Rotor Puller for 1985 Honda CB125RS
Tedwood
PostPosted: 16:44 - 11 Jun 2014    Post subject: Rotor Puller for 1985 Honda CB125RS Reply with quote
Does anyone know where I could get one or information on how to make up one?
Thanks
yen_powell
PostPosted: 17:37 - 11 Jun 2014    Post subject: Reply with quote
Try using your rear axle.
XT1200Z and a DR350 in bits
PostPosted: 17:45 - 11 Jun 2014    Post subject: Reply with quote
Rear wheel spindle won't work unless it has an M27x1.0 reverse pitch thread on it. I'm fairly confident it does not.
Try Honda part number: 079330010000
From David Silvers by post or from any high street Honda dealer if you can manage to persuade them to order you something from a part number instead of argue with you about wether you want it. Should come in at £10 -15 before they also add in sucking of teeth and unhelpful and ill-informed comments on their assumeption about the price of one.
It is the actual tool for the job and well worth a tenner.
Tedwood
PostPosted: 13:57 - 12 Jun 2014    Post subject: Reply with quote
Many thanks stinkwheel, I've ordered one from my local dealer, was very helpful! Should take 1/2 days to get in.
I've also ordered a woodruff key as the rotor has not been installed correctly ie timing marks wrong, when turned to TDC it's NOT TDC! some 40/45 degrees out!
Either some wally has fitted the rotor without the woodruff key or it's been torn out. Hopefully, the former, will find out very soon.
Thanks again
Tedwood
PostPosted: 14:21 - 21 Jun 2014    Post subject: Reply with quote
Unfortunately, the puller suggested by stinkwheel is not the one for my bike.
Found out that the Honda puller is 07933-KG2-000 (previously 07933-4300000). Dealer estimated delivery August! Searched the web and found a post on another forum by Dave Wilkins cross referencing that part number with pattern part H-Level 793628.
He's fairly close to me and he had the H-Level one in stock, so popped over and picked it up. Cost £17 and now the rotor is off at last.
For information the puller has a 28 x 1.0 internal rh thread.
davebike
PostPosted: 21:15 - 21 Jun 2014    Post subject: Reply with quote
Hi Ted
Glad it is sorted
Dave
Dave
NC750Xdct + others at work !
[email protected]
The last post was made 12 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.01 - MySQL Queries: 14 - Page Size: 49.02 Kb
