Honda h100 g reg where does the pipe go from carb to oil bot
richiemac
PostPosted: 14:23 - 05 Apr 2016    Post subject: Honda h100 g reg where does the pipe go from carb to oil bot Reply with quote
Honda h100 g reg where does the pipe go from the 2 stroke mixture tank to the carb as there is 2 spaces for piping to go on 1 at the very bottom of the carb and 1 on the right side of the carb?
PostPosted: 15:09 - 05 Apr 2016    Post subject: Reply with quote
The oil goes from the oil tank to the oil pump. Then a second pipe goes from the oil pump to a stub on the side of the carb near the inlet manifold.
You should prime and bleed any air out of the pump before running. There will be a procedure for this in the workshop manual.
stickybackbob
PostPosted: 19:22 - 05 Apr 2016    Post subject: Reply with quote
Having worked on a much older H100 (the 'A' model), the oil pump doesn't feed directly to the carb. There is a stub on the inlet manifold that connects to the pump. Not sure if it changed on later models
richiemac
PostPosted: 07:28 - 06 Apr 2016    Post subject: where is the oil pump? Reply with quote
The last post was made 10 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.47 - MySQL Queries: 14 - Page Size: 38.64 Kb
