chain lube
marc_yorks
PostPosted: 23:45 - 14 Jul 2004    Post subject: chain lube Reply with quote
hi,whats the best method and best product for keeping my chain and sprockets happy?
thanks
dibbster
PostPosted: 00:18 - 15 Jul 2004    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=27815
Should be an answer there for you.
Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's Thumbs Up
www.bikepics.com/members/dibbster
Dusty
King of the Rim
PostPosted: 03:02 - 15 Jul 2004    Post subject: Reply with quote
I apply Scot Oiler oil manually.
Probably needs to be done more often than if I used wax, but in my opinion is better than most waxs. Plus it doesn't make your wheels so dirty.
Gallery
Laura
Playboy Bunny
PostPosted: 08:58 - 15 Jul 2004    Post subject: Reply with quote
Tart.
I use new engine oil apllied with a brush Thumbs Up
Good girls ride motorcycles bad girls thrash them.
david916
PostPosted: 04:48 - 23 Jul 2004    Post subject: Reply with quote
PJ1 Blue Label Chain Lube (Optimized for O-Ring/X-Ring Chains, but can be used on Standard Chains too). It sprays on thin for ease of application and then thickens to provide an exceptionally strong film to lubricate and protect. It sticks well so there is hardly any fling. I've tried loads of chain lubes, waxes and oils on the many different bikes I've owned and in my opinion nothing comes close. Try it and I'm sure you'll like it! £6.50 for a large 13oz aerosol from www.busters-accessories.co.uk although you can also pick it up from a lot of bike dealers with accessory departments too. Very Happy
david916
PostPosted: 10:43 - 23 Jul 2004    Post subject: Reply with quote
And the best method of applying chain lube Thumbs Up Arrow
Step 1: To ensure proper adhesion clean all other oils, greases or lubes off the chain before application. Pre-use can storage should be at room temperature for best results
Step 2: Make sure engine is not running and transmission is in neutral
Step 3: Shake can well. Spin the wheel counterclockwise slowly by hand keeping fingers and clothing clear of moving parts. Apply chain lube to the lower inside “loop” of the chain on top of both edges of the side plates. Apply liberally for approximately 2 revolutions
Step 4: Wipe off excess application immediately to prevent fly-off.
marc_yorks
PostPosted: 00:09 - 25 Jul 2004    Post subject: Reply with quote
cheers Smile
Don't make me blue
The last post was made 19 years, 281 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.45 - MySQL Queries: 17 - Page Size: 55.41 Kb
