12v Battery voltage is 15v, not an overcharging issue!
PostPosted: 18:42 - 25 Feb 2015    Post subject: 12v Battery voltage is 15v, not an overcharging issue! Reply with quote
What would cause a 12v battery to put out 15v? I bought the battery new, filled it with electrolyte left it overnight and in the morning it was 15v, I trickled charged it with an optimate and still 15v, the electrolyte level is correct. What would cause this?
Copycat73
PostPosted: 18:43 - 25 Feb 2015    Post subject: Reply with quote
try a different volt meter.
caveat emptor
PostPosted: 18:47 - 25 Feb 2015    Post subject: Reply with quote
I have done, both my shitty £5 meter and my dads expensive Fluke one say the same.
Copycat73
PostPosted: 18:52 - 25 Feb 2015    Post subject: Reply with quote
leave it to stand 24 hours.
caveat emptor
PostPosted: 19:07 - 25 Feb 2015    Post subject: Reply with quote
It has been months and it is still doing it Laughing
It's not to much of an issue, the bike it is in doesn't charge the battery I just use an optimate (the same optimate that looks after 2 other batteries that are 12v (and actually are 12v).
pdg
PostPosted: 21:57 - 25 Feb 2015    Post subject: Reply with quote
On a normal digital meter display the '5' and the '2' are pretty much mirror images of each other. Here is a '5' followed by a '2'
https://image.shutterstock.com/display_pic_with_logo/61711/61711,1298051348,2/stock-photo-number-from-white-digital-display-series-71444248.jpghttps://image.shutterstock.com/display_pic_with_logo/61711/61711,1298051037,1/stock-photo-number-from-white-digital-display-series-71444254.jpg
To that end, have you checked your eyes are both in the right way round and pointing the same direction?
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
RhynoCZ
PostPosted: 23:10 - 25 Feb 2015    Post subject: Reply with quote
15v you say? No es posible. Tut Tut
PostPosted: 23:14 - 25 Feb 2015    Post subject: Re: 12v Battery voltage is 15v, not an overcharging issue! Reply with quote
If it's actually putting out 15v, the optimate shouldn't even try and charge it - it should immediately see it as (beyond) fully charged.
If it was a 7 cell rather than 6 cell lead acid battery I'd expect it to be putting out around 15v, but that seems unlikely.
If it was a lithium battery, also possible - but filling it with battery acid probably would have changed that!
Copycat73
PostPosted: 10:58 - 26 Feb 2015    Post subject: Reply with quote
in true BCF tradition ...
jpg.s of said battery and volt meters showin voltage readin ...
or it never happened... Thinking
caveat emptor
PostPosted: 11:51 - 26 Feb 2015    Post subject: Reply with quote
What happens under load? Say with a bulb running off it.
Islander
PostPosted: 12:17 - 26 Feb 2015    Post subject: Reply with quote
Very good point. Thumbs Up
PostPosted: 18:56 - 26 Feb 2015    Post subject: Reply with quote
Odd that
was wondering if a broken or cracked plate may have that effect?
RidingBear
PostPosted: 21:23 - 26 Feb 2015    Post subject: Reply with quote
as far as I understand, having 15 V is not possible. the voltage of each cell for a lead acid battery is normally 2.1-2.3 V. small variations are due to how the battery is made, but the voltage range is determined by the electromotive force which is given by the chemical reaction between the lead plates and the acid. having a broken plate would not increase the voltage.
15/6=2.5 V per cell. that's how they are charged (the chemical reaction is forced in the opposite direction).
PostPosted: 21:50 - 26 Feb 2015    Post subject: Reply with quote
Ignore me, My meter was running low on battery since replacing it is now showing 12v. Embarassed Dad told me he had the same with his meter, maybe he used mine...
RhynoCZ
PostPosted: 22:01 - 26 Feb 2015    Post subject: Reply with quote
No way. Rolling Eyes Laughing
moonzoomer
PostPosted: 22:45 - 26 Feb 2015    Post subject: Reply with quote
If it is showing 12 volts of load I would be a tad worried, put it on charge for a few hours and meter it again.
Islander
PostPosted: 23:08 - 26 Feb 2015    Post subject: Reply with quote
Kudos for 'fessing up. Laughing Karma
PostPosted: 23:25 - 26 Feb 2015    Post subject: Reply with quote
https://vignette1.wikia.nocookie.net/nation/images/f/fd/...oh_you%21.jpg/revision/latest?cb=20120107205421
The last post was made 11 years, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.6 - MySQL Queries: 13 - Page Size: 98.38 Kb
