Shuddering front V brake
Yosh
PostPosted: 09:48 - 07 Jan 2014    Post subject: Shuddering front V brake Reply with quote
At the age of 25 my girlfriend can still not ride a push bike. If I'm ever to get her on a motorbike she is going to need to feel comfortable on a pushbike. I've been taking her out and she has been picking it up but is still very nervous on any kind of corner or hill.
She complains about the front V brake causes the front end to shudder quite a lot which her terrified when ever she needs to brake and is quite frankly hilarious. Any ideas what this might be or how to fix it.
PostPosted: 11:26 - 07 Jan 2014    Post subject: Reply with quote
First thing I'd check is for any signs of play in the headset bearings or wheel bearings and take action to remove it.
So stand astride the bike, hold the front brake fully on and push the handlebars back and forth. Any looseness or clunking and you probably need to tighten or replace the head bearings.
Get hold of the front wheel at either side of the rim and try to rock it from side to side with the steering held still. Look for any looseness or movement around the axle. Again, tighten/replace bearings if necessary.
If those are all ok, have a look at the brakes themselves. Check for play where they attach to the posts on the front fork. If there is play here, you MIGHT be able to tighten them up but they could just be worn and need replacing. A basic set of v-brakes are not expensive to buy.
Have a look at the pads. Are they in the right way round and fitted on the correct side because they are directional AND handed (usually have an arrow on them and an R/L mark but the longer end points towards the rear of the bike). The pads themselves also sit on a cup, it is possible to alter the angle at which they strike the rim by loosening the bolt slightly and re-angling it. I would have the rear edge of the pad touching marginally before the front edge.
It would be a mistake to assume the bike shop put the pads in the right way round, especially if it was Halfords. In fact, if it has suspension forks, it would be a mistake to assume they put the whole front end in the right way round.
If all else fails and checks out ok, replace the pads, they might just be shit. If they are the ones the bike came with, they ARE shit, bikes universally come with shit brake pads fitted from new. I personally like clark triple compound pads when I can find them.
https://www.wigglestatic.com/images/clarks-cps513-med.jpg
Yosh
PostPosted: 15:52 - 07 Jan 2014    Post subject: Reply with quote
Thanks Stink will check it out. Thumbs Up
Tungtvann
PostPosted: 16:21 - 07 Jan 2014    Post subject: Reply with quote
Brakes are sticking, grease them up a bit and they should stop doing that.
UnknownStuntm...
PostPosted: 17:31 - 07 Jan 2014    Post subject: Reply with quote
^^ Jesus is weeping for your soul. Yosh - don't do this.
It could be the angle the pads hit the rims. When they're set up properly, the forward edge of the V brake pads should hit the rim first, about a millimetre before the back edge hits.
Yosh
PostPosted: 09:19 - 08 Jan 2014    Post subject: Reply with quote
Although there is a deep dark part of me, in the pit of my soul that says that this idea would be worth the abuse I'd get afterward for the youtube revenue alone. There is another part, a part that holds me back, a part of me that doesn't want to sleep on the coach.
sickpup
Old Timer
PostPosted: 11:24 - 11 Jan 2014    Post subject: Reply with quote
Sounds like the pads need some toe in which helps with self servo action. If the pads toe out they tend to cause a reverberation through the frame as they catch and release continuously.
There also tend to be compatibility problems between most pad materials and steel rims which could also cause the problem.
The last post was made 11 years, 200 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.53 - MySQL Queries: 13 - Page Size: 52.23 Kb
