VFR400 NC30 Electrical funzies any help appreciated
 Topic moved: from General Bike Chat to The Workshop by stinkwheel (20 Dec 2015 - 23:30)
mattevans58
PostPosted: 00:10 - 21 Dec 2015    Post subject: VFR400 NC30 Electrical funzies any help appreciated Reply with quote
Hey guys,
I've been overhauling this NC30 I've had for a while now and I got it all up and running again but had a flat battery so I hooked up the charger and stupidly ran the bike with the live charger running. I've now got no lights on the bike however the headlight works, pass light and the bike starts on the button (which in relived about). However the indicators, brake light, oil and neutral light in the dash don't come on anymore. I'm presuming from what I read it's the Regulator/rectifier that's blown?? Although when it comes to electrics it fries my brain...
So if anybody has an suggestions I'll be greatly appreciated!
Cheers[/b]
PostPosted: 00:32 - 21 Dec 2015    Post subject: Reply with quote
I'd check your fuses first off.
What you describe is not consistant with a reg/rec failure. That would pretty much just stop the battery charging (or make it overcharge).
I can't think how leaving a charger attached then starting the engine would damage the reg/rec. Damage to the charger would be more likely.
mattevans58
PostPosted: 00:44 - 21 Dec 2015    Post subject: Reply with quote
Because I'm such a novice at electrics what should I look out for? How do I know if a fuse is blown? Is the U bend within the fuse still whole or will it split breaking the connection?
Cheers for your help so far
PostPosted: 00:55 - 21 Dec 2015    Post subject: Reply with quote
Pull them out one at a time and look at them side-on against a light coloured background.
I'm assuming they are blade fuses.
As you say, if they are blown, you can usually see a break in the metal loop but do pull them out to look properly.
mattevans58
PostPosted: 16:39 - 21 Dec 2015    Post subject: Reply with quote
Mate you made my day! It was 1 broken fuse and got it replaced for 39p! Bought a few spares of each whilst I was there. Think I got 5 of each fuse for the entire bike less than £10. Thanks again!! Very Happy
The last post was made 10 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.02 - MySQL Queries: 17 - Page Size: 45.2 Kb
