| Easy-X |
 Easy-X Super Spammer
 Posted: 19:27 - 28 Mar 2020 Post subject: 2-stroke basics |
I was gonna add this to my DT thread but I thought it might be more of a general interest topic.
DT175 (1976, 2-stroke) stock exhaust and airbox but a Mikuni VM28 carb over the factory VM24SS. Factory spec #140 main jet, needle at middle position, mixture screw about 2 turns out. New spark plug and air filter.
So far I've got it to the point where it starts and idles fine. I dunno if this is because of the recent mild weather but it starts pretty well from cold with no choke; maybe a little teasing of the throttle.
Symptoms
5 mins of riding it's fine and seems to have plenty of power. After that it seems to splutter in the midrange (>3K)
Ideas
Fuel starvation? Enough of a trickle to keep it idling it seems but not enough to get any real power. Vacuum lock tends to be a time based thing so I'll try popping the fuel cap off, see if it improves. (BTW tank, petcock and pipes are all new, carb recently cleaned.)
Running rich? This would be more noticeable when the engine's warmed up. Quick test would be to pull the air filter and see what happens.
Running lean? I would have thought I'd have a bit more trouble starting it and the reverse: rough from cold but some improvement when warm. A cheeky bit of choke might help but actually it just stalls the engine.
Weakening Spark? Any way to check this with the bike running? Old coils and stators can do funny things once warmed up and corroded contacts can suddenly jump in resistance when warm. Certainly low down on my list of things 'cos... hassle
Timing? I plead ignorance here as to whether it can affect the bike once warmed up. Contact corrosion resistance again I suppose.
Compression? Obviously metal distorts depending on temperature but I'll have to get my hands on a compression tester. Hopefully just some new piston rings required, if compression's down.
Valve Gaps? Only kidding
So that's my Sunday planned out. Anything I've missed? ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Nobby the Bastard |
 - Super Spammer
| Easy-X |
 Posted: 21:00 - 28 Mar 2020 Post subject: |
I'll probably order up a compression tester, seems like a useful thing to have anyway so I'll tag some spare plugs along with that.
I've had the case covers off a few times and they all look new and in good condition. Certainly the minor seals (kick start, oil pump) are still flexible and AFAIK they were all changed at the same time. Not seen any obvious evidence of 2-stroke oil creeping through. Gearbox pressure test is a nice easy one, thanx! Fuel is fresh from the pump BTW.
Comparing the petcock from an original tank to the new one I can't say anything jumps out of me. TBH the design looks more "free flowing" easy check if it comes to it - checking flow rates - although I'd think it'd affect both cold and hot performance if it was an issue.
I agree that the up-rated carb is a bit of a random element but I had almost zero luck with the VM24 copy I have. But then again it is one cast in pure Chinesium
Thanks guys, great suggestions  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| bypass2 |
 bypass2 Spanner Monkey
| WD Forte |
 WD Forte World Chat Champion
| Easy-X |
| Easy-X |
 - Super Spammer
 - Super Spammer
 Posted: 11:15 - 29 Mar 2020 Post subject: |
| Easy-X wrote: | | bypass2 wrote: | as said could be the bigger carb. try the mixture screw 1 turn out. choke plunger seals worn/damaged. is the oil pump set right. is the throttle slide worn/damaged. do you have pipe coming from petrol cap vent |
Would the mixture screw affect the midrange power? I thought it was just part of the idle circuit The plunger looked okay when I cleaned the carb. Oil pump has been refurbed and the starting point set, I have a clear section of pipe to verify there's flow but I haven't gone as far as calculating the flow rate yet. Throttle slide is in near perfect condition.
No one-way pipe vent on the petrol cap - it's a traditional chrome one. I would hope it incorporates some sort of venting but hey, China eh? Vacuum lock is on my list  |
If it's bogging in the mid range, it's most likely pilot and or main jet, more than likely too large for the airbox.
The problem is, with standard airbox but a bigger carb, you've really changed the mixture. It will be too rich as the draw of air will be sucking more fuel as it's easier than suicking the air from the smaller in comparison airbox.
Like I said about just removing the inner trumpet from a TZR airbox, even with the same carb, you must upjet almost 100 on the main jets and at least 2.5 on the pilot jets to adjust to the newer, slightly better flowing air. Adding a larger carb would need less restriction on the airbox to compensate. Does it have an inner trumpet or just a filter in the airbox? Try removing the filter, just be careful it doesn't lean too much.
Maybe run it on pre-mix too.
You need to plug chop it really by cutting engine whilst still revving/riding to check if it's rich. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
| Easy-X |
 Posted: 11:43 - 29 Mar 2020 Post subject: |
Yes, that makes more sense It doesn't have an inner trumpet but there is a sorta upside down funnel on the outside of the box. It raises the air inlet to the highest point possible (just under the seat) but also offers some restriction. I was planning to ride it about till it started spluttering and then just whip the side of the airbox off to see what impact that had but the funnel might be a nice, low key alternative.
So, from what you're saying, I should probably go down from the factory spec rather than up, on the main jet Switching to premix would introduce another variable, would it not? I think I'm right in saying you'd up-jet in that scenario to compensate for the slightly thicker fuel. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| steve the grease |
 steve the grease Crazy Courier
 - Super Spammer
 Posted: 21:08 - 29 Mar 2020 Post subject: |
| Easy-X wrote: | Yes, that makes more sense  It doesn't have an inner trumpet but there is a sorta upside down funnel on the outside of the box. It raises the air inlet to the highest point possible (just under the seat) but also offers some restriction. I was planning to ride it about till it started spluttering and then just whip the side of the airbox off to see what impact that had but the funnel might be a nice, low key alternative.
So, from what you're saying, I should probably go down from the factory spec rather than up, on the main jet  Switching to premix would introduce another variable, would it not? I think I'm right in saying you'd up-jet in that scenario to compensate for the slightly thicker fuel. |
Yes, you upjet on pre-mix. I only suggested it as a safe measure if we’re getting drastic with the airbox.
They’re very sensitive to slight changes in airbox or jetting. Hell my bag of main jets for the race bike went from 220 to 340, although I only really used 280-330 depending on humidity, temp and pressure.
I’d either make airflow less restrictive to match the bigger carb, such as removing the funnel, or down jet the main
To compensate for the less restrictive carb bore.
A plug chop would be useful too. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
| Nobby the Bastard |
| redeem ouzzer |
 redeem ouzzer World Chat Champion
| Easy-X |
 Posted: 18:07 - 30 Mar 2020 Post subject: |
Ummm... I haven't actually got to fiddle with the bike yet, sorry to keep you in suspense This work from home lark isn't the slack-fest I was promised  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Easy-X |
 Posted: 16:34 - 04 Apr 2020 Post subject: |
Can't really go anywhere so I waited until the wife had some bits she wanted from the shops and err... volunteered
Got to one side of the town, no problems, got my shopping, headed back home. Just when I got to within 100 yards of my house it spluttered so first test: vacuum lock. I already had the key in the cap at the ready...
Seemed to work! So I took the cap apart to take a look at how it vents:
https://i.imgur.com/opUMb9t.jpg?1
I get the whole convoluted spiral deal but it all bottlenecks through a little 1mm (if that) hole. Is that enough venting? ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
 - Super Spammer
| Easy-X |
 Posted: 02:44 - 05 Apr 2020 Post subject: |
I'll try again tomorrow if there's some need to be out and about. If not I'll wash the other bike, nice day for it they say  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| mentalboy |
 mentalboy World Chat Champion
| Easy-X |
 Posted: 13:33 - 05 Apr 2020 Post subject: |
| mentalboy wrote: | What's with the mess in the centre of the cap? I'm going to assume rough casting but it looks more like someone took a file to it.
Have you got an airline to blow in the hole to make sure there isn't swarf hidden up in there?
Edit: Has the carb float height been messed with and could it do with a new float needle? |
Loads of silicone grease, from the locking mechanism.
Just to re-iterate I can warm the engine up, ride it around for 5 to 10 mins before it splutters but no, the float height is original (as far as I can tell comparing to factory specs) float valve looks okay, no obvious damage. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Nobby the Bastard |
| mentalboy |
 - Super Spammer
| mentalboy |
 Posted: 17:43 - 05 Apr 2020 Post subject: |
I've just had a look at your DT thread, nice, is that your float needle?
https://i.imgur.com/2GRvuCh.jpg?1 ____________________ Make mine a Corona. |
The last post was made 6 years, 163 days ago. Instead of replying here, would creating a new thread be more useful? |
