Cam chain tensioner question
joezxr
PostPosted: 14:10 - 01 Apr 2015    Post subject: Cam chain tensioner question Reply with quote
I have a kawasaki 636 2003 B1H model with just over 18,000 miles on the clock and the engine is making a loud ticking noise from the front right of the engine while its cold but then gets less noise when the engine heated up so im guessing the cam chain is rattling around.
usually i would just do the one click trick, where you pull the auto cam chain tensioner out one more tooth and stick it back into the engine and voila the noise goes away...
but i was just wondering why am i having to do that, and why hasnt my auto tensioner done its job and jumped another tooth out yet if the chain is loose? obviously i dont need a new chain as the bike had reletively low mileage and the tensioner on inspection isnt even half way out of its housing!? Confused
Heres a video of the noise https://vid1148.photobucket.com/albums/o564/pixelguyy/VID_20150401_144658_zpsc2fsxnl9.mp4
davebike
PostPosted: 14:15 - 01 Apr 2015    Post subject: Reply with quote
10 year old mechanism and spring just sticking
How old / clean is the oil if good try the trick or better still replace the tensioner as if it fails at speed you will lunch the engine
Dave
NC750Xdct + others at work !
davebike1@gmail.com
joezxr
PostPosted: 14:54 - 01 Apr 2015    Post subject: Reply with quote
well it all it all seems to move fine and i change the oil every 3000 miles!
but i suppose over time the spring could have lost its tension? :o maybe time to get a newun!
robertw95
PostPosted: 16:21 - 01 Apr 2015    Post subject: Reply with quote
If it was me I'd remove the tensioner and clean it/replace spring or just replace if oem price is reasonable
07 Dt125r, sv650s k8, zx6rr 04
The last post was made 10 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.84 - MySQL Queries: 14 - Page Size: 39.92 Kb
