| c058y |
 c058y Nova Slayer
 Posted: 21:57 - 27 Jul 2004 Post subject: Electrical Problems on NSR125R! ***FIXED*** |
After striping down the bodywork and doing a major clean of the whole bike I began putting it back together again. Before I got started I thought I'd just check the thing still works.
You will never guess what? It doesn't!!!
I'm pretty sure there is something wrong with electrics. The battery is fully charged, I'm sure of that. I have checked most of the connections, mainly the ones under the fuel tank and airbox, unfortunately no response.
Picture this, I turn on the ignition and nothing happens! No lights, no nothing! Not even the little black box (exhast valve?)to the right of the carburetor doesn't turn round!
Any ideas? Main areas to check? Fuses?
Please help!!!!
Thank You in advance!
c058y
| tatters |
 tatters Exxon Valdez
 Posted: 22:05 - 27 Jul 2004 Post subject: |
check your main fuse, located in the wire running from the positive of the battery.
if the thin wire in side that glass tube of the fuse is broken the fuse has "blown" so replace with a new one all car shops/homebase etc sell them just state the rating (amps) ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV
| alains |
 alains World Chat Champion
| tatters |
 Posted: 22:11 - 27 Jul 2004 Post subject: |
just to note, don,t short the fuse carrier out with cable, the fuse is there to protect the bikes circults and by shorting out could cause the wiring loom to fry,
and when you remove the battrey ALWAYS REMOVE THE NEGTIVE first on jap bikes before the postive, because the frame is negtive and you don,t want the postive to make contact with the frame (other way round for classic british bikes which postive is the frame) ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| c058y |
 c058y Nova Slayer
| tatters |
 Posted: 22:23 - 27 Jul 2004 Post subject: |
could be the CDI, l,ve had it before on a NSR125R, not sure how to check it l just changed mine over and it worked,
wd40 on connections, and checking supply to the ingestion with a multi meter is all l can suggest ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| alains |
| c058y |
 c058y Nova Slayer
| tatters |
 Posted: 22:33 - 27 Jul 2004 Post subject: |
you would got a spark and the fuse would of blown if the postive made contact with the frame, so unlikey, ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| alains |
This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
| tatters |
 Posted: 22:44 - 27 Jul 2004 Post subject: |
its is a basic safety precaution to remove the positive first to prevent damage to the electrical system, and especaily on a motorcycle which is a Zone 1 area with petrol involed.
by the way l,m a Zone 0 quailtyed electrical engineer and have worked in numerous explosive enviroments ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| c058y |
 c058y Nova Slayer
| Jammy-G |
 Jammy-G Banned
| c058y |
 c058y Nova Slayer
 Posted: 00:38 - 28 Jul 2004 Post subject: |
This may sound silly, but how do i check if has been earthed correctly? Where do i check?  |
| alains |
| Jammy-G |
 Jammy-G Banned
 Posted: 11:59 - 28 Jul 2004 Post subject: |
On my bike, I'm not sure about others, it earths through the frame.
My bike has a negative earth, so the negative wire from the battery connects to the frame.
Check where the negative wire from the battery goes, or if you can't see, run a new dummy wire from the negative electrode on the battery to a main part of the frame. (Metal part ) ____________________ RooRoo: just like the time i stuck my finger up my arse with no lube at all and she didnt talk to me for hours |
| c058y |
 c058y Nova Slayer
 Posted: 21:23 - 28 Jul 2004 Post subject: |
| Quote: | take a piece (1 foot) of insulated cuper wire , take off a bit of insulating at each end , then stay in contact with the + at one end and with the other end scrap on the negative , if no sparks your battry is dead or discharged
let me know about the results |
Alains, I tried this today with a piece of copper wire and sparks were created, so in theory there is still power in the battery, but still not starting.
I have bought a multimeter off ebay today so I will see how much power the battery is giving off by the end of the week.
| Quote: | Check where the negative wire from the battery goes, or if you can't see, run a new dummy wire from the negative electrode on the battery to a main part of the frame. (Metal part ) |
Jammy-G, the negative wire runs in to the wiring loom never to be seen again. I ran a dummy wire with another piece of copper wire from the negative terminal to the frame, but still no joy.
Thanks for all your advice so far.
If you have any ideas just let me know. I CANT let this beat me
c058y |
| swampy |
 swampy World Chat Champion
 Posted: 23:04 - 04 Aug 2004 Post subject: |
I had exactly the same trouble on my nsr, it turns out that there was a corroded connection in the loom where two live wires join into a single live wire. (i found this by wiggling the loom more in hope than expectation, and suddenly the lights came on, and went off when i wiggled a particular bit.) I opened the tape on the loom, chopped out the bad bits, and soldered in a new piece of wire, and it seems to be ok now touch wood.... hope this helps  |
| stinkwheel |
 Posted: 23:49 - 04 Aug 2004 Post subject: |
You don't have the kill switch on do you ????
Whilst we are on dumbass things. You have the plastics off right? This would include the entire front fairing which includes the headlight and flashers along with a variety of other bits of wiring that would normally be connected to the bike??
The japanese are buggers for earthing vital circuits through stupid places (like brakelights and horns). Also in removing the plastics, you sure you haven't dislodged something behind the clocks/dash? It is most likley going to be in the part of the circuit taking power to the ignition switch from the battery to make EVERYTHING fail.
Another place to check is the starter solenoid (follow the big fat wire from the battery positive, it will attach to the top of the solenoid). Many bikes run all the power to the rest of the bike through this area and the terminals do corrode, some (not sure about your bike) also have a fuse on them.
Look round the headstock and under the tank for signs of the loom rubbing through ant trapped wires under any bits you have put back on.
You may land up with everyones favourite....pulling the connectors apart one at a time, cleaning them with emery paper and reassembling with a smear of copper grease...takes a long time!
Whatever you do, if you pull something apart, put it back together before taking some other bit apart and forgetting where everything goes. Otherwise if you take it to a sparky at a later date, they will kick your arse for you. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| c058y |
 c058y Nova Slayer
 Posted: 20:29 - 05 Aug 2004 Post subject: |
Thanks for all your help guys!
I still haven't managed to fix the problem. The only thing left to check would be a loose connection within the loom. Unfortunately not enough hours in the day
Well it looks like my mechanic is gonna have a search on his hands!
By the way I didnt have the kill switch on!
Once again I thank you for all your help!
I'll put up a post after my mechanic has figured out whats wrong. It better not be something really stupid.
Cheers all
c058y |
| Honda_nutter |
 Honda_nutter L Plate Warrior
| c058y |
 c058y Nova Slayer
The last post was made 22 years, 29 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.64 - MySQL Queries: 14 - Page Size: 122.56 Kb
