Life expectancy
MC900
PostPosted: 21:25 - 05 May 2016    Post subject: Life expectancy Reply with quote
How many miles should we expect a well maintained 125 like a ybr last for? Is it right to expect one to reach at least 60k without any major problems?
Apart from things like tyres and brake pads etc what things usually go wrong with bikes when their time is up? Cheers.
Current Ride: Fazer 600 (02) & YBR125 (07)
pepperami
PostPosted: 21:35 - 05 May 2016    Post subject: Reply with quote
If you maintain it well and treat/ride it well with all the lube and all consumables done at the right time, I reckon 60K should be easily achievable.
It`s abuse and lack of maintenance that kills bikes.
PostPosted: 22:22 - 05 May 2016    Post subject: Reply with quote
Sable put 42,000 miles on his Chinese Sinnis Trackstar before the engine cracked, the oil escaped and it seized, I believe after being dropped.
Hong Kong Phooey
PostPosted: 00:24 - 06 May 2016    Post subject: Reply with quote
Modern oils means plenty of cars reach 100k miles plus, better odds if the oil is changed regularly. Cam belts snapping or timing chain skipping usually finishes them off.
It's a typical bell curve gamble as to how long each engine will last, and the deciding factor on the funeral date for it is purely economics.
Allegedly a CBR600F4 clocked 200K miles on same engine.
Guest
PostPosted: 00:56 - 06 May 2016    Post subject: Re: Life expectancy Reply with quote
2 strokes are a more simple design than 4 strokes with a lot less moving parts, 4 stroke valves/cylinders/heads/cam chains cost a lot of dosh Thumbs Down 2 stroke crank main/big end/small end bearings/seals/piston/cylinder kits cost less than £120. 2 smokers last a long time between rebuilds as long as the owner doesn't install a high rpm race pipe or mess with the cylinder's porting.
Buy a fun 2 smoker Thumbs Up & use the YBR for boring weekly shopping trolley trips.
Dave70
PostPosted: 01:11 - 06 May 2016    Post subject: Reply with quote
My R125, which I believe (could be wrong though) has the same engine as the YBR, only got to 30,000 miles before somehow (unbeknown to me) losing its oil in less than 300 miles one day. This lead to a very unhappy engine that didn't want to work anymore and tried to take me out in the process.
That bike had been very well looked after. It had a few more services than recommended and regular oil changes, more often than not, before the recommended 1,800 miles too.
However, there's a lot to be said for checking you oil level before every ride. Embarassed as I'd have noticed there was an issue before it was too late. Instead I got complacent in knowing it would only need a small top up between 800-1000 miles.
I should probably add that it had been ridden pretty hard too over most of those miles.
Not sure if any of that helps actually, as I seem to have gone off on a bit of a ramble there. Laughing
is Tefs disease contagious? Shifty
Guest
PostPosted: 01:19 - 06 May 2016    Post subject: Reply with quote
https://www.youtube.com/watch?v=tCgccVdghS0 Laughing Thumbs Up
temeluchus
PostPosted: 01:33 - 06 May 2016    Post subject: Reply with quote
I passed my test on a cg125 with 87k on the clocks. Original everything barring service items according to the riding school.
mentalboy
PostPosted: 01:35 - 06 May 2016    Post subject: Reply with quote
Dave70 wrote:
My R125, which I believe (could be wrong though) has the same engine as the YBR, only got to 30,000 miles...
Mebbe it blew up early because someone shoved a couple of extra valves in it? Laughing
Dave70
PostPosted: 01:39 - 06 May 2016    Post subject: Reply with quote
I'll get me coat. Shifty Embarassed
Sable
PostPosted: 08:23 - 06 May 2016    Post subject: Reply with quote
That thing was dropped, thrown and slung down roads. Mr. Green
It was the sump plug plate that cracked. It is possible one of the little bolts holding it in came loose and the vibration caused it to crack. I can't say I really remember checking the bolts. That was about a year ago that happened... Poor Trackstar. Sad
The good part of the Trackstar was, up to that point, the bike was mostly trouble free.
PostPosted: 08:42 - 06 May 2016    Post subject: Reply with quote
And even parted, scrapped or just left in a ditch, the cost-per-mile would have worked out well.
I'd bet on a Chinese Jianshe-Yamaha "YBR 125" lasting longer than an Indian HMSI Stunner "CBF125". But I'm perhaps just being selectively racist.
B5234FT
PostPosted: 09:52 - 06 May 2016    Post subject: Reply with quote
It depends what you mean by 'dead'.
Sure it may need a new set of rings, or some bearings, but provided these are replaced before bits appear through the crankcase, I see no reason why it shouldnt run almost indefinitely tbh.
Likewise the rest of the bike, it might be economically 'dead' when the swing arm bearings, head bearings and all the cables are failing, but they can all be replaced. Barring a bant or rusted frame.
I bought my current car when it was 'dead' at 110k miles. It's done 190 now, but then I've replaced things like wheel bearings, dampers and bushes, which most nimbys regard as lifetime components.
mentalboy
PostPosted: 12:30 - 06 May 2016    Post subject: Reply with quote
This isn't a car thread, so I'll apologise for being off topic!
Modern cars are barely run in by 100K (IMHO) I'd be pissed if my tiddly UK motors weren't capable of 250K - which is what I managed to get out of my crappy Citroen before selling it on.
My stepson's Ford SUV is over 400K and still running....
Look after your motors and they should last longer than if you don't. With the availability of spares for small 125's it should be possible to get big miles out of them, even if that means replacing everything except the frame over it's lifetime. Whether you can justify the costs against running a machine into the ground is another matter!
woo
PostPosted: 13:01 - 06 May 2016    Post subject: Reply with quote
its not expensive to have a single clinder 4 stroke 125 engine taken apart and parts repaired or replaced but a 4 clinder 4 stroke engine is another kettle of fish and can be costly if taken to shop.
i keep hearing rumors that the R125 engine is not a great engine interms of longivity but again these are rumors which i have seen no facts of.
my msx 125 is a walk in the park to repair and does not cost anywhere near as much as others (so long as i stay away from main dealers) if i ever have engine trouble
I hope i have this bike forever, cos if Ed March can do 700miles on a honda c90 with no oil then theres hope for us all
Elen sila lummen omentielvo!
B5234FT
PostPosted: 13:19 - 06 May 2016    Post subject: Reply with quote
This is my point, most people do the bare minimum oil changes and then when the car gets to 100k it needs springs, dampers, bushes, joints, bearings and so on all at once.
If you maintain things properly (preventitively) then they last almost forever. My bora is on 190k and tbh it will probably do the same again, but I'm bored of it after 100k so it's going to be someone elses soon.
So back to bikes:
If you buy a cheap 125 and do the bare minimum it will die eventually. If you buy it and look after it properly and replace things before they fail catastrophically then the same applies. People are suggesting 36k out of the engine? I'd expect to get that out of the chain.....
spottedtango
PostPosted: 14:04 - 06 May 2016    Post subject: Reply with quote
No ones considering design differences of the engines.
A 125cc air cooled 4 stroke can't be compared to a large liquid cooled 4 stroke car engine or even a larger liquid cooled 4 stroke bike engine for that matter.
Problem #1 Air cooled bikes can't effectively regulate running engine temperature as liquid cooled engines can. Liquid cooled engines have thermostats,fans and more effective cooling system than air cooled engines due to waters better thermal conductivity.
Problem #2 A 125cc 4 stroke will see full load more often than a larger car or motorcycle engine. This on top of the ineffective cooling will wear the engine faster.
Problem #3 Oil changes must become a religion for an air cooled motor to reach higher mileages due to air cooled engines being harder on their oil due again to problem number 1 as the engines may see much higher temperatures and the fact air cooled engines rely on the oil to cool the engine.
Problem #4 Air cooled engines are machined with larger tolerances due to the range of temperatures the engine will encounter due . This means a less efficient engine and in turn less bhp per cc. The larger tolerances are to account for the metal expansion due to the increased range of temperatures the engine will see.
The comment about 2 strokes is far to generalised. Two strokes have less moving parts yes BUT they don't have a good lubrication system.
Two stroke bearings see much less oil than their 4 stroke counter parts. Petrol is also a solvent and it isn't particularly a great thing to have bearings exposed to.
There's also no need to rebuild just buy a new engine, usually works out cheaper.
60k is a big ask for that type of engine. Id say it would probably start burning quite a bit of oil before then.
B5234FT
PostPosted: 14:50 - 06 May 2016    Post subject: Reply with quote
Yes, but provided you keep it in good oil and change the piston/ring before it destroys the bore and takes the cam and crank bearings with it there is no reason why it wouldnt continue to run.
Im perfectly aware of all the differences and issues, but IMHO the biggest issue is that people see the oil consumption increasing and either forget to top it up and lunch the engine, or decide it's 'dead' and get rid of the bike rather than spending a saturday afternoon sorting the issue.
Teflon-Mike
tl;dr
PostPosted: 17:11 - 06 May 2016    Post subject: Re: Life expectancy Reply with quote
Maintenance = 'Maintaining the Functional Condition of the Machine'
Maintenance isn't just changing the oil and adjusting the chain and tappets... it would include doing re-bores when required, replacing cam-chains, renewing bearings, valve guides, or even when the copper has oxidised too much and the insulation gone so hard wires start breaking, completely re-wiring the electrics.
So, if you apply the strict definition of 'maintenance', a machine that is properly, well or even just sufficiently 'maintained' ought to last indefinitely.
In the real world, though, few if any vehicles let alone motorcycles, let alone 'budget' commuters ever are, when economics comes into play.
A bike is 'Beyond Economical Repair' when it is cheaper to buy another one, than fix any faults it has to 'maintain' it's functionality.
Labour cost of tearing down an engine to over-haul and re-condition it, in the UK even on a 'cheap' and simple engine like an air-cooled push-rod single like a CG125 motor, would usually be guaranteed to render a bike BER; you are talking maybe 10 hours of £30 per hour labour, plus maybe as much again in 'parts' depending on how much you need to replace. But £30-40 for a re-bore and as much again for a new piston & rings; add gaskets, possibly a ew cylinder head if it's cheaper than milling out ad replacing valve guides, and you could be looking at a £500 bill for that bit of 'maintenance' on an old bike probably not worth that much to start with.. so it can only be 'economically' maintained if you don't cost the labour ad DIY the job, or cut corners and put in a better 2nd hand engine or whatever.
Manufacturer's typical 'service life expectancy' of a 4-Stroke 125 commuter, is about 7 years, and perhaps 50,ooo miles.
They don't expect it to be assiduously 'well maintained'; they expect it to be 'economically' maintained, and it will only probably get eve that for the first year or two of the warranty period, or if lucky the first 3 years until the first MOT is due, and the bike likely to retain half its show-room sticker value. In that time, its likely to only cover 30,000 miles or so, and the odds that it will run reliably and not develop an expensive fault are in its favour. After that? Well, they probably don't care very much! But owner use ad maintenance will be far more significant as to how likely a 'problem' is to develop.
Buy a bike brand new; treat t well. Don't thrash it, be reasonably diligent in maintenance, and good chance you can avoid major or expensve issues for perhaps, 30 or 40 thousand miles or more, before you reach the point where more expensive 'maintenance' is probably required.
If thrashed, trashed or crashed? Its any-ones guess how long it might last.
A little air-cooled 125 in daily city commuter service, is likely to be pretty hard used. It will be accelerated hard (relatively) up and down the gear-box, changing speed between junctions and traffic lights and round-abouts, the suspension hammered by heavy braking dodging the SMIDSY's or weaving between queues of cars.. ad the rider on board, is likely to not be the most sympathetic; a learner who isn't too smooth or delicate to start with, and/or a commuter, who is more concerned with getting to work on time, than riding 'finesse'.
Under that sort of 'stress', a little 125 4T single, is likely to be doing pretty well to clock more than 40K miles before it's getting rather tired, and cumulative 'maintenance' threatening it's chances of staying out of BER, even if it is better looked after. Engine might not be so close to ding a full overhaul at that sort of miles, but brakes and suspension and transmission, are likely to do for it instead.
It's a piece of string question, to which there is no answer, really.
BUT, bought new, and well cared for, the rider applying more than typical mechanical sympathy both n riding and maintenance, I could say a YBR could reasonably be expected to last ten years, 50K miles or so.....
I have seen or heard of very few 125's or any sort that have ever managed to clock anything in that region though, that haven't had at least one major amateur over-haul, and 125's that are still running and capable of passing an MOT without, are doing well to get past 30K miles.
Most long lived I have ever come across was a 1983 Yamaha SR125; owned by an instructor from new. He bought it for his missus to learn on, and she only rode it for about three moths, and only to do her rider training, before she got her licence and abandoned it in the shed, where the instructor found it one morning, when pondering how to get to work when his own bike was in the dealer's for service.. and after a week, he 'adopted' it a his daily rider cos of the economy, and boosted the miles over that, using it to instruct on, pointing out that following newbs about on other 125' it was perfectly adequate ad he wasn't wearing out expensive big-bike tyres in the process! That bike had gone through 80K miles I think, ten years ago, and the other instructors were taking bets on whether it would go round the clock (99,999miles) before it broke on him. I don't know whether it made it, but I wouldn't be surprised.. but that is the 1 in a million odds beater to set the end-stops of what might be achieved, everything being stacked in that particular bikes favour from day 1, a better conscientious rider, with high standards of maintenance and diligence.
Believe its essentially the same engine in the YBR.. which suggests it has the potential for plenty of longevity, but still, anything over 50K is going to be doing well, and more reasonably, 30-40K is more likely service-life-expectancy.
gbrand42
PostPosted: 21:44 - 06 May 2016    Post subject: Reply with quote
Whatever happened to Paddy's old mega-mileage Varadero? Does it still live?
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
M.C
PostPosted: 22:51 - 06 May 2016    Post subject: Reply with quote
Wouldn't be that concerned with the engine (properly serviced) lasting to 60k, its all the other bits.
Just a general impression, but I see 30k for a bike as equivalent to 100k for a car, the sort of mileage where (depending on the model) you're somewhat going beyond what was expected for the bike.
Yes a CBR600F might get to 200k, but most bikes won't. I don't recall seeing 60, 100, 200k service intervals Very Happy
Dave70
PostPosted: 09:14 - 07 May 2016    Post subject: Reply with quote
My R125 engine lasted 30,000 miles and that was very well looked after all its life (I had it from new).
I have spoken to a number of mechanics, all have been quite surprised I got that many miles out of it. The number of miles those engines tend to last is around 20,000 miles and I've been told this more than once and seen many have a re-build around that milage.
On a couple of occasions mechanics have told me that the only reason I got so many miles from it, was because I looked after it. The majority, it would seem, are neglected by the yoof.
Robby
Dirty Old Man
PostPosted: 11:35 - 07 May 2016    Post subject: Reply with quote
Mileage doesn't kill bikes, inactivity does.
So a new YBR, ridden regularly and serviced by the schedule will keep going. 60k should be easily achievable.
However, if that bike spends a couple of years sat in the shed doing nothing, expensive failures become likely. Rubber bits dry out and crack, metal bits rust, electrics corrode. This leads to a series of expensive failures that cost a fair bit to fix.
Also consider fitting a drain valve for easy oil changes without having to touch the sump plug. If you're changing the oil every 2k miles you're likely to end up stripping the sump plug at some point.
M.C
PostPosted: 14:29 - 07 May 2016    Post subject: Reply with quote
Genuine question, on programs such as shed & buried, how do they get an old barn find running and on the road within a short amount of time? I'd expect everything to be seized up/need lubing/greasing etc. Does a lot more work go on than they let on?
-Matt-
PostPosted: 14:43 - 07 May 2016    Post subject: Reply with quote
Interesting; just checked the MOT status of my old one and it had a new one done last month. Had done about 25k when I sold it 6 years ago Shocked. Assumed it had probably been nicked or died by now. Having said that, I suppose it could be on its 8th new engine or something Whistle.
The last post was made 10 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 140.91 Kb
