| Vincent |
 Vincent Banned
| Robby |
 Robby Dirty Old Man
| G |
 G The Voice of Reason
| Vincent |
 Vincent Banned
 Posted: 16:08 - 01 Feb 2014 Post subject: |
It sheered off at the nut - I've used loads of PlusGas for the last few days and tried two nuts but there's not enough thread to support them. I've filed two flats to get the end of the mole grips on but, for the moles to work best, I find you need to use the round part of the jaws which is too big for the stud - when I use the flat part, they just open up slightly and won't grip. I've been heating it with a propane torch but the stud isn't getting red hot. Sounds like the freeze spray might be worth a go then.
I'd like to try the "welded nut" method but don't know where I could get anyone to weld it on for me.
Gawd I hate these studs  ____________________ Space Is Deep |
| Vincent |
 Vincent Banned
| Old Git Racing |
 Old Git Racing World Chat Champion
| Vincent |
 Vincent Banned
 Posted: 17:24 - 01 Feb 2014 Post subject: |
| Clutchy |
 Clutchy World Chat Champion
 Posted: 17:33 - 01 Feb 2014 Post subject: |
Above pictures look like an interesting route to take Keep that one in the back of my mind.
Time to invest in the welder you've always wanted to buy?  ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 17:42 - 01 Feb 2014 Post subject: |
I've used the bottom one with great results.
What's best about the bottom one is all the force is acting in a circular motion around the stud, rather than at a moment from it (top one). So that way you have the least possible chance of it shearing off. Also, it will grip the whole length of the stud so it has maximum chance of coming out. You've got loads of stud you can see there, you should be able to get that out!
Don't go near a drill until you've tried a proper stud extractor as 9 times out of 10, with the proper method you'll manage to get the stud out using the stud extractor, and fuck it up using a drill.
Heat the surrounding area that's holding the stud in, either use a syringe filled with water or the spray that you've said sounds good on the stud. You want to heat the ally to make it expand and release the grip on the stud, and cool the stud to do the opposite to the stud. Ally has a higher thermal expansion rate that steel so get it all nice and hot around the stud. Try not to get any water or spray onto the ally ( which is why the syringe method works well as its easy to control where it goes).
There are some videos of the stud extractors being used on YouTube if you're not convinced, so have a look on there ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| Islander |
 Islander World Chat Champion
 Posted: 17:44 - 01 Feb 2014 Post subject: |
I have a set of the stud extractors in the middle pic - they work a treat. I've also used freeze and release - heat the surrounding area and give the stud a good blast then stick the stud extractor on quickly and all should be good.  |
| G |
| Vincent |
 Vincent Banned
| Vincent |
 Vincent Banned
| G |
| Vincent |
 Vincent Banned
| Raffles |
 Raffles World Chat Champion
| G |
| Tiff |
 Tiff Nitrous Nuisance
 Posted: 00:44 - 03 Feb 2014 Post subject: |
It looks like its a 10mm stud with an 8mm thread? If it is, the stud extractor will only grip on the part that is the size of the extractor. Can you run a die nut up the larger part, and use a larger nut on there, and a smaller nut with a washer to lock them together? Then you are putting the pressure on the larger diameter part. A good smack perfectly straight on with a hammer whilst putting anti clockwise pressure on works wonders too. ____________________ 1996 Kawasaki GPZ1100s,1996 VFR750,1980 BMW R80,1982 Kwak Z250B,1992 ZZR1100C,1996 BMW K1100LT,1994 Kwak ZZR600E,1993 BMW R1100RS,1992 ZZR 600D,1988 BMW K100LT,1998 Aprilia Pegaso 650,1994 Suzuki RF900,1991 Yamaha XJ600, 1988 Honda Dominator,1992 Kwak KMX125,1987 Yamaha RD50MX,1984 Honda MBX50.1984 Honda Superdream 125 |
| Vincent |
 Vincent Banned
| G |
| Vincent |
 Vincent Banned
| m3-paul |
 m3-paul Spanner Monkey
| anthony_r6 |
 anthony_r6 World Chat Champion
| Vincent |
 Vincent Banned
 Posted: 19:35 - 10 Feb 2014 Post subject: |
I'm going to pick a "chuck" type extractor up in the morning - I'm not holding my breath though and the drill's waiting in the wings  ____________________ Space Is Deep |
| Vincent |
 Vincent Banned
The last post was made 12 years, 258 days ago. Instead of replying here, would creating a new thread be more useful? |
