Am I just being paranoid...
andym
PostPosted: 20:05 - 07 May 2016    Post subject: Am I just being paranoid... Reply with quote
Couple of days ago I was cleaning the chain on the Ninja and a group of teenagers walk past and one of them comment "that's a f**kin' bel'ur man" and another says to me "ah'm coming back the night wae the bolt cutters".... I say something along the lines of "good luck, the seats wired to the coil"...... after which they carry on walking saying about it being a joke etc.
Today I go to the lockup and the handle had been pulled apart.... this is similar to the handle:
https://www.locksonline.co.uk/image/cache/catalog/product-images/AS9981-500x500.jpg
The handle is 2 separate parts and it was the outer casing that had been pulled open..... is it possible to bypass the lock by removing the handle on these locks?
I've spoken to the concierge about it and they've said they'll keep the camera pointed at the lockups and I've chained the bikes together.
But am I just being paranoid.... is it possible that someone bumped against the handle and separated it?
-Matt-
PostPosted: 20:28 - 07 May 2016    Post subject: Reply with quote
Can you get permission to install a garage defender?
Edit: Was assuming its an up-n-over garage lock up? Useless if not Laughing.
Commuter_Tim
PostPosted: 20:55 - 07 May 2016    Post subject: Reply with quote
Unlucky man it doesn't sound like you're being paranoid, I fucking HATE Pikeys! Sad
Is it possible you could always keep it chained to something? (Preferably ground anchored)
If your chain is substantial enough its unlikely some radgey scum is getting away with your bike easy. (although someone with slightly more brains might.)
I recommend these fellas
They're honest enough about which size chains can be used for what.
General rule of thumb if its a static location, go for one of the 16mm or 19mm link jobbies if you can.
The average smackhead doesn't have the strength to hand bolt crop a 19mm with any size croppers.
I ride a Bandit 600... badly.
Chuffin Nora
PostPosted: 09:05 - 08 May 2016    Post subject: Reply with quote
Would that there was available -- working along the same lines as a Jack-in-the-box -- 'The Patented Garage Defender', that being the grown-up version of One Tough Little Son-of-a-Bitch.
The perfect organism, whose structural perfection is matched only by its hostility.
And the perfect foil against those unclouded by conscience, remorse or morality.
The only problem I can foresee is how the fuck to get it back into the box come the morning. Laughing
Link to T-shirt outlet, please!
There's a fine line between integrity
PostPosted: 09:20 - 08 May 2016    Post subject: Reply with quote
Point of order, these would be neds, not pikeys.
I don't think that's paranoia, that's preparation. I'm amazed they didn't get in.
I went for Enfield locks because they're not as obvious as a Garage Defender. You'll want to have a good thick frame to bolt them into and you will need power tools and a selection of large bits to fit them.
MCN
PostPosted: 14:33 - 08 May 2016    Post subject: Reply with quote
This Paranoiyah
I don't like washing my bits in public.
I have more than one bike in the garage and it's just too much bait for the Regional Scrotatti to miss.
Whenever I do anything in the garage I try to remember to hoi the tarp over the bikes. I leave junk in front as a sort of camouflage too.
It probably is paranoia but I'm easy with it.
My garage door is remote operated motorised up & over. It is impossible to force open using the handle or pushing the latches in. I fitted a special device (cannot find the link) to the remote operating mechanism which dead locks the door unless opened from the inside by the motor control or the release mechanism. You could open using a Sherman tank or something maybe.
I have a steel door at the back where the widin wan was more vulnerable.
My weak link now is the shit roofing sheets. i have considered slate as an upgrade some day.
andym
PostPosted: 21:16 - 08 May 2016    Post subject: Reply with quote
Rogerborg wrote:
....You'll want to have a good thick frame to bolt them into...
Good thick frame you say.... if they are able to drag the Ninja and VFR (VFR has seized front and back brakes at the moment) out of the lockup when both front wheels are chained together (after the concierge fails to spot a group forcing the lockup door).... then there's not a lot I can realistically do to stop them.
MCN I only have junk bikes, which at the end of the day are just bikes.... just very inconvenient if I was to find the lockup door open and no bikes in there when I'm due in work 20 minutes later.... that's really what I'm paranoid about
thx1138
PostPosted: 21:35 - 08 May 2016    Post subject: Reply with quote
I once pushed my dirt bike back from a garage, from the wrong part of town, they were popping up like meer cats all over the place Sad
The last post was made 10 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.5 - MySQL Queries: 14 - Page Size: 59.35 Kb
