How's my front welded sprocket looking?
Beehive Bedlam This post is not being displayed because it has a low rating (Boring). Unhide this post / all posts.
Musketeer
PostPosted: 16:16 - 11 Jan 2014    Post subject: Reply with quote
Get this one next...
https://imagizer.imageshack.us/v2/800x600q90/69/ac7a.jpg
PostPosted: 16:36 - 11 Jan 2014    Post subject: Re: How's my front welded sprocket looking? Reply with quote
MilfHunter wrote:
Will it be hard to grind off? I plan on welding another three or four on. Very Happy
Don't bother grinding it off, just weld new ones on top as needed. Whistle
Sload
PostPosted: 16:38 - 11 Jan 2014    Post subject: Reply with quote
To be honest, after your last display of nature, I will not offer any advice, neither good nor bad, you can simply learn to get on with it.
You are without doubt an idiot.
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
gavcarter
PostPosted: 17:21 - 11 Jan 2014    Post subject: Re: How's my front welded sprocket looking? Reply with quote
MilfHunter wrote:
https://oi43.tinypic.com/10emxcm.jpg
I am not and have had no issues so far this is just a check up for my own piece of mind.
How does it look? ... Will it be hard to grind off? I plan on welding another three or four on. Very Happy
I've been greasing the splines after the chain weekly wash.
Im sure it will be fine! At least until a weld gives way and the sprocket decides to snap the chain, probably giving you a nice scar on your left calf to remind you not to do it again.....
Pete.
PostPosted: 18:44 - 11 Jan 2014    Post subject: Reply with quote
It's a good example of why even though you can use weld as a retainer, you should never actually weld a sprocket to a spline.
Not to mention an example of retarded chain maintenance.
a.k.a 'Geri'
RhynoCZ
PostPosted: 19:03 - 11 Jan 2014    Post subject: Reply with quote
Why? A brand new sprocket is like 15 pounds. Confused
kerr
Yes you have been very lucky thus far.
Where is the R6?
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
gavcarter
PostPosted: 20:23 - 11 Jan 2014    Post subject: Re: How's my front welded sprocket looking? Reply with quote
MilfHunter wrote:
I do not fear death or scars you can not scare me. Crying or Very sad
Wasnt trying - just saying......
Pete.
PostPosted: 20:24 - 11 Jan 2014    Post subject: Reply with quote
But that's it - you didn't have to weld the sprocket on. You came very close to getting it right - you bolted the retainer to the sprocket, then welded the retainer to the shaft and the sprocket. What you could have done is bolted the retainer to the sprocket, welded the retainer to the shaft then removed the bolts. That would have left the sprocket secure on the spline but free to float as it should, and the welds would not all be torn apart.
a.k.a 'Geri'
Pete.
PostPosted: 20:54 - 11 Jan 2014    Post subject: Reply with quote
I don't seem to believe anything - everyone can see that the retainer WAS welded to both the shaft and the sprocket. The reason the sprocket is now floating is because the welds/retainer have failed which is the reason you don't do it.
a.k.a 'Geri'
Aff
PostPosted: 21:16 - 11 Jan 2014    Post subject: Reply with quote
Was the retainer snapped before? or has that happened after, as Pete has said above because of the lack of float.
If you got a sprocket welded on because of a damaged retainer and not because of damaged splines like I thought it must have been, you are even more retarded than I expected.
Electric Bike Project
RhynoCZ
PostPosted: 21:21 - 11 Jan 2014    Post subject: Reply with quote
How did you weld it anyway? As I remember, anything that's been lubed/soaked in oil long enough gets unweldable. Thumbs Up
331X2
PostPosted: 21:38 - 11 Jan 2014    Post subject: Reply with quote
It will weld but the contaminants will cause the weld to break, oh wait...
PostPosted: 21:40 - 11 Jan 2014    Post subject: Reply with quote
It looks lousy before, and it still looks lousy. HTH. Smile Thumbs Up
Screw Loose
PostPosted: 21:58 - 11 Jan 2014    Post subject: Reply with quote
Shocked
I would seriously not be riding around on a welded front sprocket Exclamation
They are hardly expensive, fit the damn things properly IMHO Confused
MBK Nitro 50cc -> CBF 125 <\s>
CBT: February 2012 - Full licence August 2013
Clutchy
PostPosted: 22:01 - 11 Jan 2014    Post subject: Reply with quote
Y.A.A.M.B.E
Can anyone guess what that means Rolling Eyes
Beehive Bedlam This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
Screw Loose
PostPosted: 22:12 - 11 Jan 2014    Post subject: Reply with quote
Clutchy wrote:
Y.A.A.M.B.E
I agree, he is a massive bell end Rolling Eyes
kerr
PostPosted: 22:18 - 11 Jan 2014    Post subject: Reply with quote
Op why are you here? serious question.
PostPosted: 22:20 - 11 Jan 2014    Post subject: Reply with quote
Likes the attention. Thumbs Up
Screw Loose
PostPosted: 22:23 - 11 Jan 2014    Post subject: Reply with quote
MilfHunter wrote:
What a soft cunt. I've ridden with fucked brakes and no lights. Very Happy
Shocked if riding with both brakes and lights makes me soft then I'm as soft as they come Shocked
The last post was made 12 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 135.29 Kb
