| Ariel Badger |
 Ariel Badger Super Spammer
| stinkwheel |
 Posted: 00:14 - 28 Feb 2016 Post subject: |
Yes. But be aware, depending on material, the temperature the solder flows and the temperature the aluminium sags into a puddle can be very close together.
Last time I used it, I found the biggest problem was getting enough heat into the piece over a wide enough area. I set a bigger blowlamp with a wide flame running over the whole piece then used a micro blowlamp to heat the area I was working on. Keep the flame moving to avoid meltiness.
Now with your third and fourth hands apply the solder and guddle it about with the stainless wire...
Would it not be better to get someone to TIG it up then you can file it back?
I've used lumiweld to solder two red bull cans together to make a micro-alcohol stove and I've used it to build up the bit on a brake lever that pushes the light switch. I've heard of it being used on crankcases but never tried it myself.
Not a great picture of the stove (old phone camera) but that's a 1p next to it.
https://i48.photobucket.com/albums/f216/stinkwheel/Image003.jpg
A tad too much heat on the first attempt. When it goes, it goes quick!
https://i48.photobucket.com/albums/f216/stinkwheel/Image004.jpg ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Ichy |
 Ichy World Chat Champion
 Posted: 00:19 - 28 Feb 2016 Post subject: |
I still have some in my garage, somewhere. I agree with Stinkwheel. The point of getting it to bond is about the same temperature that the piece you are trying to fix starts melting. I must admit to using a great big torch but a smaller torch would not put enough heat in the part. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| temeluchus |
| Ariel Badger |
The last post was made 10 years, 219 days ago. Instead of replying here, would creating a new thread be more useful? |
