MTX popping banging crackling
MattWadz
PostPosted: 20:42 - 09 Dec 2013    Post subject: MTX popping banging crackling Reply with quote
So my MTX hasnt been running right since i bought it, it seems to accelerate well but unless its at full throttle it seems to be crackling and popping like a 4 stroke fast idle sort of thing? im sure i heard someone tell me its 4 stroking or something? it seems to pull hard and fast at full revs but very spluttery and rough at anything less than full throttle? :S
Its difficult to get the bike to idle, and the idle screw is pretty much all the way in, the mixture screw is wound all the way in (Rich) and the circlip on the carb slide is on the bottom notch (More fuel). if i try and lean it out a bit, it takes ages to start and i have to bump it, asif the fuel is taking ages to get through? i have tried multiple spark plugs.
The reason it is like this im assuming is because it has had a new expansion chamber, a new end can, the snorkel has been removed and the airbox has been drilled.
if anyone could explain to me why this is and what i should do?
i would be extremely pleased!
thanks for reading!
Pitbike x2, Mini Moto x4, China Quad, 02' Suzuki AP50 > 03' MBK Nitro > 86' Suzuki GP100 > 02' Yamaha Jog R > 57' Honda Lead 100 > 95' Piaggio ZIP Rst 50 > 51' Suzuki TS50x > 83' Honda CB125TDE Twin > 51' Yamaha Aerox > 98' Kawasaki KX60 > 89' Yamaha DT50MX > 80's Honda QR50 > 05' CG clone > 125cc China Pitbike > 91' Honda MTX125 RW-L > 09' Peugeot Speedfight 2 LC LR > Lucky MX 140cc > Apache Tomahawk 50 Quad (current = 2010 Yamaha WR125R
Nobby the Bastard
Harley Gaydar
PostPosted: 20:47 - 09 Dec 2013    Post subject: Reply with quote
Why the hell did you drill holes in the airbox?
It always amazes me when people feel that they can do a better job of the intake side of the combustion than the original manufacturer.
Triumph Sprint ST 1050
69chris
PostPosted: 20:53 - 09 Dec 2013    Post subject: Reply with quote
Nobby the chihuahua wrote:
stuff
aint un-common to drill the airbox, just usually with a re-jet along with performance exhausts
Nobby the Bastard
Harley Gaydar
PostPosted: 21:14 - 09 Dec 2013    Post subject: Reply with quote
I take it that the re-jet is done whilst using a dynameter to check the results?
69chris
PostPosted: 21:21 - 09 Dec 2013    Post subject: Reply with quote
i guess some do and some dont, people used to manage ok before dynos were common place Wink
regardless, what i meant was its not an un-common mod, bigger carb/jets and performance exhausts would be pretty much wasted if you cant get more air in in the 1st place
but, going back to the op post, im assuming it hasnt been re-jetted, just adjusted to try to compensate......which prob wont be very healthy for his piston Thumbs Up
MattWadz
PostPosted: 07:29 - 10 Dec 2013    Post subject: Reply with quote
i didnt personally drill the holes, whoever had it before me has done so!
okay so definetly upjet? just the main jet or pilot/idle jets aswell?
thanks
Nobby the Bastard
Harley Gaydar
PostPosted: 18:14 - 10 Dec 2013    Post subject: Reply with quote
No idea. Everyone else would just be guessing as well.
MattWadz
PostPosted: 19:14 - 10 Dec 2013    Post subject: Reply with quote
alright il try a new main jet tommorow and post back, probably post a video up if it still isnt sorted out Thumbs Up
Suntan Sid
PostPosted: 23:56 - 10 Dec 2013    Post subject: Reply with quote
You could try taping over the holes, drilled in the air box, and see if it makes any difference!
MattWadz
PostPosted: 00:29 - 11 Dec 2013    Post subject: Reply with quote
ive tried blocking them up already and its just quieter doesnt really run any differently :/
gbrand42
PostPosted: 00:47 - 11 Dec 2013    Post subject: Reply with quote
What colour is the plug? Have you done a plug chop?
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
The last post was made 12 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.88 - MySQL Queries: 14 - Page Size: 68.94 Kb
