| stranger12 |
 stranger12 World Chat Champion
| Clutchy |
 Clutchy World Chat Champion
 Posted: 10:55 - 10 Jun 2014 Post subject: |
You 'SHOULD' check the oil level first of all ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
| stranger12 |
 Posted: 10:57 - 10 Jun 2014 Post subject: |
I have , not that daft  ____________________ SV650 Red
R6 Red |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 11:00 - 10 Jun 2014 Post subject: |
Oil level doesn't matter on an r6. As long as the light isn't on then you're good to go.
As always, cct ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| stranger12 |
| gavcarter |
 gavcarter Could Be A Chat Bot
| stranger12 |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| stranger12 |
| Conzar |
 Conzar World Chat Champion
| weasley |
 weasley World Chat Champion
 Posted: 12:14 - 10 Jun 2014 Post subject: |
Could be tappet tick, in which case ^^^this^^^.
Or it could be a header pipe gasket, which sounds a lot like a tappet tick. I'm told.  ____________________
Yamaha XJ600 | Yamaha YZF600R Thundercat | KTM 990 SMT | BMW F900XR TE |
| stranger12 |
| weasley |
| Snorty |
 Snorty World Chat Champion
| stranger12 |
 Posted: 11:51 - 26 Jun 2014 Post subject: |
I took the CCT out and as per haynes manual did test it .
here is a video of it .
me with finger pressure
https://tinypic.com/player.php?v=2qimyw4%3E&s=8#.U6wJAfldV8E
using screw driver
https://tinypic.com/player.php?v=rvlpxk%3E&s=8#.U6wJRfldV8E
basically haynes says to test it ,
wind it in all the way , then put your finger on it and release the pressure and it should pop out slowly .
It does pop up but in bits and jerkey motion rather than slow and smooth . I think it is because I am not keeping a constant pressure and suddenly take a lot of pressure of it so it jumps out.
if I stick the screw driver in it, wind it and unwind the screw driver it works well.
I did put some wd40 in it to clean and then put oil in it .
I thought that will not damage it as it is only a spring and pipe and that is all so no damage should be caused.
I don't want to spend £110 on cam tensioner if that is not faulty .
I can hear the sound from the exhaust area and think maybe it could be exhaust gaskets so want to change them all.
it sound like, I can hear the combustion from inside the engine translated to a ticking noise .
It is hard to explain but can't explain it any better.
Also my r6 can't idle spot on so think exhaust gas is leaking or the throttle bodies need to be synched . it idles at around 1.3 and moves by 100 side to side .
Am I correct thinking a leaky exhaust valve or throttle body sync can cause this ? ____________________ SV650 Red
R6 Red |
| lihp |
 lihp World Chat Champion
| stranger12 |
| P. |
 P. Red Rocket
| lihp |
The last post was made 11 years, 225 days ago. Instead of replying here, would creating a new thread be more useful? |
