Spotlights.
Northern Monkey
PostPosted: 16:38 - 03 Jun 2015    Post subject: Reply with quote
How about an hid kit instead.
weasley
PostPosted: 16:48 - 03 Jun 2015    Post subject: Reply with quote
I doubt the indicators will support them - they'd wobble. Maybe the mirror stems? Depends on how this would align the lights.
Wiring - ghetto: splice into the main beam wire behind the headlight with a Scotchlok. Properly: use a relay that takes main power from the battery (with an inline fuse) and a switching signal from the main beam circuit.
spriddler
PostPosted: 17:09 - 03 Jun 2015    Post subject: Reply with quote
I doubt you'll be able to ride fast enough in the twisty lanes to outrun your headlight! Besides, those lanes are very safe at night as you'll be able to see the light from others' approaching headlights at corners, illuminating the high Cornish stone 'hedges'.
Daytime is when they're most dangerous - tourists tearing along or an approaching tractor in 't middle of the lane or ahead of you leaving a trail of mud.
1954 Matchless 350. 1947 AJS 500. 2012 Kawasaki ER6, 2014 Honda CBF 125 (aka The Grudge Special') 1926 ATCO motor mower, Motorhome, People carrier....and vintage bicycle.
orac
PostPosted: 17:39 - 03 Jun 2015    Post subject: Reply with quote
so only for a week, what times. I currently work in Plymouth and it get light at 0500 and still light at 2130. longest day is on the 21 june so unless you are riding at some very late or very early time you should not need anything.
UncleFester
PostPosted: 17:42 - 03 Jun 2015    Post subject: Reply with quote
The ones i use ( got them from Farklemyride IIRC) are 900lumen / 12W each and are bright enough to render dipped beam all but redundant and that's with a new headlight reflector / lens and a better dipped/main lamp.
Can't find them on ebay now but it came as a kit - only thing i added was a relay and a switch so i could turn them on and off independently of the main lights.
Based on how bright these are, i don't think i'd want to subject other road users to their 2 brighter products.
2017 Z1000SX
WD Forte
PostPosted: 18:09 - 03 Jun 2015    Post subject: Re: Spotlights. Reply with quote
BodyGuard wrote:
Lights aren't that great on my Fazer I have a big contract on in Cornwall in a couple of weeks and will be riding down there to work for a week I don't want to end up in a ditch on some tight unlit Cornish country lane because I could not see.
Are these any good?
I am thinking of mounting them off indicators unless anyone has any better suggestions of where to mount them on a box eye Fazer.
Also how to wire them so they come on with full beam?
2x125 watts ?
that's 250 watts and probably more then your stator will pump out on a good day.
The 2x 12W ones UncleBfester has will do you and not put a strain on the charging system
bikers smell of wee
weasley
PostPosted: 18:23 - 03 Jun 2015    Post subject: Reply with quote
BodyGuard wrote:
When I say indicators I mean the stems...
Yes, I got this... my point still stands.
BodyGuard wrote:
I think they would look daft on the mirror stems.
I thought this was about being able to see, not improving how it looks in high street shop window reflections? Thinking
Improved safety and improved looks are often mutually incompatible.
WD Forte
PostPosted: 18:34 - 03 Jun 2015    Post subject: Reply with quote
2x20W wont kill it
bikers smell of wee
weasley
PostPosted: 18:38 - 03 Jun 2015    Post subject: Reply with quote
Implying mounting them on the indicator stems isn't going to improve visibility?
No, but I predict that the weight of those lamps will overcome the rigidity of the indicator stem and mount and the whole lot will wobble. At best this will give you a wobbly but bright view of the road ahead. It would annoy the nuts off of me. At worst it could fatigue the stems into failure. Or it might be fine.
weasley
PostPosted: 21:26 - 03 Jun 2015    Post subject: Reply with quote
Then ignore my well-intentioned but over-thought ramblings. Thumbs Up
ferrisio
PostPosted: 23:05 - 03 Jun 2015    Post subject: Reply with quote
Have you done the fazer headlight mod? It's on the Fazer owners forum, I think it's bad form to link directly to another forum from here but you'll find it easy enough if you Google it.
BMW R1100R
PostPosted: 23:24 - 03 Jun 2015    Post subject: Reply with quote
https://foc-u.co.uk/?topic=181.0
Big danger at night is vampires. Replace all bulbs with UV 'black light' bulbs. Advice applies only to BodyGuard.
UncleFester
PostPosted: 15:43 - 30 Jun 2015    Post subject: Reply with quote
Well ... you could either weld them on .......
Or you could look at wiring in some kind of switch or switch with a relay from a switched live so they only work when the lights come on .... or you could have them wired via a relay to just come on every time the lights come on.
Have you got any wiring experience at all?
2017 Z1000SX
UncleFester
PostPosted: 16:09 - 30 Jun 2015    Post subject: Reply with quote
You're going to need a wiring diagram.
You're then going to need to learn how to wire in a 4 pin relay and connect your lights to it.
Once you find the positive wire that feeds the main beam(s) and splice a wire off that to feed the relay - that will then turn on the spotlights when the main beam comes on.
If you have zero clue about this stuff, find someone willing to do it for you / show you as they do it.
Failing that .... off to google you go!
2017 Z1000SX
UncleFester
PostPosted: 16:46 - 30 Jun 2015    Post subject: Reply with quote
If the bike is a 12V system - then yes, you need a 4 pin relay.
You should also fit an inline fuse of the correct rating between the battery and the relay .... whatever is the correct rating for the current draw of the spotlights.
Wiring example.
https://www.vstrom.info/vsri-gallery/gallery/d/88309-1/Driving+Lights+High.jpg
I'd start with the above - the bits specific to your bike you'll need to work out. Google it - you won't be the first. That high beam wire in yellow is just the example - yours could be a different colour.
At risk spoiling the fun ..... check, check and check your wiring before you make it live / apply power.
2017 Z1000SX
The last post was made 11 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.51 - MySQL Queries: 14 - Page Size: 133.45 Kb
