Car help: judder and stall when cold
grant965
PostPosted: 21:41 - 28 Jan 2015    Post subject: Car help: judder and stall when cold Reply with quote
Hi all,
Got an issue with my Peugeot 206 1.4 8v.
When I first get in the car I have to reverse it onto my drive to turn it around, car starts fines.
Most of the time it reverses fine but then judders and stalls when you press the clutch.
Occasionally it judders when I reverses.
If it stalls, I start it up and its perfectly fine.
Similarly, I can drive it for 5 minutes in a morning and at 10pm that night (when the car should be cool) it works perfectly fine.
I also sometimes get a judder/misfire when driving but if I change down a gear and accelerate it is fine.
Note:
Head gasket changed 5k ago, oil and water still clean so don't think that has gone again.
Exhaust is blowing.
When it first did it a few months ago a mate hooked it up to a code reader and it was clear.
Just little things that do not bother me in the slightest but I am looking to sell it shortly so need it sorting.
Thanks in advance,
Grant
Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R
Mark65
PostPosted: 21:50 - 28 Jan 2015    Post subject: Reply with quote
Clutch plate sticking, not disengaging flywheel?.
grant965
PostPosted: 11:47 - 01 Feb 2015    Post subject: Reply with quote
Cheers for the help guys, had a good look over the car and noticed the following:
Exhaust had a bit of it missing where it joiners the headers; cost me £11 and half hour to change.
Engine breather that goes to throttle body was gunked up, guess I forgot to check it when I changed the headgasket. Bit of carb cleaner and a rag and all good now, also cleaned and greased the two sensors on the throttle body, assuming TPS and MAF ?
Hasn't stalled since and haven't had the misfire/bog down either, however that never happened that often so only time will tell if it is sorted.
Onto another issue, the MPG is awful.
£10 to trafford centre and back from Preston, worked out at 32mpg from a 1.4 8v, combined MPG from a site is 45mpg, I know you dont usually get anywhere near that but how can I be 25% off it.
Not too fussed at sorting this as I will be getting a new one in the next month or two but would be interested to see whats causing it.
Tyres are checked regularly.
As far as I can tell the brakes aren't sticking slightly.
95% motorway for the journey above at a speed of around 60mph.
Not particularly heavy footed.
Only me and my missus in the car.
Thanks,
Grant
The last post was made 11 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.59 - MySQL Queries: 14 - Page Size: 50.24 Kb
