HELP ER6 - Re-Assembling Forks
wots
PostPosted: 12:25 - 11 Jan 2014    Post subject: HELP ER6 - Re-Assembling Forks Reply with quote
HELP, been trying to re-assemble my forks, but something isn't right.
I slide the damper rod down into the stanchion, then keep it held upside down with a broom handle. Add the silly white cap and insert into the fork lower. I loosely tighten the bolt and slide the stanchion, it moves once then sticks. Take it apart again and the plastic bit is keeping the damper rod in the stanchion where I've labeled in yellow.
I did my NTV forks without issue, what have I done wrong here? I've looked at service manual and even videos, found one on youtube https://www.youtube.com/watch?v=Cs5LnzjHll4 yet I can't see what I'm doing wrong as it kind of skips that bit.
sickpup
Old Timer
PostPosted: 13:11 - 11 Jan 2014    Post subject: Reply with quote
I don't understand your description but you seem to be making an easy job hard.
Drop the damper into the fork leg and place the plastic cap over the end, put the whole lot into the lower. Using a long allen socket place the bolt on it and the copper washer on the bolt. holding the fork leg the right way up insert the bolt and do it up two or three turns.
Fit the top bush and the seal, insert the spring and fit the fork top loosely. Invert and do the damper rod bolt up with a windy gun, remove fork top, add oil, replace fork top and done.
Yes it really is that easy.
wots
PostPosted: 13:30 - 11 Jan 2014    Post subject: Reply with quote
That's exactly how I did it the first time, in fact how I did the NTV's. The only reason I inverted things was following the video just to try it. The damper rod just sticks inside the stanchion so you can't 'knock' the seal/shim in. I use the del-boy method with 2 halves of plastic pipe and a jubilee clip and then knock it in. That plastic bit on the end of the damper rod, jams into the bottom of the stanchion. Then the stanchion no longer slides.
It took me about 20 minutes to re-assemble both NTV ones and they are very similar.
sickpup
Old Timer
PostPosted: 13:40 - 11 Jan 2014    Post subject: Reply with quote
If you push the chrome stanchion hard down into the lower it will jam solid.
wots
PostPosted: 14:21 - 11 Jan 2014    Post subject: Reply with quote
Agreed, however it was jamming just by the pressure of the stanchion dropping. Continued and spring pressure prevents that when the cap goes on. Pulling hard on the stanchion upwards releases it. Strange but there you go. Will just have to be careful when filling with oil. Thanks anyway.
EDIT: All back on the bike, but running out of daylight, will set the forks up tomorrow and see how it all is. Bike has pulled a hissy fit and decided it doesn't want to start too.
The last post was made 12 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.21 - MySQL Queries: 14 - Page Size: 46.31 Kb
