Water in my indicators
talkToTheHat
PostPosted: 17:13 - 18 Sep 2014    Post subject: Water in my indicators Reply with quote
My indicators are big chrome lollipop like things on rubber stalks. I had an open circuit in the right rear, so I took the lens off, wrestled the bulb out and then took the left rear lens off, only to have a load of water pour out. Some pissing about later and the right started working again.
How would I go about sealing my indicators against such water ingress?
Is it safe to smear a little coppaslip on the bayonet socket to aid removal and prevent corrosion?
Bandit. does. everything.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:17 - 18 Sep 2014    Post subject: Reply with quote
I'd just drill a small hole in the bottom of the indicator. Any further water ingress will then just run out.
Triumph Sprint ST 1050
Copycat73
PostPosted: 17:24 - 18 Sep 2014    Post subject: Reply with quote
yes.
and this too.
caveat emptor
CG Sam
PostPosted: 17:28 - 18 Sep 2014    Post subject: Reply with quote
Looking on CMNSL there should be some kind of gasket between the lens and the indicator housing. I know on the CM125 they have rubber ones, having had a problem with a rear indicator due to it being missing and water getting in.
CG125, SV650S, CBR600F, GSXR600 SRAD
talkToTheHat
PostPosted: 17:54 - 18 Sep 2014    Post subject: Reply with quote
I have the gaskets in. Not sure if they seal perfectly. What isn't sealed is the inside of the indicator stalk, wondering if water sprayed at the fender runs down the indicator cables through the inside of said stalks.
Is there some kind of recommended sealant that won't bond so tight I can't get the indicators open ever again?
Will drill the two scummiest indicator bodies, am still trawling for reasonably priced replacements for the right hand side, but shuffling the two rights to the rear to experiment with drilling holes in the meantime is no further loss if I mess up. How big a hole, about 3 mm?
Taught2BCauti...
PostPosted: 18:04 - 18 Sep 2014    Post subject: Reply with quote
Big enough so it doesn't get blocked by crud that comes in with the water. You could also use clear silicon sealant on the cable entry.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
CG Sam
PostPosted: 18:19 - 18 Sep 2014    Post subject: Reply with quote
The quick cheap fix would be some aluminium tape, wouldn't show up to much against the chrome and just put it round the joint that you suspect is the problem. Wouldn't look great though, but should give an idea of if it is where the water is getting in.
The last post was made 12 years, 27 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.29 - MySQL Queries: 14 - Page Size: 52.75 Kb
