 Tristan_NSR L Plate Warrior
 alains World Chat Champion
 Posted: 12:02 - 24 Dec 2015 Post subject: |
check the choke piston and the cable
Under the choke is a robber bit which close the air passage and it could be worn (look dellorto site for 28PHBH spares change piston and spring)
also if the cable is dirty or with sharp bends it may make the choke stocked
if your starter get stocked it has nothing to say with the carb , so check the starter relay then your starter itself
download https://www.geneva-racing.ch/~alains/NSRtips.doc (~5Mo) and follow instructions on starter rebuid
any spares are avaiable at davidsilverspares.co.uk (brushes & springs) ____________________ the worst day fishing is better than the best day working |
