| daifuco |
 daifuco Nova Slayer
 Posted: 11:28 - 03 Apr 2015 Post subject: Should I practice mod 1 manoeuvres on a 125? |
So as some of you know I failed my mod 1 (A license). I really didnt practice the U turn that much for a number of reasons... end then:
I got too nervous.
I didnt play well with clutch/gas
I focused on the line rather than on the exit...
Foot down!!!
Ok I have been on a 600cc before . I know the handling is much different. And I know that the clutch and gas feels different.
But I am considering to practice a lot on the 125 so I automatically do the right things and hopefully my brain just has to work a little bit compensating for the 600.
One of the good motorcycle training business around offers just a few hours of training and mod 1 on the same day (late afternoon) for a reasonable price, so I could use that time to get used to the big bike. (and they have a MT-07 so if Im lucky I could try one of the possible candidates once I pass)
My instructor said it was NOT a good idea to practice on the 125, but now I know they are awful. So I'd better ask BCF!. Should I practice on the 125?
It is mostly the figure of 8 and the u turn what I will practice. Leaving the others for the hours before MOD1 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:38 - 03 Apr 2015 Post subject: |
They're both motorcycles, physics doesn't magically change on a bigger bike. Not that an MT-07 is that much bigger than a 125 anyway.
Just practice with lots of revs and slipping the clutch. ____________________ Biking is 1/20th as dangerous as horse riding.
| NJD |
 NJD World Chat Champion
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| Acemastr |
 Acemastr World Chat Champion
| daifuco |
 daifuco Nova Slayer
| Teflon-Mike |
 Teflon-Mike tl;dr
| winz |
 winz World Chat Champion
| Acemastr |
| alex965 |
 alex965 Scooby Slapper
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 18:36 - 03 Apr 2015 Post subject: |
| Acemastr wrote: | Mike, I was under the impression that the turning of the engine actually provides centrifugal force, thus balancing the bike more. Worked fine for me so far! | Yup, and the wheels act like gyroscopes....
Its negligible to non existant... you get stability SIMPLY from moving.. at slow speeds you have little stability, ad slipping the clutch to try and 'under-drive' the bike slower than its stall speed, is actually robbing you of the stability that the force you are not transmitting to the back wheel might offer, as well as the momentum actually letting it run at the speed it can clutch out could give.The diamond cutters of motorcycle 'control' are trials riders and stunters; we DON'T 'slip and drag' to under-drive the stall speed; IF we need to make the bike go that slow, we down gear, so we CAN go that slow, under 'drive', and not have to jiggle three controls, in the motorcycling equivalent of patting your own head and rubbing your tummy, that is significantly JUST to satisfy a test examiner of your 'control dexterity'..
Twenty years ago, it was a cheap trick, to get frustrated newbies doing U-Turns on DAS bikes, it's actually so engrained now, as DAs has become the defacto route to big bikes, that ofte no-one knows any other way, to slow-speed manoeuvre, ad almost 'lore' the best way to effect 'fine slow speed control'.. in actual fact its an abandonment of control.. if you were in control you should be able to do it above stall speed, making it utterly un-necessary. If you cant? Then man-handle it, 'in full control' under leg-power to go that slow, with two feet adding support so you DON'T have to balance the damn thing. Don't fucking drag and slip!
...Except to make an examiner holding your pass cert in his hand happy!.... where all you need do is touch a lever enough to make the brake lamp stay on, and slip enough revs occasionally to let him believe you are patting your head and rubbing your tummy. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| daifuco |
 daifuco Nova Slayer
| NJD |
| daifuco |
 daifuco Nova Slayer
| NJD |
| Rogerborg |
 Rogerborg nimbA
| Barnoe |
 Barnoe Trackday Trickster
 Posted: 00:18 - 04 Apr 2015 Post subject: |
The problem most learners have with tight control is the fear of leaning the bike.
Keeping the bike as upright as possible is a skill in itself when doing sharp turns, but as a learner you will turn a lot easier if you use forward momentum and lean a little while looking where you want to end up.
If you need to slow the bike pull the clutch in, rolling the throttle off quickly during a sharp turn will make the bike unstabe.... you could end up putting a foot down :/
like everything in life... practice makes perfect.
If you ride correctly, the engine size and weight makes no difference..... if you ride like an idiot, smaller bikes are more forgiving to errors  ____________________ You know you are old when you're told to slow down by your doctor and not the police. |
| talkToTheHat |
 talkToTheHat World Chat Champion
 Posted: 07:03 - 04 Apr 2015 Post subject: |
When I was training for my mod 1, the site the training school used had some extra obstacles from the forklift people that also used the area, so the turn radius for the approach to the fast manoeuvres was very tight. Not a problem on the das bandits, but to achieve 50kph I learned how to get a pseudo-cruiser to skim pegs without catching my boot. Much noise made about the difference between needing to torture my 125 and the effortlessness of a 600, as 90kph through the speed trap was technically not a fault but makes the examiners really twitchy.
Some of the days course riders had their own 125s and were encouraged to practice on them, but the differences in acceleration and braking performance were noted.
A 125 is easy to catch if you topple at walking pace and is easier to pick up than a big bike, so work on your low speed manoeuvres, see how how tight you can get the bike turning and get comfortable with a bit of lean during low speed agility tests. You won't have anywhere near as much to think about getting on a big bike then.
When I did my cbt the year before, it had been ten years since I had been on a motorcycle and I had not been on a push bike for maybe 5 years. I had asked to split my CBT into sessions no longer than 2 hours due to my epic lack of health, and after the first session, was very pissed off with myself for having lost skills i knew I used to have. I was encouraged to try slaloms and figure 8s on a pushbike, so I sorted out the random junk bike living in the shed, cut some tennis balls in half, and after a few short sessions I had my balance and confidence back, and it transfered directly into my ability to ride a ybr.
You can learn useful skills with any two-wheeler. You won't get clutch control on a pushbike and a big bike needs a fine touch where a 125 needs wide open throttle, and in the case of my gz, a very firm braking hand, but where there are similarities, use them. ____________________ Bandit. does. everything. |
| daifuco |
 daifuco Nova Slayer
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
| Beehive Bedlam |
| Taught2BCauti... |
 Posted: 09:41 - 05 Apr 2015 Post subject: |
I'm actually quite good at 'U' turns - and weaving in and out of cones - it's just my personal preference not to do them myself on the road.
Watching other people do them badly on YouTube is enough for me  ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 15:02 - 05 Apr 2015 Post subject: |
| Taught2BCautious wrote: | Unfortunately, it's one of the hoops you have to jump through to get that ticket - but it's a manoeuvre that I would never attempt in real life. I would prefer to continue ahead to the next roundabout, or go around the block, than do a 'U' turn on the road. |
There are times it can be useful.... not sure 'essential', but certainly 'useful'.
I was up the Gt Orme in Landudno, last summer, looking for the ancient copper mines; coming in the 'wrong' way from town, of course I rode past the sign looking for the place & only my daughter on the back slapping me between the shoulder-blades made me look round to spot it!
Narrow, less than 2m wide, gravel strewn lane, on a bludy big hill.. nearest T-Junction to do a U-ie, half a mile up, and not much nicer, next roundabout three miles up, back at the bottom of the hill, in town... WHAT do you do?
Had a similar one, again with daughter on the bunny, going to a country park; mile down a narrow, gravel strewn, leafy lane, to find the pike gate across the car-park entrance at the bottom.. NO-WHERE to go BUT back the way we came... WHAT do you do?
U-Turns can be useful, and if you have the confidence to do one, possibly one of the better ways about it....
If not? Well, probably the most common answer is to do a 3-point... and why not?
Well, paddling is something you do at the beach, NOT on a motorbike... And far too many folk are LOATHE to get off the bike.
Paddling the thing backwards, you have one leg on the floor at a time propping you up, AND you are trying to use it to push the bike at the same time, AND look over your shoulder, its NOT stable and its not giving you good control, and you are as, if not more, likely to drop the buddy thing when you're one pushing propping foot slips on that shitty gravel or leaves, as if you tried riding through it in a powered U-Turn, feet-up!
GET OFF, man handle the bike round to where you want it pointing... get back on, ride off! Simples!
Its safe, its stable, its neat, it gives you THE most balance, THE best field of vision, and THE most control you can have to point the bike where you need it pointing.
And THIS is why the man-handling exercises are on the Mod 1! DSA don't REALLY give a shit whether you can get your own bike in and out of your garage on your own drive! Why should they? But, it is one of the 'better' ways to SAFELY manoeuvre a motorcycle, in 'full control' in a tight spot, at speeds slower than stall-speed in first, where the surface is 'iffy', and THAT is why its on the test.
And unlike 'Drag & effing Slip' man-handling IS a technique that you can and should use regularly; that IS very useful, and a bit of 'discipline' that used as routine, rather than 'paddling', can save a LOT of hassle and embarrassment!
Much under-utilised bit of technique, to my mind, but still.
(Yes, CAN be a bit embarrassing to ask a pillion to clamber off so you can do it.. but a DAMN site less embarrassing than apologising as you try and lift the bike off their leg, after mis-footing trying to paddle it!) ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| talkToTheHat |
| daifuco |
 daifuco Nova Slayer
The last post was made 11 years, 160 days ago. Instead of replying here, would creating a new thread be more useful? |
