| simonjb |
 simonjb Nova Slayer
 Posted: 14:43 - 01 Feb 2014 Post subject: Worth changing the front sprocket on YBR 125? |
Hi there BCF, not a technical query as such, but still figure this is the place to post it.
The question is, is it worth changing the front sprocket on my YBR 125 from a 14t to a 13t as JT offer both? The calculations suggest about a 7-8% increase in torque. I haven't found a piece of road around here that's straight and flat enough without traffic to actually see if I can get it to the red line (which I doubt), so not sure what the top speed reduction will be.
Just want some opinions on whether it's worth it as I don't spent that much time on dual carriageways. ____________________ Current Bike: 2008 Yamaha YBR 125 |
| G |
 G The Voice of Reason
| The Artist |
 The Artist Super Spammer
| Rogerborg |
 Rogerborg nimbA
 Posted: 15:38 - 01 Feb 2014 Post subject: |
Give it a go, but you're unlikely to notice much difference to performance either way.
What you will notice is that your gears are closer together and you'll be changing gear more. I went to a larger front sprocket to get the opposite effect. ____________________ Biking is 1/20th as dangerous as horse riding.
| bladerunner |
 bladerunner World Chat Champion
| simonjb |
 simonjb Nova Slayer
 Posted: 13:46 - 02 Feb 2014 Post subject: |
| bladerunner wrote: | I'd be tempted to go larger on the front not smaller as if your not even getting it to 65 mph then you will benefit from less gear changes. If you want to see what it's like with the lower gearing your thinking about...ride it for a day without using top gear! If you want the extra torque then drop it down a gear....really that's it! A bigger front sprocket however will allow you to use lower revs for the same speed so possible to get extra mpg or extra few mph in downhill/ tail wind situations |
Problem is, the YBR is underpowered, even for a 125. In the majority of situations, especially up hill or with a headwind, it'll only pull off around 55; whilst the revs will be higher with a 13t, the extra torque should pull it up to around 60. Well that's the plan anyway! For the sake of ten quid, I've decided it's worth a shot. Thanks all, will post results once I've had a chance to change it.
Edit: I don't think you can get a 15t front for the YBR, it'd be too large, if I decide I need to go the other way, I can always reduce the teeth on the rear sprocket in future. ____________________ Current Bike: 2008 Yamaha YBR 125 |
| DangerousSpot |
 DangerousSpot L Plate Warrior
| janner_10 |
 janner_10 World Chat Champion
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 07:50 - 26 Apr 2014 Post subject: |
I wouldn't touch it, the engine is too small to benefit from that.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| simonjb |
 simonjb Nova Slayer
 Posted: 11:00 - 28 Apr 2014 Post subject: |
You can get them on ebay at a decent price, just make sure they are actually JT. Or you could just find other online shops.
Note from me: I tried this, and it did give me better acceleration and more torque, BUT it did noticeably reduce my top speed, and I found myself revving it higher compared to before, and hence my MPG dropped.
If you don't do any roads faster than 45 mph regularly, and you spend most time in traffic or just around town, then its worth trying out. But if you do, then its better to explore other avenues!
I've actually gone back to a 14t now, but by doing an oil change, replacing the air filter, properly cleaning and lubing the chain, and replacing the spark plug with an NGK Iridium, it's much better on the 14t.
You're better off just revving it higher by changing down a gear on hills or in headwind IMO, but I had to try it out myself first! ____________________ Current Bike: 2008 Yamaha YBR 125 |
The last post was made 12 years, 206 days ago. Instead of replying here, would creating a new thread be more useful? |
