Honda VFR 800
staningrimsby
PostPosted: 18:11 - 08 Jun 2014    Post subject: Honda VFR 800 Reply with quote
Hi guys,
Looking a little into the future I know but you can't beat a bit of forward planning, I had a look at a Honda VFR 800 today and really like it, its within my budget and I really like the look of it for a bit of touring and the obvious rising round with my fello bikers.
What I would really like to know is does anyone know if there is anything specific I should look for on these bikes, are they reliable or does anyone have any experience with them good or bad ???
Cheers in advance,
Stan.
When you have removed the impossible the improbable however unlikely has to be the truth.
1986 Yamaha DT 80 >> 2009 Honda Varadero XL 125 >> 2003 Suzuki V-Strom 1000
duhawkz
PostPosted: 18:58 - 08 Jun 2014    Post subject: Reply with quote
Vtec or pre vtec
I had vtec and couldn't fault it. Aside from the usual things to look out for when buying a used bike, the only thing I can think of is to check if its had it's 16000 mile service, that's when valve clearances need checking and on the vtec its a specialist job and fairly expensive. 800+ isnt unheard of
staningrimsby
PostPosted: 19:01 - 08 Jun 2014    Post subject: Reply with quote
Not sure yet the one im looking at is a 2005 model which is right on the change but £800+ sounds expensive.
staningrimsby
PostPosted: 19:11 - 08 Jun 2014    Post subject: Reply with quote
I have just heard that every 16000 miles the head needs to be removed to check the valves are ok at a cost of around £800, don't know if its true or not.
PostPosted: 19:52 - 08 Jun 2014    Post subject: Reply with quote
How on earth can a valve clearance check require 15-20 hours of labour? You could replace a valve for less than that, so if that's genuinely what is being asked, I'd laugh it off and ride until something goes wrong. You could, quite literally, buy a bike for that money.
Compromise: rather than taking it apart, you could get a compression test done. If that's OK then the valves are closing.
staningrimsby
PostPosted: 19:54 - 08 Jun 2014    Post subject: Reply with quote
I did think it was a bit extreme but being a newbie to bike you just take the words of others who are considered more knowledgeable.
PostPosted: 21:03 - 08 Jun 2014    Post subject: Re: Honda VFR 800 Reply with quote
Vincent wrote:
'Buy mine if you like Thumbs Up
Has it had the valves checked recently? Wink
instigator
PostPosted: 21:34 - 08 Jun 2014    Post subject: Reply with quote
I understand it's because to get access to the engine, a lot of the bike needs to be removed and to do the whole process 'properly', the cams need to be removed twice. *shrug* If you get a garage that is really familiar with the process, I suspect they will be the cheapest.
Shaft
PostPosted: 22:05 - 08 Jun 2014    Post subject: Reply with quote
Seems it's not all labour, from what I've read, it's about 3 hours to check them, another 5 hours if they need adjusting, then there's the parts; looks like an absolute sod of a job.
On the other hand, anecdotal evidence suggests they rarely need adjusting before 50K, often not even then, so I guess you can pray to the god of shims and keep your eye on the price of good used engines.
PostPosted: 22:51 - 08 Jun 2014    Post subject: Reply with quote
Mmm. My analysis with the GS was that BMW Motorrad wanted £200 for a service with "valve check", but they wouldn't even discuss how much an "adjustment" would be, because "it depends".
On further investigation, that particular cower of shunts had never had a bike in that didn't "need" some amount of "adjustment", so in the event I fu​cked it off and decided to gamble that the chimps who made the engine did a better job than the monkeys who get to work on it.
Hang on, I'll be back in 5 minutes after I've done the clearances on the Enfield, and got another beer.
Shaft
PostPosted: 23:06 - 08 Jun 2014    Post subject: Reply with quote
You need to try and find a tech with a conscience.
When I was seriously considering a GS boxer, I happened upon a guy called Chris Harris on Youtube; he's a BMW trained tech and tells it like it is, eg if you've been charged for a valve clearance adjustment on a 16V K bike with sensible mileage, you've probably been ripped off.
In the OP's case, a time served Honda tech who is now doing his own thing the right way, would be most useful.
Dibble
PostPosted: 23:22 - 08 Jun 2014    Post subject: Reply with quote
I can genuinely do the valves on my Guzzi in 5 mins VFRs apparently take a bit longer.
VTECs need the clearances checked then the oil system pressurised to engage the second set of valves, then all of them checked again.
Pre VTECs are easier I'm planning to do mine this winter.
Clocks, odometers lcds etc go wrong the Giant PCB corrodes, easy to fix if you are logical, check the mileage on old MOTs cos the odometer might not have been working for a period ( Embarassed I didn't).
FiW and FiX fuel injection is a bit funny at low rpm but a jerkyness pulling away could be a slightly corroded clutch pushrod (10 minute job with some wire wool).
Dobles have a very clean FiX (1999) on 40k miles for £2499 Shocked but then the new one is £10500 and even the salesman couldn't come up with any reasons why it was £8000 better.
Yellow ones are fastest and make you feel less like an old man.
J biker
PostPosted: 23:28 - 08 Jun 2014    Post subject: Reply with quote
Buy a FZ1. Faster more comfy bike. 24k major service (valves), 6k oil, and way easier to work on. Rear shock a bit bouncy if pushed hard is only problem. Electrics and motors sound.
People seem to have a sense of humour on second hand prices for the VFR.
Dibble
PostPosted: 00:29 - 09 Jun 2014    Post subject: Reply with quote
or a Triumph sprint RS/RT or Daytona maybe with converted bars, Ducati ST2, I tried all of them.
PostPosted: 09:02 - 09 Jun 2014    Post subject: Reply with quote
The suggestion to just do a compression check came from just such a chap, in reference to a workmate's CBR600RR. He (reportedly) said he'd never worked on a modern Honda where the clearances had actually needed adjusted.
2nd hand anecdote, I hasten to add, I'm not making that claim.
staningrimsby
PostPosted: 09:07 - 09 Jun 2014    Post subject: Reply with quote
Just been looking online at the Triumph Sprint ST, seems a really nice bike and the reviews are good for it to just need to see if its a good size for me that's all.
Busa1340R
PostPosted: 09:53 - 09 Jun 2014    Post subject: Reply with quote
Not trying to put you off......I loved my 07 Sprint, however if you intend to ride at night, be warned that the (pre facelift) Sprints headlights are abysmal. The main beam switch effectively does nothing....it's like turning on a small torch with flat batteries.HID kits apparently improve greatly if you want to spend the money/can be bothered.
Something else you may want to consider is resale value. I had no interest when it came to selling mine on, even though it was immaculate with low miles and FSH and sensibly priced. Even dealers weren't really keen on PX. Buying one with pannier kit will help even if YOU don't intend to use it.
Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc
staningrimsby
PostPosted: 10:06 - 09 Jun 2014    Post subject: Reply with quote
Thanks for the info I was looking for something around 2005 I believe they changed around then, I will also want panniers etc as I plan on a bit of touring with the missus as well.
Ideally I would love the Honda Pan European 1300 ST but its a little bit out of my price range Sad .
Busa1340R
PostPosted: 10:22 - 09 Jun 2014    Post subject: Reply with quote
Not face lifted until 2010 I believe....
staningrimsby
PostPosted: 10:39 - 09 Jun 2014    Post subject: Reply with quote
I stand corrected and will look into that, thank you for the info
map
Mr Calendar
PostPosted: 12:51 - 09 Jun 2014    Post subject: Reply with quote
Rogerborg wrote:
...I'll be back in 5 minutes after I've done the clearances on the Enfield, and got another beer.
As long as that? Suggest moving fridge with beer closer to bike (or vice versa).
On topic (ish), VTEC valve stuff check/adjustment was criticised when the VTEC bike came out (yes, I'm that old I remember the press headlines). IIRC the first mileage to do them at was estimated it'd be about the same time you'd be selling if bought from new.
staningrimsby wrote:
...Ideally I would love the Honda Pan European 1300 ST but its a little bit out of my price range
A ST1100 shouldn't be though. Going a bit further back in time, but old bike does not always equal bad bike. Think cheaper insurance! Just check for rust on the swingarm and hopefully it'll have a replacement stainless exhaust collector box (downpipes stainless anyhow).
The last post was made 12 years, 21 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 129.6 Kb
