honda cbr 125r 2007 wire problem
dbubble
PostPosted: 23:00 - 05 Aug 2014    Post subject: honda cbr 125r 2007 wire problem Reply with quote
new to this forums
i was wondering if someone could help me out i have a honda cbr125r year 2007 and after attempted robbery.( they just cut my ignition cable to get the bike to run) now for some reason my front lights horn and back brake light(when i brake) dont work
the turn signals work and the back red light works
i have checked the fuses and checked all the cable blocks to see if they got pulled out i have no clue now what or where i should be looking any help would be great thanks
unitynotsocri... This post is not being displayed because the poster is banned. Unhide this post / all posts.
InquisitionCh...
PostPosted: 14:54 - 06 Aug 2014    Post subject: Reply with quote
Neutral Sorry to hear about the attempted theft buddy. And also welcome to the forum!
As unity said it sounds like the the primary connection in the ignition itself. It could be that when they cut the wires, they pulled out a couple of wires from inside the barrel.
Best of luck with getting it fixed! If youre in the midlands I can recommend a couple of great shops that wouldnt cost the earth.
Currently Riding: CBR125-R7 (and having too much fun doing it) + Kawasaki Z750 (She's called Clementine for a reason!)
dydey90
PostPosted: 15:08 - 06 Aug 2014    Post subject: Reply with quote
Here's the wiring diagram:
https://i574.photobucket.com/albums/ss182/hmmmnz1/Honda/cbr125r.jpg
I don't know exactly how the black (assuming common neutral) is routed, but it makes sense for the front lights and the horn at least to be close to the ignition, so that'd be my first guess.
I had a problem with mine where it wouldn't start and it turned out it was because the fuel sender wire wasn't connected. I don't know if that had an effect anywhere else in the loom, but it's the only change I made and it fired right up afterwards...
gavcarter
PostPosted: 15:09 - 06 Aug 2014    Post subject: Reply with quote
Not an issue, mine is running without one at present as its been "fightered"
dbubble
PostPosted: 19:32 - 06 Aug 2014    Post subject: Reply with quote
thanks guys i worked out why it did not work the fuse that i replaced did not work even tho it was not broken the fuse was a spare that came with the bike just my luck i spend all this time and its the fuse
i still have the problem that the back brake light stays on when i turn the bike on any ideas ?
thanks
and yes i am in the west midlands Smile
gavcarter
PostPosted: 21:30 - 06 Aug 2014    Post subject: Reply with quote
thanks
Brake light switch is sticking. First clean the pivots for the lever, clean and lightly oil the return spring and also a bit of oil on the brake switch wont hurt either.
InquisitionCh...
PostPosted: 22:14 - 06 Aug 2014    Post subject: Reply with quote
thanks
Arnold's in Loughborough are my local shop if ever you need anything done. Can't recommend them enough, ace service and there is free tea and coffee Wink
As far as your brake light goes, is it at full illumination? Or on but dim?
dbubble
PostPosted: 15:27 - 07 Aug 2014    Post subject: Reply with quote
i fixed the back light problem they had broken my front leaver where it hits the brake light switch off
i found this out after i checked the back one because the back spring was not attached to anything
https://imgur.com/2Bcsuce
the brake light is on when the spring is not stretched so anyone have any ideas where this thing has to go lol i have no clue if someone has a picture or a videos that would be great Smile
thanks again for the help
gavcarter
PostPosted: 16:58 - 07 Aug 2014    Post subject: Reply with quote
spring hooks under the rear brake lever i sure there a little bracket for it it to catch onto.....
dbubble
PostPosted: 17:09 - 07 Aug 2014    Post subject: Reply with quote
i have looked and looked and unless i am retarded and tbh i think i am i cant find where its got to go Razz i am not a bike man! i dont know much when it comes to bikes Razz
gavcarter
PostPosted: 17:24 - 07 Aug 2014    Post subject: Reply with quote
just hook it round the lever the itself
dbubble
PostPosted: 17:45 - 07 Aug 2014    Post subject: Reply with quote
its not that long to hook it around the leaver the only thing it can hook onto is the big string next to it but that way it turns off when i use the pedal Razz
gavcarter
PostPosted: 17:54 - 07 Aug 2014    Post subject: Reply with quote
just double checked mine and yes sorry it it supposed to hook around the bottom coil on the fatter spring.
It is only supposed to light up when you press down on the lever. If it turning of altogether your bulbs have probably blown
dbubble
PostPosted: 18:10 - 07 Aug 2014    Post subject: Reply with quote
i have tested the back light and it works with the front brake and back brake when i use the switch`s but i am having problems getting the back brake leaver to work the switch right .... if i put the spring onto the bottom of the coil when i use the back brake the light goes off not on because it pulls the spring down its driving me up the wall Razz
i bet its something simple but
just to check the back brake switch makes the light brake come on when u pull it ?
gavcarter
PostPosted: 19:12 - 07 Aug 2014    Post subject: Reply with quote
Yep thats right, pull spring light on, release spring light off......
dbubble
PostPosted: 19:23 - 07 Aug 2014    Post subject: Reply with quote
then i have messed something up because when i pull it the light is off
gavcarter
PostPosted: 19:39 - 07 Aug 2014    Post subject: Reply with quote
Maybe it is adjusted too far? If you look were the switch actually mounts there is a circular ring that screws up and down on the switch letting the switch drop down or raise up.....
Screw it all the way to the top of the switch so the switch moves closer to the rear brake lever and try that. You will probably end up with no light at all if the switch still works, then you will have to steadily raise it until the light comes on with the lever depressed.
dbubble
PostPosted: 19:51 - 07 Aug 2014    Post subject: Reply with quote
sorry i think i have mislead you like i said before i am not a bike man
with out the spring attached to anything if i pull the spring then the light is off
i think u might be thinking i was on about the leaver ?
so with out the spring attached to anything other then the switch it self and u just pull on the spring is the light supposed to be on or off ?
because at the moment its off when i pull it
again thanks for the help i have no clue about things like this trying to save some money and learn at the same time Razz
gavcarter
PostPosted: 20:03 - 07 Aug 2014    Post subject: Reply with quote
the light is supposed to be OFF when the spring is detached. You may have pulled it a bit far and got it stuck.
Push the plunger ( that spring is attached to) on the switch right up and see if light goes of. Try with a reasonable amount of force if it doesn't work first time.
Don't try and crush it back up or use pliers etc you will probably break it altogether.
It works like this:
the brake lever is pressed down,
the return spring is stretched ( fat spring that pulls lever back up )
which moves the bottom coil further from the switch
so in turn pulls the lighter spring and then the plunger on light switch comes down and turns on your brake lights.
if the plunger on the brake switch has gone too far it may not be returning properly so give it a good shove back in towards the switch and try that.
If it goes off but comes back on when you attach the spring then the switch position needs adjusting ( this is what I put in my post above ^^)
dbubble
PostPosted: 20:34 - 07 Aug 2014    Post subject: Reply with quote
in that case then the switch is broke i will buy another one
thanks mate you have been a feel good help Smile
The last post was made 12 years, 35 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 111.17 Kb
