| podmore71 |
 podmore71 Borekit Bruiser
| Teflon-Mike |
 Teflon-Mike tl;dr
| podmore71 |
| smegballs |
 smegballs World Chat Champion
| podmore71 |
| podmore71 |
 Posted: 11:35 - 20 Apr 2014 Post subject: |
Think that is a bit too big.  |
| smegballs |
 Posted: 14:32 - 20 Apr 2014 Post subject: |
If you put a "l" after the last letter in the imgur code it makes it smaller.
https://i.imgur.com/97ezaMEl.jpg
[picher]https://i.imgur.com/97ezaMEl.jpg[/picher]
Took me a while to learn how to use img codes, but they are handy once you get used to it. I think the l suffix is unique to imgur tho. |
| moonzoomer |
 moonzoomer World Chat Champion
| kramdra |
 kramdra World Chat Champion
| Kickstart |
 Kickstart The Oracle
| podmore71 |
 Posted: 10:45 - 29 Apr 2014 Post subject: |
Well boys I've managed to sort out the suspension.
I got hold of some replacement links and suspension springs from ebay, and I've got it all back together.
I've just tested the suspension and its looking good. Proper movement this time. Thank god.
The problem I have now is refitting my front break cable. No matter what I do, whenever I pull on the front break lever and release it, the front breaks don't release. If I adjust the breaks then the pads bind on the wheel.
When I took off the wheel, I pulled the break drum out by mistake. I think I put it back in correctly but I can't be sure. As far as I know
Any ideas guys
Andy |
| smegballs |
 Posted: 10:56 - 29 Apr 2014 Post subject: |
What state was the break cam shaft (pic related)in? I always give them a good wiring brushing and a little smear of grease (not too much, dont want to contaminate the shoes) to keep it all working smoothly and not binding up.
https://yambits.co.uk/images/BSP074.JPG
Want to take some pics of the wheel/cable as you've assembled to help us diagnose? |
| podmore71 |
| podmore71 |
| smegballs |
 Posted: 11:21 - 29 Apr 2014 Post subject: |
By arm do you mean this bit?
https://yambits.co.uk/images/BSP034.JPG
The star on the arm, fits the splines on the camshaft in my last pic, the whole thing needs to be free of dust and corrosion and shit to work nicely, the springs on the brake shoes should be enough to easily ping the lever back when you actuate the brakes by hand, with the wheel off and the cable disconnected.
Sounds to me like the whole thing needs a good wire brushing, and re-assembly with a little grease on the shaft. On the plus side, it doesn't really cost much to service drum brakes! Just a little elbow grease, no brake fluid or seals to much about with either! |
| podmore71 |
 Posted: 13:49 - 29 Apr 2014 Post subject: |
That's the fella.
It does need a strip down and a good clean. I'll try and get some break cleaner and copper grease some time this week. As for the bike. Well I've just finished replacing all the body panels and just took it for a very quick spin around the block. Breaks are as they were before I started (thank the gods, lol) and the suspension is, well I can only say, it feels perfect. Plenty of bounce in the front forks. The old springs seemed ok to me but considering I got another set with the links I bought off Ebay I thought I'd swap them out anyway. A hell of a lot simpler than I thought it would be. I feel so proud of myself for having a go and doing it myself. Just hope it now passes its MOT tomorrow.
Thanks everyone for the sound advice and help. Very much appreciated.
I love places like these boards. Everybody is just so dam helpful
Andy |
The last post was made 12 years, 204 days ago. Instead of replying here, would creating a new thread be more useful? |
