Honda NSR 125 ignition wires and switch
nsr_J22_FOXEYE
PostPosted: 10:16 - 10 May 2014    Post subject: Honda NSR 125 ignition wires and switch Reply with quote
So I have a broken ignition barrel .
I have taken away the 4 wires
we have. BLACK, BLACK and WHITE , RED , GREEN
Can we label these for me, I have my assumptions but all the help is needed on this repair (more to fall down the hole in in)
Also can you let me know what the ignition barrel connects or disconnects ? is it a multi switch or 3 wire switch. All information will be made use of, but please don't tell me how your "sv 650" used to wire up. Alain or other nsr twinkers please let me have your 2 cents.
Sorry I have not posted in a while, boobies got in the way of the screens but its all good now.
Never Ride Faster Than Your Angel Can Fly
alains
PostPosted: 19:19 - 10 May 2014    Post subject: Reply with quote
red is +12V switch entry coming from battery
black is +12V switch exit to bike feeding
black/white is +12V switch exit to services
green is -12V to bike & services feeding
nsr_J22_FOXEYE
PostPosted: 20:56 - 10 May 2014    Post subject: Reply with quote
bonne soirée Alain, vous me manquez.
what does the key switch acheive? I have a new barrel on order, need to replicate the key switch
alains
PostPosted: 09:34 - 11 May 2014    Post subject: Reply with quote
to establish voltage from battery to the bike except the ignition which is totaly independent (you can run the engine without any power)
nsr_J22_FOXEYE
PostPosted: 12:06 - 11 May 2014    Post subject: Reply with quote
I noticed the bike didn't need power. bad design
With what I can see the switch connects the black and red for ignition ?
but what with the green and black/white?
I have to simulate the key switch before I can chase and earth further down the line. at the moment I need to solve 1/2/3 and then i can go to check 4+ in this list
1, key switch
2, start switch
3, ignition circuit breaker
4, rectifer/regulator
5, servo motor of the exhaust valve
6, oil level sensor
7, Rear brake switch false
8, Turn signal relay
9, control box of the exhaust valve
10, starter relay
11, Flashing back right
12, red lights and stop
13, Rear left turn signal
14, switch on side stand
15, electric starter
16, main fuse (15A)
17, Diode
18, Diode
19, Neutral Switch
20, Battery
21, alternator
22, sensor lighting (pickup sensor ?)
23, temperature sensor
24, ignition box (ecu)
25, ignition coil
26, mass frame (earth)
27, safety switch on handle clutch
28, Left handlebar controls (from left to right: buzzer, Call Lighthouse, blinkers, Inverter code beacon)
29, horn
30, front left turn signal
31, Headlight and side light
32, headlight and side light
33, Dashboard (1, Temp gauge, etc etc)
34, flashing right front
I find the chair leader and the world will be safe... earth being the chair leader and the world being my nsr and safe being working (wont make sense in French )
nsr_J22_FOXEYE
PostPosted: 16:28 - 11 May 2014    Post subject: Reply with quote
all sorted after 2 hours studying the electrics diagram
Many thanks ( closed )
There is a gap of 1 year, 311 days between these two posts...
NSRJIM
PostPosted: 13:07 - 18 Mar 2016    Post subject: Reply with quote
Hi can anyone put a pic of the wires onto the back of the ignition barrel mine have broke off and need to know what wire goes where
The last post was made 10 years, 225 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.22 - MySQL Queries: 14 - Page Size: 51.59 Kb
