| tight fart |
 tight fart Derestricted Danger
| bypass2 |
 bypass2 Spanner Monkey
| smegballs |
 smegballs World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
| tight fart |
| tight fart |
| bypass2 |
| tight fart |
| tight fart |
| tight fart |
 Posted: 18:02 - 26 Apr 2014 Post subject: |
Doh! Put new plug in and it appears I don't have a good spark after all.
Not sure where to start, it would be easier with points. ____________________ www.tightfart.com |
| bypass2 |
| tight fart |
 Posted: 20:02 - 26 Apr 2014 Post subject: |
I think if the woodruff key had worn I'd have a spark but at the wrong time, faulty lead or cap maybe, not sure How to check that other than replacing, the lead I think is bonded into the coil.
I've not used it for a while but the bugger wouldn't start and I put it in the shed till I had time to look at it. ____________________ www.tightfart.com |
| Vincent |
 Vincent Banned
| tight fart |
| bypass2 |
| moonzoomer |
 moonzoomer World Chat Champion
| Vincent |
 Vincent Banned
 Posted: 07:35 - 01 May 2014 Post subject: |
| tight fart wrote: | | Vincent wrote: | IIRC, the CDI on the DT was one of the first for Yamaha and was pants, ('probably suffered damage from vibration). Might be worth looking there first. |
I've looked at it, can't see what else I can do apart from look. |
Good point....I've never used one myself, but have heard of "CDI Doctors"....in other words, you send them the CDI, and they check it over for you.
I know they had problems with the CDI because a neighbour of mine had one, (ended up leaving half his face on a chain-link fence after coming off the thing),....... and his had been converted to use the points from a same-year 250 version for that very reason.
Try googling "CDI Doctor".....or "CDI testing/repair".
The problems Yamaha had with the early Capacity Discharge ignition may have been the reason they started filling them with resin. I know the first 350 YPVS had similar problems. On the 350, owners would actually "bend" the whole unit slightly and fix a splint*
Somewhere on the interweb, there'll be a dedicated forum for your bike, populated by experts, (most likely in the US - they love their thumpers over there). I'd find it... and ask on there. You may even find a kind enthusiast willing to lend you a good CDI to test if you're lucky.
*:- True. ____________________ Space Is Deep |
| Piercee100 |
 Piercee100 Trackday Trickster
The last post was made 12 years, 201 days ago. Instead of replying here, would creating a new thread be more useful? |
