| stinkwheel |
 Posted: 22:42 - 14 Feb 2015 Post subject: Royal Enfield bullet oil filler extension |
Thought I'd share this since a few people on the forum have Enfields too.
Pre-unit Enfield bullets of any vintage aren't known for their conservative oil useage. They tend to leak/burn a fair bit and require regular checking and topping up.
On a long trip, this is a bit of a pain because the oil filler is a bit too inaccessable to simply pour oil into from a bottle if you get caught short. You either need to take a bottle with a long spout or a funnel. I for one am fed up with having to carry an oily funnel about with me all the time.
The simple solution would be to extend the filler neck so you CAN pour oil from a bottle into it.
So I got my local engineering spot to make an extended filler neck up for me out of alloy. Works a treat. He added the "cooling fin" detail hiself. This isn't a big job at all for someone who can work a lathe.
https://i48.photobucket.com/albums/f216/stinkwheel/CIMG2266_zps2yqfgdmk.jpg
https://i48.photobucket.com/albums/f216/stinkwheel/CIMG2267_zpsdl2xdd5k.jpg
The bottom seals nicely against the existing o-ring. I've fitted a bonded seal (Dowty) washer under the filler cap.
The only remaining job is to fit a longer dipstick. It simply screws in and has an M5 thread so a bit of 5mm bright steel bar, a hacksaw and an M5 tap are the only tools needed to make a new one.
Here's the plans (remember I'm a vet, not an engineer and did this on libre office draw, not a CAD package so the drawings may not be perfect but the measurements are correct).
https://i48.photobucket.com/albums/f216/stinkwheel/extension%20collar_zpsjolx5hxe.png
NOTE: There is more than one type of oil filler cap. This one is a screw-in type with a round dipstick. You'd need to do something different if you have a push and turn one with a flat dipstick. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Pete. |
 Pete. Super Spammer
 Posted: 23:01 - 14 Feb 2015 Post subject: |
Nifty idea but christ what a crappy way to finish a part. No broken corners, galled thread and face and his 'cooling fin' detail looks like the part has spun in the chuck. ____________________ a.k.a 'Geri'
| stinkwheel |
| Triton Thrasher |
 Triton Thrasher Could Be A Chat Bot
| stinkwheel |
| Rogerborg |
 Rogerborg nimbA
 Posted: 17:16 - 15 Feb 2015 Post subject: |
But I like my oily funnel.
He's right, I genuinely do carry one, with most of the spout cut off. ____________________ Biking is 1/20th as dangerous as horse riding.
| YBR Ric |
 YBR Ric Spanner Monkey
| RhynoCZ |
 RhynoCZ Super Spammer
| Triton Thrasher |
| bikenut |
 bikenut World Chat Champion
| stinkwheel |
| Rogerborg |
 Rogerborg nimbA
 Posted: 17:03 - 16 Feb 2015 Post subject: |
Is yours an iron 350?
My AVL 500 does about the same top speeds, although it will indicate higher. It's all torque and might conceivably add another few (real) mph with a bigger front sprocket. It doesn't burn or spew oil (yet), although keeping the primary cover sealed is an ongoing project.
mpg is indeed 80 or more. Fuel is energy is power, and it doesn't make much.
The electric starter on the AVLs is a TRAP. It does start the engine but will almost inevitably jam the sprag clutch. At that point, your starter is constantly engaged with the engine. My (already replaced) sprag just jammed but I got lucky and it freed off when I wiggled the drive shaft back and forwards a bit, but it should be considered an emergency starter only.
The post 2008 fuel injected UCE engines are a different prospect with a lot of improvements - including to the starter and sprag. Unless you actively want a project bike, I'd suggest looking at one of them. They even have a fuel gauge instead of an ammeter. Luxury! ____________________ Biking is 1/20th as dangerous as horse riding.
| RhynoCZ |
| stinkwheel |
| garth |
 garth World Chat Champion
 Posted: 19:05 - 16 Feb 2015 Post subject: |
600ml in 360 miles is 1.6l in every thousand.
With consumption like that it's not worth changing the oil.  ____________________ You ain't a has been if you never was |
| Rogerborg |
 Rogerborg nimbA
| stinkwheel |
| Rogerborg |
 Rogerborg nimbA
 Posted: 21:05 - 16 Feb 2015 Post subject: |
Did I tell you about the time that I was behind a Nissan Micra being driven by a lady at a variable and appropriate speed for the road and conditions?
I was so amazed that I followed it for a few more miles just to be sure that I wasn't imagining it.
True story. My life, you want it. ____________________ Biking is 1/20th as dangerous as horse riding.
| reckless_b |
 reckless_b Trackday Trickster
 Posted: 21:12 - 16 Feb 2015 Post subject: |
My 350 bullet is in the same ball park as the others I guess, fuel somewhere over 80mpg, 60-70mph depending on conditions, I haven't noticed any significant oil useage as yet, its got about 7,000 kilometers showing so I guess its run in, its had the pulse air thing removed has a short sporty exhaust and electronic assisted ignition. I buy most of the consumables from india, air filters oil filters etc, very cheap off ebay, when I use the bullet instead of the car to go to work it only takes about six days to cover the cost of the road tax, with todays fuel price I guess about 4 days will be enough to cover it, although petrol has gone up 2p in the last couple of days, love to ride it, always leaves me with a smile on my face, plus the wife wont go on the back  ____________________ 40 years on the road on and sometimes off bikes with a very recent OFF |
| RhynoCZ |
| bikenut |
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:35 - 17 Feb 2015 Post subject: Re: enfiled |
| bikenut wrote: | they have good handleing and cornering ability as well as good enough brakes ? |
They go round corners and the brakes bring you to a halt. The tyres are 125 width, so set your leaning expectations accordingly. The suspension is basic, even with the new fangled gas shocks on the rear. Mine has had softer springs put in the front. Sometimes after braking it doesn't rebound until I rev it, at which point the front lifts a few inches in a sea-sick inducing motion.
I'd describe it as being just barely sufficient in quality and ability to constitute a motorcycle. But that's part of the appeal. I didn't ride it today and now that the sun's come out a bit, I'm pining for it. ____________________ Biking is 1/20th as dangerous as horse riding.
| YBR Ric |
| bikenut |
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:15 - 17 Feb 2015 Post subject: Re: enfield |
| bikenut wrote: | there most be some better aftermarket bits an bobs out there surely, like better rear shocks and some f/fork stuff |
Yup, there's loads of stuff available, either from Hitchcocks or direct from India. It's a bike that tends to be bought for tinkering.
| bikenut wrote: | don't these bikes have an internal dry sump lub system rather than a wet sump?? |
Yes, but they're prone to wet sumping. Hitchcocks actually do a filler extender with a breather in it:
https://www.hitchcocksmotorcycles.com/pictures/content13/wet_sumping.pdf
https://www.hitchcocksmotorcycles.com/accessory-engine-timingside#part_6260 ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 11 years, 243 days ago. Instead of replying here, would creating a new thread be more useful? |
