| bryhhh |
 bryhhh L Plate Warrior
 Posted: 12:57 - 02 Aug 2004 Post subject: Broken Tax Disk Holders |
First post, so treat me gently
A month ago I found my tax disk holder had snapped, so I replaced it, along with the tax disk only to find this morning that the same has happened again. I had the first one mounted on the swingarm, the second one I mounted on the front mud gaurd screw. I'm guessing that vibration was the cause of the breakage rather than somebody nicking it, as the tax disk that was fitted expired over the weekend.
So the question is where is the best place to fit the damn thing? I have a CBR600, and I'm struggling to find any good locations to fit them as all the fairing bolts are inset. Comments appreciated from any other CBR6 owners.
For info, I've been using this motrax disk holder. I might try one of these these next, as the lug (where my two last ones broke) looks a bit stronger. |
| Tarmacsurfer |
 Tarmacsurfer World Chat Champion
 Posted: 14:22 - 02 Aug 2004 Post subject: |
Hi, and welcome
I always use the cheap stick on plastic beasties, 80p and they attach solidly to the inside of the screen making it damn near impossible to remove the holder and leave the disc in one piece without alot of hot water and careful peeling. Never lost a disc yet to either thieving or just general misplacement. ____________________ I'm immortal. Well, so far. |
| bryhhh |
| stinkwheel |
 Posted: 17:17 - 02 Aug 2004 Post subject: |
Chances are that someone has been snapping them off and stealing your tax disc. A stolen tax disc is of no use to anyone these days as they use a database to check if a vehicle is taxed before they even stop it.
So why steal them? you may well ask. Because they are Fecking idiots, that is why.
Clear, sticky backed plastic. 60p per metre at all good hardware stores. The traditional place used to be stuck round the frame downtube or the fork leg before all these new-fangled holders came about.
Mine is stuck on the back of the numberplate, you can see it clearly if you know where to look. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| marc_yorks |
 marc_yorks Crazy Courier
 Posted: 20:22 - 02 Aug 2004 Post subject: |
just a little tip for all the people who's tax discs get wet with general moisture,go to a printers or stationary shop and get them to laminate your tax disc,stops moisture messing them up. |
| hustler |
 hustler Crazy Courier
 Posted: 21:01 - 02 Aug 2004 Post subject: |
Hmmm, mines currently in my jacket pocket. That reminds me I need to go and buy a holder  ____________________ As I said to that guy with the crutches and full camouflage gear, you can hide but you can't run. |
| clemsta |
 clemsta Scooby Slapper
| bryhhh |
 Posted: 21:34 - 02 Aug 2004 Post subject: |
Thanks for the tips. I've got a stick on holder and put it behind the screen.
If this one goes missing, I'll know for sure that it's some little w**ker that keeps nicking them. Perhaps I should have added a few razor blades  |
The last post was made 21 years, 138 days ago. Instead of replying here, would creating a new thread be more useful? |
