NSR125 Dellorto PHBH28 carb
dansp1
PostPosted: 19:37 - 08 Jun 2015    Post subject: Reply with quote
Probably just vents for the float chamber, if you take the chamber off
you should be able to work out if that's the case.
Fidge This post is not being displayed because the poster is banned. Unhide this post / all posts.
stirlinggaz
PostPosted: 23:58 - 09 Jun 2015    Post subject: Reply with quote
hi,
these are definitely overflows/breathers & it IS odd that they are pointing upwards.
they shouldnt be.
therefore i'd be suspicious as to why they are pointing upwards.
try aiming them downwards & see if fuel pi$$es out,
cheers,
GAZ
stirlinggaz
PostPosted: 19:23 - 10 Jun 2015    Post subject: Reply with quote
Hi,
nothing that fancy on this carb, seen lots with the hoses pulled off.
I guess, as long as the wee nipples (Smile) arnt blocked everything should be ok.
I always look at the nipples & if the are grey/alloy they are usually breathers.
brass & they are usually fuel or oil hoses
cheers,
GAZ
The last post was made 11 years, 28 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.36 - MySQL Queries: 14 - Page Size: 57.37 Kb
