no revs showing
blahheed
PostPosted: 17:53 - 03 Dec 2015    Post subject: no revs showing Reply with quote
tdm850
tacho is not working,
checked connections
anybody had this problem before?
Big
WD Forte
PostPosted: 18:51 - 03 Dec 2015    Post subject: Reply with quote
Not on a TDM but I did have to sort a VFR with a tacho dropping out twice.
First was a track broken on the plastic film pcb inside which I bridged with fine wire and delicate soldering
Months later it dropped out again and after I checked my bridge repair
on the pcb hadn't failed
I traced/tested cables and found the connector on the ignition unit plug was faulty.
perhaps you have a simlar problem?
HTH
bikers smell of wee
stickybackbob
PostPosted: 20:24 - 03 Dec 2015    Post subject: Reply with quote
I had a TDM with this problem many years ago. In my case it was a bad soldered joint on one of the resistors in the tacho. Re-soldered it and worked perfectly after that.
The last post was made 10 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.55 - MySQL Queries: 14 - Page Size: 34.4 Kb
