| Leem123 |
 Leem123 Two Stroke Sniffer
| Kickstart |
 Kickstart The Oracle
 Posted: 21:48 - 04 Jan 2014 Post subject: |
The bike shouldn't care about what gear it is in as far as the power valve goes. They can stick and fail to open, but I suspect you have cleaned it up thoroughly and I would normally expect that if it managed to open once it would manage it again immediately afterwards.
The valve control unit gets its rpm signal from one of the charging wires (ie, the AC wires from the stator to the regulator / rectifier unit).
Can you check if the valve is really not opening?
My guess would be that the valve is opening but is in place upside down, so not giving you full power (seen dealers do this, probably because the valve goes with the curve the opposite way up to the blanking plate).
| Leem123 |
| Kickstart |
 Posted: 22:16 - 04 Jan 2014 Post subject: |
Sounds like you now have the valve the right way up (ie, the chamfered bit should be horizontal when in place).
The valve should open at just under 8000rpm. The power should pick up quickly at this point and it should rapidly rev to 11k. It only tries to open the valve for a short while (you will notice at night that the light dims a touch for a second or 2 while the valve tries to open, then brightens again whether the valve opened immediately or has still not opened)
If the valve is plane not opening you can check the cable while revving the engine hard while not moving (once the engine is warm).
As you use higher gears it will take longer to get from 8000rpm to 11000rpm (ie, in 1st that is from about 24mph to 40mph, in 2nd it is from about 35mph to 57mph). But it shouldn't instantly go from 8k to 11k (unless the clutch is slipping).
| Leem123 |
| Leem123 |
| Kickstart |
 Posted: 22:28 - 04 Jan 2014 Post subject: |
Exhaust could be full of crap, but difficult to know and not the first thing I would suspect (and it it were that blocked up I suspect getting the valve blanking plate out would have been a hideously difficult job).
A leaking exhaust (including around the power valve gasket) might lose you a bit of power.
It is difficult to say much else. However the first thing to check with any RS125 is the compression.
| Leem123 |
| Kickstart |
| Leem123 |
| Kickstart |
| Leem123 |
| Kickstart |
| Leem123 |
| Leem123 |
| Kickstart |
 Posted: 19:02 - 05 Jan 2014 Post subject: |
The power valve working won't have much effect on low down power (depends on the blanking plates, early ones limited the bikes to 12hp and covered a bit more of the port - suspect you might gain 1~3hp at ~7500rpm fitting a power valve on those), where it will have a dramatic effect is after the power valve opens (above ~8000rpm).
Will the bike rev beyond 8k, even if making poor power, or does it refuse to go over that? Is the valve opening? Is it open at low revs (it should be open under 2500rpm)?
| bikersupermot... |
 bikersupermot... Could Be A Chat Bot
| Leem123 |
| Leem123 |
| Kickstart |
 Posted: 20:03 - 05 Jan 2014 Post subject: |
The valve should be open (so the solenoid should be pulling the cable to lift the valve) up to 2500rpm, then closed (solenoid relaxed, no tension on the cable) up to around 8000rpm (think 7750 on a standard RS125, but Aprilia used slightly different control units on different models to open the valve at slightly different rpm, and possible one of those is fitted - exact rpm is probably written on the control unit in white paint) when it opens again.
Reason it is open at low revs is so that when bimbling around town the valve gets regularly opened and closed, hopefully stopping it from getting stuck.
| Leem123 |
| Kickstart |
| Leem123 |
| Kickstart |
 Posted: 20:18 - 05 Jan 2014 Post subject: |
Wouldn't think so. Although you have just made me think.
The solenoid allows more power to open the valve than it does to keep the valve open (as I described in more detail in an earlier post). I suppose it is technically possible that if the spring is stronger than standard it could open the valve initially but fail to allow enough power to keep it open.
However this should be obvious at idle.
| Leem123 |
The last post was made 12 years, 318 days ago. Instead of replying here, would creating a new thread be more useful? |
