| Matt371 |
 Matt371 L Plate Warrior
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 18:32 - 09 Jan 2015 Post subject: |
You should replace it .Its the gauze oil filter cover,not the drain plug which is underneath the engine. If you change the oil using this and not the bolt then all the dwarf n crud builds up inside......knackering your new oil in five hundred miles. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| Matt371 |
| unitynotsocri... |
 Posted: 18:48 - 09 Jan 2015 Post subject: |
Look under under the engine, there should be another bolt at the lowest point. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| Matt371 |
| Matt371 |
The last post was made 11 years, 308 days ago. Instead of replying here, would creating a new thread be more useful? |
