| ultraculture1... |
 ultraculture1... Two Stroke Sniffer
 Posted: 18:25 - 11 Aug 2015 Post subject: Honda NS125R-L 1993 Resto project |
Soooooo, I ambitiously thought I could fix up this battered old NS125r after swapping it for a speedfight moped, I first thought it was the pre fox eye NSR but on further investigations (Logbook/google) I found it was the power valveless NS135R, all of which is pure digression.
I do not know where to start in fixing her up so any advice would be greatly received, Firstly and foremostly, she wont start, kicks over but i suspect many things, lack of spark, fuel blockage and carb issues mostly, followed by head gasket and other compression issues.
My main problem is lack of specialist tools, parts and knowledge.
I may just see if I can swap her for a runner and let somebody with more time and experience have a go....any offers? |
| stevo as b4 |
| Kickstart |
 Kickstart The Oracle
| ultraculture1... |
| ultraculture1... |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 23:46 - 05 Sep 2015 Post subject: |
you sure the plug cap is making a good connection with the lead? ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| Vincent |
 Vincent Banned
| ultraculture1... |
 Posted: 15:06 - 07 Sep 2015 Post subject: |
Thanks for replies, and apologies for my piss poor typing.
So to answer no, im not sure its connecting, I dont like the screw in idea, there is no way if being sure. Somebody advised me to get a dyna tech ignition or something similar. They aren't cheap mind.
Somebody gave me a different old spark plug to try in the cap and it was from a cortina fitted the bike too, didnt kick it over though incase it hit the piston.
As is the case with this bike the more I progress the more I find that's wrong. The front brake, master cylinder? Am I right in calling the reservoir for brake fluid this?
Its no good, one of the screws that tightens it is sheared off half way down so it is still kinda usable but not gonna pass mot.I filled it with dot4 and no pressure. Caliper seems to be missing a bleed valve. I will try and post pics. Im going to keep this thread going through the rebuild
So im hoping once I get this ht lead issue sorted it will start, then I look at clutch and brake issues. |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 16:46 - 07 Sep 2015 Post subject: |
it is a master cylinder, if its knackered try drill it out, if you cant then they aren't massively expensive to replace.
bleed nipples are available online everywhere for about £5..
if its missing a bleed nipple then it wont build up pressure.
as for sparking issue, cut a little off the lead, screw the cap on and push your plug in, some spark plugs have a little bit on the top that screws in, youll find you will probably have to remove it so unscrew it, when you push the plug cap on it should click on the way in...
https://i.imgur.com/KTaJFZy.png
once thats all done put it against your frame, bare unpainted metal and hit the starter to see if it sparks...
if it sparks then job jobbed.
if not then throw your tools out the pram and go back to the old cap to see if that works. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Jelle |
 Jelle L Plate Warrior
| Pol Anorl |
 Pol Anorl Banned
 Posted: 21:18 - 07 Sep 2015 Post subject: |
the ohms wont stop it running itll spark faster and shorter with 5k and cause interference.
fit 5k ride up and down the road messing with people televisions  ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| ultraculture1... |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 17:25 - 09 Sep 2015 Post subject: |
needs to be against the frame or on the engine if unpainted ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Vincent |
 Vincent Banned
 Posted: 20:41 - 09 Sep 2015 Post subject: |
The spark plug needs an earth to work. If you're near enough, it'll go through you  ____________________ Space Is Deep |
| Pol Anorl |
 Pol Anorl Banned
| ultraculture1... |
| ultraculture1... |
| alains |
 alains World Chat Champion
The last post was made 10 years, 357 days ago. Instead of replying here, would creating a new thread be more useful? |
