| c_dug |
 c_dug Super Spammer
 Posted: 09:50 - 06 Oct 2014 Post subject: Weird electrical issue |
Over the last week my bike has developed an odd electrical fault. It took a couple of times for me to nail down what was happening, I think it happened 3 or 4 times in total last week. It has been very cold and damp in the mornings so I'm not sure if that has contributed.
I park with my front wheel to a hedge, so the first thing I do is get on the bike, key in ignition on. With that the headlight, dashboard and Neutral light all come on. I then start to paddle the bike backwards by around a foot or two, the backwards bit may or may not be relevant but I thought I should mention it.
While paddling backwards everything electric dies for about half a second. No lights on anything. Clock resets (Time not Odometer). It then all comes back on. I think it makes a sound a lot like a starter solenoid clicking as the power comes back on, I've not identified where the click is coming from.
- The bike starts up fine and there are no issues at all on the way to work.
- The issue only seems to happen first thing in the morning.
- I don't think I am pressing the starter button or anything like that which might somehow trigger everything to die.
I have never replaced the battery and I have questioned it's health in the past, it is just about at the top of my replace list for when I have the spare £££, but to me the issue doesn't seem like something that would be caused by an unhealthy battery? It still shows 12V. ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| Copycat73 |
 Copycat73 World Chat Champion
 Posted: 10:15 - 06 Oct 2014 Post subject: |
worn ignition lock or contacts .. try jiggling the key in the lock when it goes off and see wot happens.  ____________________ Whatever I post I have no citation and no intention of providing one..
caveat emptor |
| c_dug |
 c_dug Super Spammer
| map |
 map Mr Calendar
 Posted: 10:44 - 06 Oct 2014 Post subject: |
Can you confirm the bike, not clear from your tags line, is it the XJ900?
One thing I can think of related to going backwards (and I'm not exactly sure if there's one fitted) is a tilt sensor being dodgy.
Other than that I'd go with looking at the contacts in the ignition/key area. Or maybe kill switch electrics being pulled/shorting with backwards movement (so ok when ridden forwards). ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| c_dug |
 c_dug Super Spammer
| iooi |
 iooi Super Spammer
 Posted: 12:02 - 06 Oct 2014 Post subject: |
Moisture getting into the switches maybe.
Get some WD 40 or such sprayed into the switch clusters.
Or park the bike the other way round  ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| WD Forte |
 WD Forte World Chat Champion
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 13:34 - 06 Oct 2014 Post subject: |
I had a similar problem with my DRZ400E, turn the ignition, sometimes it worked, sometimes completely dead.
Turned out the main fuse holder and wiring were a bit dodgy.
The fuse was situated on the frame just between the seat and side panel. The position of your backside, on the seat, or how hard you brushed the side panel with your boot, last time you used the bike, determined the availability, or lack of, electrickery, when turning the key!
What, if any, wiring is under your seat? ____________________ "Everybody needs money, that's why they call it money!"  |
| stinkwheel |
 Posted: 13:50 - 06 Oct 2014 Post subject: |
Solenoid-type clicking noise shortly after turning on the ignition says fuel pump to me.
Does it have one? If it does, I'd look here first, even if it's just to confirm this is the source of the clicking. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| map |
 map Mr Calendar
 Posted: 13:59 - 06 Oct 2014 Post subject: |
If we're admitting to weird electrical faults of our own bikes the old GT550 had one. Could I find it, could I heck.
Then one day looked at what appeared a good solid earth wire from battery. Gave it a little pull and it just crumbled to dust. Totally gone. A fresh piece of shiny (insulated) copper wire and all as good as new (well as good as for a 20+ year old bike).
So, on topic, checked a good earth connection? ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| monkeybiker |
 monkeybiker World Chat Champion
| c_dug |
 c_dug Super Spammer
| monkeybiker |
| chris-red |
| stinkwheel |
| chris-red |
| c_dug |
 c_dug Super Spammer
| Ribenapigeon |
 Ribenapigeon Super Spammer
The last post was made 11 years, 281 days ago. Instead of replying here, would creating a new thread be more useful? |
