| von1papen |
 von1papen Spanner Monkey
 Posted: 12:24 - 29 Apr 2014 Post subject: Speedometer Repair |
Hi folks,
The Speedometer on my CM200 is up the left, under-reads very badly because the back piece that the cable screws onto is loose.
Upon inspection there is no way of tightening it from the outside, I need to open the clock up, it is a standard looking black plastic round speedo that you see fitted to CB100's, early CG's etc.
There seems to be no spares on ebay and the bike's front wheel is a different size to the cb100 and cg so the speed would be off if I got a second hand speedo from one of those bikes. (How much though if anyone can clarify this?)
David Silver Spares can get a new one for £150
Is there any businesses that repair speedometers that anyone is prepared to recommend? I'm based in Northern Ireland so would have to post it.
Or can you open the speedo up? I didn't want to crack the plastic case trying to jimmy the back plate out unless this can be done?
Thanks,
Von1papen ____________________ Honda CG125<Honda CM200< Kwak GT750 (SOLD) < BMW R65 |
| Nexus Icon |
 Nexus Icon World Chat Champion
 Posted: 12:27 - 29 Apr 2014 Post subject: |
This isn't going to be a lot of help but I had a '77 CG125 many, many years ago and the speedo needle fell off the shaft. I remember opening it up and refitting the needle without any problems, so it must be doable.
I was a complete engineering dunce when I was 17 so it must be fairly easy too.  ____________________ Greetings from Shitsville! |
| Vincent |
 Vincent Banned
| Ste |
 Ste Not Work Safe
| smegballs |
 smegballs World Chat Champion
 Posted: 16:20 - 29 Apr 2014 Post subject: |
On the GN the speedo wasn't working. The cable seemed fine so I knew it was the gubbins inside the were bollocksed. As it wasn't working, "whats the worst that can happen" said I.
After taking it off the bike and pulling off the surrounds, I was left with a white plastic body that had the glass held on with a crimp. I gently levered up the crimp with a flat screwdriver working around the outside until I could gently pull it off and expose the inner workings.
The problem was caused by some sticky residue (spider jizz??) on the cup that magnetically couples (I think) to the magnet spun by the speedo cable. I cleaned it up with some meths and put a drop of machine oil on the tiny spring that returns the needle. Reassembled it and my speedo is now working. Before the strip it would get to about 20mph and then just hang there.
Maybe something similar is happening to yours? There is obviously some drag causing it to under-read. I'm confident enough now with the procedure that I took the tacho apart at the weekend to install a little voltmeter on the clock face: pic related.
https://i.imgur.com/G5nnUQx.jpg
Just go nice and steady unpeeling the crimped steel bezel and you'll be okay. |
| von1papen |
| Vincent |
 Vincent Banned
 Posted: 21:40 - 29 Apr 2014 Post subject: |
Be warned.....clock bezels, (the metal ring that's folded over the edge of the clock body), are quite easy to remove .......but not so easy to get back on properly  ____________________ Space Is Deep |
| smegballs |
| moonzoomer |
 moonzoomer World Chat Champion
 Posted: 22:15 - 29 Apr 2014 Post subject: |
| smegballs |
| von1papen |
The last post was made 12 years, 203 days ago. Instead of replying here, would creating a new thread be more useful? |
