honda h100 engine clean
cb1rocket
PostPosted: 19:52 - 17 Feb 2015    Post subject: honda h100 engine clean Reply with quote
As some of you may know I'm restoring my first ever Honda H100s2.
Anyway i rebuilt the engine with all new bearings and seals and didn't get the cases clean while it was apart as i had no intention of doing a full bike strip down.
So rebuilt engine, dirty cases. What do i do to clean it? My guy who does aqua blasting won't touch it because of fluid contamination in case the oil leaks out despite the fact it empty.
Edit: should add i have a compressor but not use for cleaning. I have done soda blasting but this makes such a mess plus its cold and i want to do it in the garage
https://cdn.bikechatforums.com/files/2015-02-17_18.49.34.jpg
stevo as b4
PostPosted: 20:33 - 17 Feb 2015    Post subject: Reply with quote
Can you not make blanking plates for the inlet/exhaust, and remove any rubber pipes and wiring etc, then throw it in a bath of coca cola for 2days to see if that helps?
I've found strong alloy wheel cleaner and a stiff brush good at alloy cleaning in the past, but it depends on the brand. They are a mild acidic cleaner which if properly rinsed off should cause no worries (disclaimer here!)
Don't use oven cleaner on the alloy, as despite the horror stories, I don't think it does much or is that effective on alloy anyway! It would probably have a good go at the steel or cast iron bits though!
The last post was made 11 years, 216 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.73 - MySQL Queries: 14 - Page Size: 32.07 Kb
