Fuel leaking when filling up
Conzar
PostPosted: 08:33 - 09 Apr 2014    Post subject: Fuel leaking when filling up Reply with quote
Morning.
Bit of a problem with my CBR F3.
I had it restricted at the weekend (tank/carbs off)
All was fine until last night when i went to go put some fuel in and strait away i noticed fuel leaking from the bottom middle of the bike.
I took the tank off and checked pipes going to the tank and no obvious leaks there.
So the fuel is coming from the overflow or the carbs?
Anyone had this before?
Thanks Conor.
Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan
The Disapproving Brit
PostPosted: 08:40 - 09 Apr 2014    Post subject: Re: Fuel leaking when filling up Reply with quote
Either some crap has gotten in the float or whoever restricted it left something loose. Either way, they fucked it, get them to fix it.
Current Bikes: 1983 Honda VF400FD / 2003 Honda VT750 Shadow
Bike Test Passed 18/03/09, Car Test Passed 14/05/13
yen_powell
PostPosted: 08:51 - 09 Apr 2014    Post subject: Reply with quote
Just inside the filler neck you should see a hole, this connects to a rubber pipe which runs to the bottom of the bike. Its in case you overfill the fuel. If you get a bit enthusiastic and splash fuel over it you will get some appear at the bottom of your bike.
XT1200Z and a DR350 in bits
Robby
Dirty Old Man
PostPosted: 09:32 - 09 Apr 2014    Post subject: Reply with quote
You need to trace the leak by following the overflow pipe to see if it's coming from the tank or the carbs.
Tank overflow is from overfilling. Not something I have experienced, I don't think I've ever owned a bike with a working tank overflow, they tend to rust themselves closed after a few years.
Carb overflow means a sticking float. I had that problem with a CB500 a few years ago, whenever the carbs were drained the float would stick. Tended to unstick after getting a knock from the back of a screwdriver, or a short run to let the movement and vibrations free them off.
Conzar
PostPosted: 09:38 - 09 Apr 2014    Post subject: Reply with quote
Cheers Robby ill try it out when I'm home Thumbs Up
Just to add it only pisses it out when filling up not when left stood or running.
lihp
PostPosted: 09:39 - 09 Apr 2014    Post subject: Reply with quote
Are you opening the filler cap before trying to fuel?
The last post was made 12 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.51 - MySQL Queries: 14 - Page Size: 47.37 Kb
