| Renton |
 Renton World Chat Champion
| kramdra |
 kramdra World Chat Champion
 Posted: 15:36 - 22 Nov 2014 Post subject: Re: Hot Grips + Renthals |
The glue will act as lube, and in the case of superglue, the more you use, longer it takes to set as it requires a tiny bit of moisture. I would recommend using a 5 min epoxy as it has better temperature resistance than superglue. I had issues with my throttle grip coming lose and being unusable - riding 20 miles with no grip is far from pleasant.
Dont worry about damaging them, oxfords have a layer of hard plastic in the middle which the element is wrapped around**. The inflexible nature of it is perhaps why they are harder to fit. I recently cut the old oxford rubber off and slid new wemoto grips over the top of the element. Much nicer  |
| _Iain_ |
 _Iain_ Banned
 Posted: 15:51 - 22 Nov 2014 Post subject: |
Probbably a silly idea, but couldn't you plug the hotgrip in & warm it up to max & leave the bars in the freezer overnight?
Grip expands, bar contracts, glue to lube it all up & win? ____________________ Please be aware that the above post may be full of complete nonsense.
| Renton |
| talkToTheHat |
 talkToTheHat World Chat Champion
| barrkel |
 barrkel World Chat Champion
 Posted: 22:39 - 23 Nov 2014 Post subject: |
Don't epoxy the right hand side Oxford heated grip to your throttle tube.
Heated grips don't last forever, and Oxford quality even more so. Save yourself having to buy a new throttle tube should you need to replace the grips.
I wouldn't use epoxy at all. Superglue was lube enough. Superglue is brittle once hardened, it's easy to remove a grip that has been superglued in place, so don't be afraid of getting it wrong when fitting - and use more glue as necessary to lube. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| talkToTheHat |
| _Iain_ |
 _Iain_ Banned
| barrkel |
 Posted: 10:54 - 24 Nov 2014 Post subject: |
| talkToTheHat wrote: | | barrkel wrote: | Superglue is brittle once hardened, it's easy to remove a grip that has been superglued in place |
Is there an easy technique to do this? |
A thin screwdriver inserted between grip and bar, a spray of lubricant or acetone if you have a handy means of squirting it in, and roll the screwdriver all the way around between grip and bar until the grip is able to rotate independently. It should then slide off fairly easily.
Stock grips are effectively superglued in place. It's easier to get stock grips off, as they don't have any wire, just rubber, so are more stretchy. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
| Conzar |
 Conzar World Chat Champion
 Posted: 12:22 - 24 Nov 2014 Post subject: |
Brake cleaner works fine, it will act as lube and will dry up over night.  ____________________ Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan |
| talkToTheHat |
| barrkel |
 Posted: 19:05 - 26 Nov 2014 Post subject: |
| talkToTheHat wrote: | | _Iain_ wrote: | Acetone dissolves it |
Is acetone safe to use on a throttle tube you want to keep or will it damage the plastic? |
Honestly I don't know. I've briefly used it (or nail polish remover, rather) on a rag to help remove existing glue, it didn't seem to cause visible damage. You'd need to use a lot of acetone for it to make a significant dent in the plastic, IMO. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
| stinkwheel |
| chris-red |
| raesewell |
 raesewell Traffic Copper
The last post was made 11 years, 297 days ago. Instead of replying here, would creating a new thread be more useful? |
