Honda X8R not starting...
PostPosted: 14:10 - 02 Nov 2014    Post subject: Honda X8R not starting... Reply with quote
Hey,
Got an X8R.
Has fuel, is getting fuel to carb happily. Carb is spotless.
Has compression, more than enough.
Is only sparking when you let go of the starter button, just 1 single spark, whilst cranking there is fuck all. Neutral
Any ideas? Its crap weather so thought I'd spend the day fixing, however after making sure everything fuel wise is great, it just won't spark on the button, only when you let go.
It does have some aftermarket bits, PM Tuning CDI so perhaps that is causing issues, however there isn't much you can do with it bar adjust "delay" and "rpm" so I won't be messing with it, no idea what they do. Thumbs Up
Any hints/tips/fixes I can do would be greatly appreciated, I'm afraid I'm out of ideas Sad
doggone
PostPosted: 14:22 - 02 Nov 2014    Post subject: Reply with quote
Dodgy coil?
Tried an alternative plug?
Thinking
andys675
PostPosted: 15:21 - 02 Nov 2014    Post subject: Reply with quote
dodgy coil, check there's power going to it
coils are really cheap, £8.50 off the bay
https://www.ebay.co.uk/itm/IGNITION-COIL-C-W-HT-SPARK-PLUG-LEAD-FOR-HONDA-SKY-X8R-/160910023178?pt=UK_Motorcycle_Parts_13&hash=item2576fc1a0a
same type used on a peug speedfight and honda vision, they go regularly on them
PostPosted: 15:56 - 02 Nov 2014    Post subject: Re: Honda X8R not starting... Reply with quote
Checked the kill switch wiring system? Ie side stand switch and so on?
PostPosted: 16:09 - 02 Nov 2014    Post subject: Reply with quote
No kill switch stuff on there.
Could try a new coil, does the same with any spark plug.
PostPosted: 20:33 - 02 Nov 2014    Post subject: Reply with quote
We have life.
I just spent a few minutes stripping the coil off the frame. I assume they have lots of spiders in York as I found a family of them chilling on the coil..
I've given it a quick clean up and hey presto, tick tick tick Mr. Green
How to figure out why its not pumping oil Shocked
PostPosted: 21:25 - 02 Nov 2014    Post subject: Reply with quote
I shall, however getting to it requires either cutting the frame or removing the swing arm... Laughing
stevo as b4
PostPosted: 22:58 - 02 Nov 2014    Post subject: Reply with quote
Hi Paddy.
The XR8R/S is one of my all time favourite 50cc twist and go's, being a solid Japanese built bike, and also having an all cast alloy frame for cool points.
The PM tuning CDi, will have been fitted to bypass the re-limiters in the Honda Cdi, as they did a very good job as usual with restricting the performance and speed to 30mph.
There's a limiter at 7500rpm, which apparently can be by-passed somehow, but another limiter at 9250rpm, which means that proper reverse cone sports pipe's don't work as well as they should, hence why people fit aftermarket Cdi's.
map
Mr Calendar
PostPosted: 09:34 - 03 Nov 2014    Post subject: Reply with quote
If pump is an issue you can run on premix until sorted.
PostPosted: 11:06 - 03 Nov 2014    Post subject: Reply with quote
Premix would be fine, however I aim to run an additional fuel tank, just because Laughing So would be ball ache to mix an unknown amount of fuel.
That and I'd have to upjet etc.
The last post was made 12 years, 5 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.29 - MySQL Queries: 16 - Page Size: 97.29 Kb
