2 stroke rattle noise
PostPosted: 21:14 - 05 Jul 2015    Post subject: 2 stroke rattle noise Reply with quote
There is a noise in the engine that runs with the rpm, when I rev, it ticks faster. I can also hear this noise when I ride. I have checked for slack in crank on both sides, changed piston, the conrodl and the whole clutch side. Also checked for engine mounts. It still runs normally and starts as usual. Can the main bearings be bad anyway? I'm starting to run out of ideas here .. Razz
sound:
https://www.youtube.com/watch?v=P4L8OUs6HK0
770
PostPosted: 21:23 - 05 Jul 2015    Post subject: Reply with quote
Vincent wrote:
Piston slap?
Little ends?
Mains tend to make more of a rumbling noise. Yours deffo sounds like top-end from where I'm sitting.
There was no play in the rod, and I also replaced the piston bearing when I was inspecting it.
770
PostPosted: 21:35 - 05 Jul 2015    Post subject: Reply with quote
Vincent wrote:
Maybe you should take the top end off again and make sure the circlip hasn't come out or a ring snapped.
This noise was there before I changed the piston
770
PostPosted: 08:15 - 06 Jul 2015    Post subject: Reply with quote
Vincent wrote:
Are you sure it isn't something vibrating on the outside of the engine?
Yes, and it is coming from the bottom end. But there is no slack on either side of the crankshaft. The sound is always there, either I am in neutral or in gear with clutch in. I have checked the ex valve system, the balance shaft.
heres a new vid where you can hear pretty well when driving, the sound has become louder after each ride.
https://www.youtube.com/watch?v=dpAEE_8D3HE&feature=youtu.be
770
PostPosted: 11:34 - 06 Jul 2015    Post subject: Reply with quote
mpd72 wrote:
A couple of options. Firstly, if you changed the small end bearing, what about the gudgeon pin? I normally change piston, rings, small end, pin and circlips at the same time.
Also, has it been rebored? On some engines with high squish, the standard size head gasket needs honing out a bit to match the size of the over bored piston, or the top end of the piston can catch it.
Main bearings are normally more of a knocking, rumbling noise than that.
When you changed the piston was there any damage? A small piece of ring may have ended up in the crank and has now found it's way up to the combustion chamber through a transfer port and is now merrily bouncing about.
Yes, new piston so new rings, small end bearing, pin bolt and circlips. There is no head gasket kinda, there are just 2 O-rings. The old piston and ring had no damage itself, but it was getting black beneath the ring.
770
PostPosted: 12:46 - 06 Jul 2015    Post subject: Reply with quote
mpd72 wrote:
So it's on standard bore then?
No it has been bored up and I am using the correct piston size
770
PostPosted: 13:17 - 06 Jul 2015    Post subject: Reply with quote
an O-ring head, so obviously no change there, but squish on a peaky engine like that will be pretty tight. A slightly thinner base gasket could lower the barrel enough so the piston touches the outside of the squish band. [/quote]
Maybe you could poke a bit of solder through the plug hole so it touches the edge of the barrel and turn over by hand to measure the squish in 2 or 3 places around the top of the bore?[/quot
It's a Husky 125cc, I think they only sell one kind of base gasket.
The noise suddently came after a ride, not after a rebuild. 4000km ago the crankshaft, bearings, piston were changed.
bikenut
PostPosted: 13:28 - 06 Jul 2015    Post subject: noise Reply with quote
seen video but no audio here........our computer......
1.does it make the noise if the flywheel cover is off??
2.is anything under the flywheel touching anything else??
3.how about on the primary drive side, anything in there involved with the crank touching anything else, apart from gear teeth to gear teeth or balance system?
4.sure its not an exhaust leak?
5. reeds?
6.did you check for "bump clearance"? yes I know its a petrol engine but still?? Karma
nuts about bikes
770
PostPosted: 14:12 - 06 Jul 2015    Post subject: Reply with quote
Vincent wrote:
If you're sure it's not the top end, and it's definitely coming from the bottom, I suppose it has to be the main bearings as there's not much else down there. I suppose with a smaller engine, main bearing wear may sound a bit less "rummbly".
Where is the water pump?
The water pump is located on the right side beneath the primary drive. I checked the waterpump by turning it with my finger when I was inspecting the right side of the engine, where I checked the crank and the clutch.
770
PostPosted: 14:16 - 06 Jul 2015    Post subject: Re: noise Reply with quote
5. reeds?
1. yes
2. no
3. I have taken off the whole clutch and inspected the whole right side, I have also taken off the flywheel and tried to jiggle the crank, there's no slack.
4. The noise is definitly from the engine
5. Just checked them, they are in good condition.
6. I don't think that's possible since I have been riding a long time without any noise like this, it suddently came after a ride.
bypass2
PostPosted: 17:18 - 06 Jul 2015    Post subject: Reply with quote
What about your clutch basket loose pull the clutch in then rev it a few times see if it still happens. engine chain sprocket loose.
bikenut
PostPosted: 11:34 - 07 Jul 2015    Post subject: noise Reply with quote
not able to hear the audio......
do you reckon the noise is at crankshaft speed??
does it make the noise if the engine is off but bike is pushed along in gear? with plug out?? and ign killed..
nuts about bikes
bladerunner
PostPosted: 23:39 - 07 Jul 2015    Post subject: Reply with quote
just for interest..did you actually measure the piston and bore to work out the clearance?
770
PostPosted: 10:41 - 08 Jul 2015    Post subject: noise Reply with quote
The bike felt like it was surging, when I was going to clutch out from first it sounded like I needed to choke it. When turning it off I heard this squeaky noise, and everytime I kickstart it this squeak comes and the engine stops after a few seconds..
I have already checked clutch, piston, conrod, flywheel. Basically everything you can check without splitting.
VIDEO
https://youtu.be/VcQao433GjQ
The last post was made 10 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 127.94 Kb
