| robster94gt |
 robster94gt L Plate Warrior
| bikenut |
This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
 bikenut World Chat Champion
| Nemo |
 Nemo Could Be A Chat Bot
 Posted: 19:25 - 14 May 2015 Post subject: Re: part |
| bikenut wrote: | load of crap |
Before spamming, check that the site actually has that model
Might help if you take a picture of your bike.
I might be being stupid (I've got manflu, so it is possible) but I don't quite understand.
You're trying to fit the top yoke, but there is a bigger gap (how big is the gap roughly?) between the top yoke and headstock?
Really, need to know how big of a gap you are talking here. ____________________ Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo |
| bikenut |
| bikenut |
| robster94gt |
 Posted: 20:14 - 18 May 2015 Post subject: |
I found a schematic at
https://www.oldjapanesebikes.com/mraxl_GT_Resource/manuals/b100p_parts/index.php
under FRONT FORK
I've attached a few pics.
In the two shots with the handlebar mount, hopefully you can see the gap/angle that it has with/without the thick washer under the mount. It's noticeable at the top of the shocks.
The pic of the bolt shows the washers that were on it. The big one is black because it got powdercoated with the rest of the bike.
Initially I tried putting thick washer on top of the mount. When I put it under, the handle bar mount is pretty much level.
There is a washer in the parts picture that sits under the mount, but in the picture it doesn't look that thick, and its # is the same as the other thinner ones used... |
| bikenut |
 Posted: 12:06 - 19 May 2015 Post subject: exploded view |
parts diagrams and exploded views can be so helpful, cant they.
perhaps now some of the non believers will repent and see how powerfull these exploded views can be! and cmsnl is full of them :D
anyways the do not have them for your bike, but you have persevered..........
the diagram seems to show two part number 31's??
the bottom 31 seems to be a distance piece sitting on the bottom yoke steering tube.........with the lower steering bearing "cup" sitting above it.
if the distanced piece is missing then the bearing assembly will sit lower, meaning the whole assembly will fit "lower" but will probably foul the frame and not allow smooth un hindered movement from lock to lock.
back in a mow....
part 33, the lower "lock nut" seems to have a register??
washer 38 fits above 33, being a bit thicker than the 33 register??
34 is the upper lock nut, does this also have a register??
34 tightens down on to 38 and then 33. the washer 38 stops the lower lock nut 33 from turning when the system is tightened.
back in a mow....
does 38 the washer have a tang or key to stop it from turning??
part 20 is a washer also........back in a mow.....
I have now looked at the pictures and there is a large gap tween top yoke and the steering bearing system ....there also seems to be an upper washer missing, part 20??
using the exploded views, are the parts in properly, the lower distance piece and the 2 washers..........
note, are the fork headlight mount "tubes" and their rubber mounts in properly??
the gap seen in the last pic is too wide to account for any "compression" or "nip" of the headlight tube rubber dampers.....so that the headlamp is effectively "rubber mounted".....
good on you for the diagram, I will have to remember that location ( its in my little black book now ), perhaps it should be listed on here some where...what do you think admin?? :karma: ____________________ nuts about bikes |
The last post was made 11 years, 115 days ago. Instead of replying here, would creating a new thread be more useful? |
