nsr125r jc22 water in the cylinder?
joshuaHolden
PostPosted: 23:08 - 10 Aug 2014    Post subject: nsr125r jc22 water in the cylinder? Reply with quote
So I removed my JC22 engine, stripped it completely down and replaced an oil seal and checked the piston size for future reference, put it all back together and fired her up, after about 5 seconds the engine cut out and water was squirting from the exhaust port sides (where the exhaust joins the engine) switched it off and waited 5 minutes, gave it a quick blast again (didn't want to push it in case I got hydrologic compression on the crank ) this made more water squirt out of the exhaust port.
Any Ideas what I could have missed that would cause this or what to check for, could do without taking then engine out again but I guess I may have to now?
skatefreak
PostPosted: 08:19 - 12 Aug 2014    Post subject: Reply with quote
Yep,
its going to be coming from either the top or bottom gasket on the cylinder or if you're really unlucky the cylinder may have cracked.
Best best, least faff would be to get the head off and look for any obvious signs that the head gasket is letting water through (may not be so easy if the engine hasn't run, then get the cylinder off to check it and the base gasket Neutral
Not having much luck are you Neutral
Let us know how you get on.
Best regards
-Jvr
Ps, you can upload pictures when you make a post and pictures can be invaluable (even if its just for 'Slack chain/Bent subframe' giggles - This is the BCF heh).
The last post was made 11 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.73 - MySQL Queries: 14 - Page Size: 37.91 Kb
