will be on almost all the time during the winter.
Handlebar Muffs
Although I cannot imagine handlebar muffs will do anything to improve my image, these are the direction in which I am currently leaning. They seem to be pretty cost effective and in theory could be transferred from bike to bike, and are unlikely to suffer wear issues like gloves. I have been reading quite a lot about them and my main considerations are the fitting (I don't much fancy anything that involves a Stanley knife and super glue), the possibility of interference with levers/instruments, and getting my hands in and out of them safely while riding.
Also, the ones I was looking at, based on reviews, were the Oxford "Bone Dry" muffs - although various forum posts recommend the Tucano Urbano which are apparently easier to fit, however some posts suggest these latter are only really suitable for scooters.
So I'm really looking for some advice on the above, and would welcome your thoughts and comments on this, it is entirely likely that I will make my decision based on the discussion in this thread, so please share any experiences you have with any of these methods (or indeed some other method I haven't yet considered). |
| haroman666 |
 haroman666 World Chat Champion
 Posted: 00:34 - 29 Nov 2013 Post subject: |
Winter gloves + Bar muffs = barely chilly fingers.
I use lobster-style gloves which cost me about £30.
Bar muffs are Oxford ones which cost me around £25 on Ebay.
Job's a good'n'.
EDIT: To be slightly more helpful here's links to what I have:
Gloves
Bar Muffs
I will say though; having a faired bike has made a massive difference to how warm I am. ____________________ The mistresses: 2000 Honda CBR600f, 2000 Honda VTR1000 |
| lozzypop1 |
 lozzypop1 Certified MILF!
| G |
 G The Voice of Reason
 Posted: 00:58 - 29 Nov 2013 Post subject: Re: Cold Weather Riding: Muffs vs Heated Grips vs Winter Glo |
| ViniH wrote: |
Noooonooo, nooo.
Well, oxford ones are 'ok' if you don't go over 40 and don't mind a bit of a draft etc.
Tuccano are THE muffs (no, I don't have shares in them, but maybe I should.)
They clip on to the bar ends so don't push back against the bars.
They do bigger ones fine for 'normal' bikes.
If you don't use the cable ties to hold them on, it takes about 20 seconds to get them off or put them on. So easy to take off if someone else wants to ride your bike and doesn't like them etc.
I would go for the muffs first.
I never bothered to fit the heated grips on my GSXR, but both does add that bit more.
Heated grips alone tend to overheat the middle of your hands, but the outsides are chilled by the wind. Decent muffs remove that.
On my KTM I could be sitting at 70mph on the motorway with soaking hands in mx gloves from greenlaning but not have a problem with the oxford muffs (around enduro bash guards, which solves some of their problems) and symtech heated grips.
The symtec heating element goes under your normal grips and is very thin, so doesn't noticeably increase the size of the grips.
I wouldn't mind some heated gloves, but most of the time prefer the convenience of the above setup - which if you've got it wired in to a relay for the grips, means no extra fiddling at all. |
| Polarbear |
 Polarbear Super Spammer
 Posted: 02:05 - 29 Nov 2013 Post subject: |
Heated grips and and lobster gloves  ____________________ Victory Cross Country American tractor. |
| Rogerborg |
 Rogerborg nimbA
 Posted: 02:15 - 29 Nov 2013 Post subject: Re: Cold Weather Riding: Muffs vs Heated Grips vs Winter Glo |
| Polarbear wrote: | Heated grips and and lobster gloves  |
...are good, but muffs and either grips or warm gloves (which will be dry gloves) are better.
| ViniH wrote: | I have been reading quite a lot about [muffs] and my main considerations are the fitting (I don't much fancy anything that involves a Stanley knife and super glue), the possibility of interference with levers/instruments, and getting my hands in and out of them safely while riding. |
Mostly non issues, at least with Tucano Urbanos. They go on easily, come off readily (if you want them to), don't interfere with the levers (there's a stiffening rib), and there's no problem getting hands in and out.
There's a tiny issue with not being able to see the controls, but a ride or two takes care of that. Numb fingers are much worse. ____________________ Biking is 1/20th as dangerous as horse riding.
| pinkyfloyd |
 pinkyfloyd Super Spammer
| ViniH |
 Posted: 03:15 - 29 Nov 2013 Post subject: |
Thanks for the advice so far, I am now leaning quite heavily in the Tucano direction.
Is there a specific model or whatever that I should be looking for or will a shopping search for "Turcano Urbano" yield the correct set for my Divvy?
P.S. Don't you think Turcano Urbano sounds like a spell from Harry Potter?
EDIT: I found this:
https://tucanourbano.co.uk/wp-content/uploads/2013/05/Hand-grip-covers-compatibility-list_04_01_13.pdf
So, Nylon or Neo-prene?
EDIT 2: I've ordered the Nylon ones. Yes I am impatient (also I want them on Saturday ideally). |
| Mark65 |
 Mark65 World Chat Champion
 Posted: 09:43 - 29 Nov 2013 Post subject: |
Tucano muffs = win
Trust me Ive just been through this, my muffs cover everything,takes a ride or two to get used to them, I can take handout and wipe visor and back in no problems. And no numb fingertips any more and thats with thin summer gloves. I have the nylon ones for mirrors and bar ends, call Palmers motorcycle shop, they had them to me in less than 30 hours from ordering.
Mark ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
| P.addy |
 P.addy Red Rocket
 Posted: 09:49 - 29 Nov 2013 Post subject: |
Hate the look of the nylon ones, if you are going to look like a bell end, might as well do it in style with neoprene  |
| pinkyfloyd |
| James83 |
 James83 Crazy Courier
 Posted: 11:04 - 29 Nov 2013 Post subject: |
+1 on the Tucano muffs. Its the wind chill factor - winter gloves can keep it at bay for a period of time, depending on the gloves, but the wind chill will get through any glove eventually. Because the muffs don't touch your hands, it simply removes wind chill from the equation. After that, as long as your gloves are warm enough for the ambient air temperature, your good all day long.
Oh, and as others have said, don't cheap out on the basic muffs if you ever plan to ride at more than *mumblemumble* mph. Even the Tucanos begin to press inwards at 110+*
*As tested on a private road, under controlled conditions, with expert supervision, while wearing a high vis jacket. By someone who wasn't me. Honest. |
| P.addy |
 P.addy Red Rocket
| Bendy |
 Bendy Mrs Sensible
 Posted: 11:25 - 29 Nov 2013 Post subject: |
I've got the muffs but still need the heated grips as well.
But then I'm currently sitting at my desk with the heating on and wearing 2 fleeces.  |
| James83 |
| Polarbear |
| chris-red |
| Walloper |
 Walloper Super Spammer
 Posted: 13:46 - 29 Nov 2013 Post subject: |
If you're not au fait with electrickery look at kies heated gloves. And you'll be fine.
As for winter gloves not lasting. You need to find better mates.
I have winter gloves I've used since 2009 every winter and still purfik.
I wear long sleeves thin woollen jumper. (Or a fancy Tech Base-layer).
Grips are not such a difficult thing to fit and there are good tips on this forum for how-to-do. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| G |
| Flatbadger |
 Flatbadger World Chat Champion
| Matt B |
 Matt B World Chat Champion
| 27cows |
 27cows World Chat Champion
| mgh0 |
 mgh0 Scooby Slapper
| Benno |
 Benno World Chat Champion
 Posted: 22:57 - 01 Dec 2013 Post subject: |
Heated grips can be very nice in somewhat cold weather - weather in which you are comfortable when not riding (and uncomfortable when riding due to wind chill).
In weather that is cold even if you are not riding, heated grips will only keep the insides of your hands [slightly] warm[er]. Your fingertips will still lose all feeling and your thumb tips will feel like blocks of ice.
I have heated grips and fairly decent winter gloves, and still sometimes on the colder nights my hands get absolutely frozen. It's the wind that does it.
Muffs are probably the best item for keeping your hands warm. It's the wind that really does it. With muffs and a normal pair of winder gloves you will never want for any fancy electronics or technology again
But if you do, make sure you get some that go off when the ignition goes off...because one day when you go for a ride way out onto the moors, and you stop somewhere remote to admire the view...you will end up spending a very long time admiring that view. Even after the rain comes. ____________________ I'm autistic. That means I'm smarter than you. |
| bikersupermot... |
 bikersupermot... Could Be A Chat Bot
 Posted: 01:56 - 02 Dec 2013 Post subject: |
| Benno wrote: | Heated grips can be very nice in somewhat cold weather - weather in which you are comfortable when not riding (and uncomfortable when riding due to wind chill).
But if you do, make sure you get some that go off when the ignition goes off...because one day when you go for a ride way out onto the moors, and you stop somewhere remote to admire the view...you will end up spending a very long time admiring that view. Even after the rain comes. |
What's sitting right next to & against your hands fingers & skin?
Yes the glove! So heat the glove, not the handgrips! Get heated gloves! Iv got the keis ones and even at lowest setting other night I'd to turn them off for a while I was too warm! ____________________ tinybikes |
The last post was made 12 years, 324 days ago. Instead of replying here, would creating a new thread be more useful? |
