Lowering a GSXR. Bad Idea?
DSK
PostPosted: 14:42 - 22 Apr 2014    Post subject: Lowering a GSXR. Bad Idea? Reply with quote
I have a 750 SRAD, and being only 5ft 6 I have issues touching the ground and Manoeuvring it.
I've played with the pre-load and compression on the suspension, but yesterday on a bike run I stopped next to a slight dip in the road and it went over with me. I managed to hop out the way but it was embarrassing and caused a little damage.
I have avoided the option of lowering it as I thought it would
A - Look Gay
B - Ruin the handling.
So if I get -25mm dog bones for the rear shock, how much do I need to drop the forks to keep it the same geometry wise as it is now?
Do the -25mm dog bones effectively change the rear spring rate? So that I'd need to change other settings to compensate.
Or do I just call it quits with my all time favourite bike and get something more shorty orientated?
Stu
Current Bike - 1990 CBR600 FL Benetton edition.
SQL
PostPosted: 14:52 - 22 Apr 2014    Post subject: Reply with quote
Start here
https://www.bikechatforums.com/viewtopic.php?t=230544
RhynoCZ
PostPosted: 14:56 - 22 Apr 2014    Post subject: Reply with quote
Never lower a sports bike, you'll ruin it. It's designed to work as it is. Thumbs Up
Fizzer Thou
PostPosted: 16:26 - 22 Apr 2014    Post subject: Reply with quote
I have differant dog bones on my Exup 1000 and 5mm shorter ones equates to a rise of about 25mm at the backend.This gave me quicker steering and was just as stable as before.
Is there a threaded clevis on the top shock mount of your Gixer?If so,you can change the rear ride height to a degree using this.Then you can compensate by dropping the forks through the yokes by an amount not more than 10mm.
Keep a note of all of the changes made,doing one at a time until you feel comfortable.Just do not make any drastic changes.
Being 5' 6" is not short as I have seen quite a few people manage similar sport bikes in the past.
Always have a 'Plan B'
PostPosted: 16:53 - 22 Apr 2014    Post subject: Reply with quote
My mate bought a brand new GSXR and the shop lowered it 30mm as he too is a short-arse. I don't recall him complaining about any poor handling.
The -25 dogbones won't change the spring rate much if any at all and simply dropping the forks the same amount through the yokes will preserve the geometry at the expense of a couple of mm shorter wheelbase. This is a lot less than the difference between a new chain and a worn one so don't worry about that. Again, the difference between new suspension and 20k miles suspension is likely to be more.
The last post was made 12 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.63 - MySQL Queries: 14 - Page Size: 51.01 Kb
