GS500 High Speed Fuel Starvation
Nipedley
PostPosted: 17:07 - 29 Mar 2014    Post subject: GS500 High Speed Fuel Starvation Reply with quote
Hi guys,
Been chasing this gremlin for a little while now - 1989 GS500e
What it does: I can accelerate up to 90mph no problem at all (and no doubt would go faster), but if I hold my speed over between 67 - 72 mph depending on how the bike is feeling that day, for more than 15 - 20 seconds, it will start to pull back (that running out of fuel feeling), start to bunny hop a bit, then slowly decelerate while the throttle makes no effect at all - just like running out of fuel. It then refuses to start until I 'PRIME' it for a while, and then we can take off. So, I presume the issue is lack of fuel
What I've done: Cleaned the carbs, twice. New float valve and seat, new fuel lines (not kinked), new fuel filter (and also ran without filter, no change). Cleaned fuel tap. Removed petcock from tank and cleaned (filter not like new but looks like it would flow fine).
I discovered as per a previous post I have large chunks of old fuel tank liner inside my fuel tank that I am unable to remove, but they shouldn't be fouling the petcock filter or flow I would seriously doubt.
So I am left with: Still dirty carbs (unlikely), faulty fuel tap? (vacuum operated), or the large chunks of old fuel tank liner are causing a problem
What do you think, or can you guys suggest anything else?
Ta very muchly
J.M.
PostPosted: 17:24 - 29 Mar 2014    Post subject: Reply with quote
Is it an older gs500? Run the bike on prime and see if the issue goes away.
If it does, fit the petcock from a newer bike - 2004 onwards.
2004 R1 & 2018 XSR900
Nipedley
PostPosted: 17:27 - 29 Mar 2014    Post subject: Reply with quote
Sorry yeah it's a 1989. Prime seems to help slightly but the problem is still there, I can maybe get an extra 5mph cruising speed though before the problem exhibits itself.
I actually bought a newer fuel tap but unfortunately it wouldn't fit onto the 1989's mounting bracket as it was fouling on other parts
J.M.
PostPosted: 17:41 - 29 Mar 2014    Post subject: Reply with quote
Could you not attempt to make a plate, such that you can mount the newer fuel tap without fouling any parts?
The issue is supposedly that at high speeds, there isn't enough vacuum to draw the fuel that the bike needs for that speed. Running on prime (as prime is gravity fed only, no control via vacuum) usually resolves these issues and makes the bike run more nicely at high speeds.
The new design of petcock (2004 onwards) was supposedly better for this. I know my 2004 GS500 didn't suffer from this at high speed.
GSTwins has multiple things on it:
https://gstwins.com/gsboard/index.php?topic=19363.0
https://gstwins.com/gsboard/index.php?topic=36958.0
temeluchus
PostPosted: 17:51 - 29 Mar 2014    Post subject: Reply with quote
Did you replace the vacuum hose going to the tap? is the vacuum hose clamped at both ends?
Nipedley
PostPosted: 18:16 - 29 Mar 2014    Post subject: Reply with quote
Yeah I also replaced the vacuum hose though the original one was airtight, it is clamped on the carb end and the tap end is on so tight it'll probably never come off again
I do suspect the fuel tap to be honest.. I opened up the old tap and cleaned it out, and it seemed to be okay, but I can't think what else it can be. Unless the tank petcock is clogged underneath the filter somehow.
I think my plan of action is: try a different tap, and take the tank petcock out again, remove the filter and blow that through with compressed air as well (I blew it through from one outlet to the other, but with the petcock itself closed)
temeluchus
PostPosted: 18:18 - 29 Mar 2014    Post subject: Reply with quote
Check the vents in the fuel cap are also clear.
Coxyzxr
PostPosted: 20:06 - 29 Mar 2014    Post subject: Re: GS500 High Speed Fuel Starvation Reply with quote
Nipedley wrote:
Hi guys,
Ta very muchly
GS500 fuel caps where a bit finnicky with allowing enough air in at high speeds, after a high speed run (safely!) try pulling over and opening the tank cap and listen for the suck sound. It could be the vent for that is blocked.
Other suspects would be as you suggest the vaccuum diaphragm, make sure it's not pinched or perished anywhere, it's a 1989 and fuel hoses/carb hoses are the things that RARELY get serviced.
**WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID !
Nipedley
PostPosted: 01:29 - 30 Mar 2014    Post subject: Reply with quote
Thank you guys Smile I read on GStwins a bit more about the vacuum part of the tap, apparently there's supposed to be some sort of check valve in there I remember mine being a bent gooey mess, so that may well be the problem
Got a NOS tap on the way that will fit, going to blow through the tank petcock with compressed air and also going to clean out the tank cap vent's - if that doesn't do it, well... I'll probably be back for more suggestions
Thanks everyone! Smile
mysterious_rider
PostPosted: 18:58 - 30 Mar 2014    Post subject: Reply with quote
i replaced the fuel lines once on my gs, made them a few extra inches long, would barely run properly. Make sure they are dead short! Or it will starve.
KAWASAKIIIII
The last post was made 12 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.9 - MySQL Queries: 14 - Page Size: 65.83 Kb
