Optimate charger
Whosthedaddy
PostPosted: 10:52 - 20 Jan 2015    Post subject: Optimate charger Reply with quote
Just removed the battery to charge as will be sitting idle for several weeks and found an optimate charger connector attached to the bike.
Never having one before does anyone recognise it? Be habdy not to have to unscrew and bolt the seat each time.
Matt B
PostPosted: 10:59 - 20 Jan 2015    Post subject: Reply with quote
May be wrong but with that red cap it looks like the lead that comes with an Optimate.
The Oxford chargers use the same type of connection though.
map
Mr Calendar
PostPosted: 11:03 - 20 Jan 2015    Post subject: Reply with quote
Yes. It looks like an optimate charger lead. The different shapes are so you don't put +ve to -ve or vice versa.
See here for variations.
The lead from the optimate should plug straight in. Optimate don't appear to have changed this plug for any of the various version numbers.
Whosthedaddy
PostPosted: 11:10 - 20 Jan 2015    Post subject: Reply with quote
Looks like the SAE71 adaptor that's attached to the battery. So in theory any model of optimate battery charger should be able to hook up to this cable?
map
Mr Calendar
PostPosted: 11:19 - 20 Jan 2015    Post subject: Reply with quote
Whosthedaddy wrote:
...SAE71 adaptor...in theory any model of optimate battery charger should be able to hook up to this cable?
map wrote:
...Optimate don't appear to have changed this plug for any of the various version numbers.
I'd say so.
If you can't get an Optimate then Accumate are made by same company.
Whosthedaddy
PostPosted: 11:35 - 20 Jan 2015    Post subject: Reply with quote
It says a new connector in the advertising pic?
On the connector sales page it says not suitable for 1 and 2 chargers unless pre 2010...
Think I'll just order a charger and if it fits then all well and good, they appear to come with the detachable connector anyways so worst case scenario I'll have a spare.
Which one though? It'll only be the odd charge when standing for more than a few days, not a trickle over night.
Matt B
PostPosted: 11:40 - 20 Jan 2015    Post subject: Reply with quote
Cheapest option is probably an Oxford Oximiser 600 - about £20ish on ebay now.
map
Mr Calendar
PostPosted: 11:41 - 20 Jan 2015    Post subject: Reply with quote
Whosthedaddy wrote:
...Which one though? It'll only be the odd charge when standing for more than a few days, not a trickle over night.
I admit I've lost track of the various Optimate version numbers. I think the higher numbers handle the newer Gel and whatever batteries better.
I'd speculate it doesn't really matter which one (unless you need for newer battery type) as I understand Optimate does a recovery/recharge and if left on (for days) then automatically goes into a recycle/top-up/keep good sort of mode.
FWIW I've heard bad reports of the Oxford branded chargers. They're not really Optimate/Accumate. They tend to break after a while when the Optimate just keeps on working.
Bikeless
PostPosted: 12:10 - 20 Jan 2015    Post subject: Reply with quote
Buy a CTEK charger,half the price of an optimate and the same or better.
Iain.
PostPosted: 12:42 - 20 Jan 2015    Post subject: Reply with quote
Optimate 3+ is on the wall in the shop for £49.99. CTEK is sat next to it at £40 and hasn't moved for the two years I've worked here. Tells me all I need to know Laughing Thumbs Up
jeddy11
PostPosted: 13:55 - 20 Jan 2015    Post subject: Reply with quote
Be carefull as i have a newer optimate 4 and it comes with the blow plug.
https://i185.photobucket.com/albums/x232/jeddy11/OPT_SAE_connectorX_zps894700ec.jpg
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
Bikeless
PostPosted: 14:06 - 20 Jan 2015    Post subject: Reply with quote
Because bikers are always pointed towards Optimates,they're good but you can get better for the money,CTEKS are cheaper,have a 5 year warranty and beat Optimates in auto test features.
And no I'm not biased,l have both an Optimate 3 and a CTEK 5.0.
The last post was made 11 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 1.28 - MySQL Queries: 14 - Page Size: 77.54 Kb
