Sluggish gt125
Dave M
PostPosted: 00:09 - 21 Apr 2014    Post subject: Sluggish gt125 Reply with quote
Hysong gt125 new carbs fitted but very slow to pick up revs after gear change.
Tank has been cleaned.
Carbs spotless.
New fuel filter.
Plugs ok.
Garage set up carbs.
Could anyone suggest where I could look next. Takes a long time to warm this bike up with choke. As soon as I twist throttle after all gear changes it stutters then kicks in and sometimes stutters dropping down into 2nd and 1st gear. Hope this makes sense. Cheers.
sickpup
Old Timer
PostPosted: 01:21 - 21 Apr 2014    Post subject: Reply with quote
Pilot air screws are incorrectly set up. Use a CO2 tester and set to 3-3.5% CO2 at idle, should be about right.
Dave M
PostPosted: 10:17 - 21 Apr 2014    Post subject: Reply with quote
Thank you I will give this a go!
Dave M
PostPosted: 11:13 - 21 Apr 2014    Post subject: Reply with quote
Seem to have a flat spot in and around 4k rev range. Could this be more of an electrical problem as someone suggested to me. One of cylinders maybe dropping out? Could it be something like this? What reading do I need when checking the coils?
Dave M
PostPosted: 11:20 - 21 Apr 2014    Post subject: Reply with quote
It's also a bugger to start.[/url]
moonzoomer
PostPosted: 21:41 - 21 Apr 2014    Post subject: Reply with quote
Check valve clearances are not too tight ( especially exhaust ), I have found the valve clearances tighten on this model rather than slacken over time so back the clearances of a tad then try to start the bike.
The last post was made 12 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.38 - MySQL Queries: 14 - Page Size: 45.19 Kb
